75 sereis ute door catch
Submitted: Sunday, Jun 18, 2006 at 16:43
ThreadID: 35042 Views:4901 Replies:3 FollowUps:0
Hi all,
Does anybody know if there is a way to adjust the drivers side door catch on a 75 series landcruiser ute to stop the door rattling?
Thanks in advance.
Reply By: Peter 2 - Sunday, Jun 18, 2006 at 17:18
The actual lock assembly in the door will move a very small amount when the screws are loosened but the big adjustment is in the bit on the door pillar, draw a pencil line around it before loosening the two bolts and then tap it gently in the required direction, nip the bolts up and check it, repeat if required.
AnswerID: 179078
Reply By: Brian B (Mackay Qld) - Sunday, Jun 18, 2006 at 17:25
Problem fixed, just adjusted the striker on the body and greased around door latch and striker.
AnswerID: 179081
Reply By: Skid - Monday, Jun 19, 2006 at 12:02
Wrap a bit of electrical tape around metal loop on the door post
AnswerID: 179186
