hilux suspension
Submitted: Tuesday, Jun 13, 2006 at 19:20
ThreadID: 34906 Views:1815 Replies:2 FollowUps:1
hi everyone,
i am just wondering it anyone can help,i want to put a 3 or 4 inch lift on a 2003 duel cab lux,I dont know if it will lead to other problems and who will install it in sydney.Can anyone help
Reply By: boogyman - Tuesday, Jun 13, 2006 at 20:27
being ifs you probably wont get away with more than 50 - 60 mm lift on the front (with suspension) add a 2inch2 body lift and bigger tyres(32in at the most or you scrub out on inner guards) you will be gettin up there.......
AnswerID: 178328
Follow Up By: boogyman - Tuesday, Jun 13, 2006 at 20:29
forgot to mention this can be diy...cutting the cost significantly
FollowupID: 434473
Reply By: Member - Nick (Kununurra) - Tuesday, Jun 13, 2006 at 20:51
Had a 3" lift on my 4 Runner when I had it and it caused no dramas.I did have free wheeling hubs so cv shafts wernt turning all the time causing wear.I got three inches in the front by doing a ball joint drop,,fitting a spacer between the top ball joint and the upper control arm and you also drop the diff the same amount to even out the cv shafts.It also had OME torsion bars wound up slightly more than normal.If you check out some of the surf forums or 4wd monthly forum there's info on the ball joint kits.You will need a wheel allignment afterwards.
AnswerID: 178337
