intercooler kits
Submitted: Monday, Jun 12, 2006 at 20:21
Rib Eye
I have just bought a denco intercooler kit for my 1kz-te hilux and without much mechanical knowledge have come to a hault. Has anyone installed one of thse before? if so can you remember if the brakets for the intercooler radiator/fan unit have to be paked out from the cross member? To me this looks neccessary to clear the air-con consensor unit. Any help would be much appeciated.
Reply By: crfan - Monday, Jun 12, 2006 at 21:02
Try Emailing Denco i'm sure they will help
P
178146
Reply By: Wosat - Tuesday, Jun 13, 2006 at 17:45
Good luck with the install...
Could you please provide some sort of report when you are finished?
I've been looking at the Denco kit for my Hilux as
well and would be very interested so see how you go.
Brett
178296
Follow Up By: Rib Eye - Friday, Jun 16, 2006 at 19:15
Just finished installing kit, was harder than instuctions lead you to believe. I couldn't get the air-con pipe to move as far as required so got professionals to run one new pipe out of the way. also the components that up the intake pipe ie cast elbows and intercooler barrel together are too long and hit against brake master cylinder causing awful vibration so i haksawed a few millimetres off one of the elbows.
First drive of it finished feels good with a noticable increase in the thottle reponse as
well as power. Heading away for a few weeks next wednesday so will be able to test it properly with full load. hope this helps
435137
Reply By: Truckster (Vic) - Friday, Jun 16, 2006 at 21:47
I agree with CR. Call Paul, he will set you straight within 10 mins dude.
178863
