Only allowed 15mm bigger over standard diameter in QLd..
Submitted: Saturday, Jun 17, 2006 at 11:01
ThreadID: 35009 Views:10502 Replies:2 FollowUps:12
Hi All,
In need of new tyres for my Rodeo tray, Qld only allows + 15mm increase in tyre diameter. Whats the overall tyre diameter for a standard tyre size of 205R16? Any opinions on the best possible choices in tyre sizes, whilst still staying legal. I want to get my diffs of the ground as much as legal..
Thanks everybody.
Cheers dornbus
Reply By: Gramps (NSW) - Saturday, Jun 17, 2006 at 11:12
dornbus,
Can't help you with a recommendation but try this link to compare sizes etc
calculator
AnswerID: 178919
Follow Up By: dornbus - Saturday, Jun 17, 2006 at 11:18
Thanks Gramps,
Whats the profile of 205R16?
FollowupID: 435222
Follow Up By: Gramps (NSW) - Saturday, Jun 17, 2006 at 11:26
dornbus,
I think that's your sidewall height (????) expressed as a percentage of your tyres width e.g. mine are 205/70R16. 70 is the profile.
FollowupID: 435226
Follow Up By: dornbus - Saturday, Jun 17, 2006 at 11:32
Hi Gramps,
I know its sidewall height, but whats the sidewall height or profile of 205R16 ????
FollowupID: 435228
Follow Up By: Gramps (NSW) - Saturday, Jun 17, 2006 at 11:41
dornbus,
It should be written on the side of your tyre. Mine are Road Grippers with a treadwidth of 205, diameter 16 and profile of 70 i.e. 205/70R16. Enter those three figures into Vehicle Stock Tyre Size and hit Compare Tire Sizes. Gives me an OD of 693.16mm.
FollowupID: 435230
Follow Up By: dornbus - Saturday, Jun 17, 2006 at 11:49
Hi Gramps,
The tyre size is 205R16 (thats the size stamped on the tyres & my tyre placard), common tyre size but can anyone tell me whats the profile of this tyre size??? Sorry Gramps, but also got me bam-boozled as to what the profile is on this size tyres????
FollowupID: 435231
Follow Up By: Utemad - Saturday, Jun 17, 2006 at 12:30
My Rodeo had 205/75 16 tyres originally but my friend's Hilux has 205R16 and they look taller. I have been told that 205R16 have an 80 profile but that is just what I have heard.
However it is all good and well to try and stay legal but if you are doing this to get your diffs higher off the ground then don't bother as what is 7.5mm more clearance going to do for you?
If your current tyres are still roadworthy then maybe you should wait until Qld decides whether they will endorse the new 50mm increase in diameter.
Have you got a suspension lift? As when I had my Rodeo I used to belly out on things far more often then scraping the rear diff. A 50mm suspension lift would be more beneficial than a 7.5mm tyre lift.
FollowupID: 435234
Follow Up By: dornbus - Saturday, Jun 17, 2006 at 12:40
Thanks Utemad,
Any idea when new tyre legislation will be coming in? Currently my insurance company ( budget direct) will not allow any lift.
FollowupID: 435235
Follow Up By: Member - Troll 81 (QLD) - Saturday, Jun 17, 2006 at 13:12
Dornbus
My advise is change your insurance company mate if they don't allow any lift then you are with the wrong mob. People do lifts for all sorts of reasons, towing, handling, etc etc if they can't understand that then change
my 2 cents
FollowupID: 435239
Follow Up By: Utemad - Saturday, Jun 17, 2006 at 13:23
My understanding is that new National Light Vehicle Code of Practice has been passed but Qld has yet to endorse it. So I have no idea when it will be when they will pass or reject it (maybe they will only endorse parts of it?)
As for your insurer I'd be looking for a new one.
FollowupID: 435243
Reply By: AS/KS - Saturday, Jun 17, 2006 at 16:05
Dornbus
Did you find out what the profile yet??
AnswerID: 178948
Follow Up By: AS/KS - Saturday, Jun 17, 2006 at 16:22
Back again,
205R16 i think have 80 profile
if so,
205/80R16 OD 734mm
your options
LT 225/75R16 OD 744mm OR 235/70R16 OD 735mm, which will fit your 16x6 rims
245/70R16 OD 749mm , needs 16x7 rim
I would stick with a LT type of tyre.
Hope this helps mate.
FollowupID: 435254
Follow Up By: dornbus - Saturday, Jun 17, 2006 at 20:59
Thanks AS/KS,
All the info provided helps a lot to help me determine my next tyre purchase, Many Thanks to all those who have taken time to reply or read my Question, u all help 2 make this forum what it is... I reckon this Forum is Great.....................
FollowupID: 435284
Follow Up By: Billowaggi - Saturday, Jun 17, 2006 at 23:40
Hi All I run 31x10x 15 on my 96 tray Rodeo and all works good no scraping or fouling, speedo reads about 4% slow but I am aware of this so not a prob. I have better ground clearance [25mm] a 15 in tyre so better side wall flex and 'bagging' when deflated in the sand also a cheaper size of tyre to buy.
Regards Ken.
FollowupID: 435308
