Nissan Navara ZD30 Timing belt?
Submitted: Monday, Jun 12, 2006 at 10:34
RussellP
My 03/03 Navara's 100k service is coming up soon. The manual indicates that the timing belt should be changed at 100k. However, I've been told that it has a timing chain and not a belt and therefore it doesn't need changing.
Can anyone shed some light on which the ZD has: Belt or Chain?
thanks
Russell
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Monday, Jun 12, 2006 at 11:08
It is indeed a chain. I suspect the service is a check of chain condition and tensioner. I will check my documents and let you know.
178057
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Monday, Jun 12, 2006 at 11:14
My service shedue published by Nissan says nothing of a timing chain service at 100K.
The only unusual service item at 100,000K is valve clearances.
434243
Follow Up By: Exploder - Monday, Jun 12, 2006 at 18:54
I Think somebody said once that the Nissan service Manuel that you get with the car is universal for all Nissan cars so it will list chit that densest apply to your car sometimes.
434288
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Monday, Jun 12, 2006 at 20:09
yes i think it lists petrol stuff as
well as diesel
434302
Follow Up By: RussellP - Monday, Jun 12, 2006 at 21:41
Yep, my schedule has both petrol and diesel. Both mention changing the timing chain at 100k.
Interesting.
434338
Follow Up By: MATT.D(WA) - Monday, Jun 12, 2006 at 22:06
My manual says to change the timing belt for the "camshaft and injection pump" on the diesel engine. Don't know if this is the same as the main timing belt/chain people are talking about or not.
Matt.
434342
Follow Up By: Outbacktourer - Tuesday, Jun 13, 2006 at 22:30
This could be for the 4.2?
434531
