96 GQ Clutch
Submitted: Thursday, Jun 15, 2006 at 15:34
Lorne
I need to replace the clutch on the gq and was wondering while the box is out what else should be done, It's only done 170K klm's. Any particular brand of clutch to put in and any ones not to use.
Lorne...........
Reply By: arewelost - Thursday, Jun 15, 2006 at 16:53
i gather you are putting in a clutch kit with new thrust bearing good idea to replace the spigot bearing at the same time and the front gearbox seal hows the rear engine seal and any core plugs i have found repco pbr parts to be very reliable and have heard a few good reports on the cheap replacement parts i have a nissan narvara so i replace all the parts above only because the gearbox is a major job to get out have to drop all the front
suspension torque bars and cross members hope this helps
178646
Reply By: Member - Vincent A M (NSW) - Friday, Jun 16, 2006 at 11:58
i would fit a centre force clutch (very Heavy duty) on my old patrol 1st clutch 125000klms & the 2ndClutch was a centre force clutch & 425000klms & i belive it is still going
178774
Follow Up By: Lorne - Friday, Jun 16, 2006 at 15:42
Thanks for the info will look into this brand and check price.
Lorne..........
435069
Reply By: 120scruiser (NSW) - Friday, Jun 16, 2006 at 17:59
Strongly, Strongly advise to have flywheel surface ground as
well as clutches wear in a taper formation due to the pressure plate spring forces.
I also agree to replace rear engine seal at same time as they are a bugger of a gearbox to get out and even worse to get back in.
178826
