GU Pulling Left
Submitted: Monday, Jun 19, 2006 at 14:11
ThreadID: 35069 Views:2692 Replies:13 FollowUps:6
Can you Brains help me with my GU Patrol Pulling left Alignment within specs
.I suspect Steering Damper This has been getting worse last 30,000k
What is the best damper to fit it that is Problem,
Anyone had this problem,
Expert Advice is greatly accepted.
dj
Reply By: Footloose - Monday, Jun 19, 2006 at 14:14
A silly thought, but all your tyre pressures are correct ?
AnswerID: 179230
Follow Up By: djpatrol - Monday, Jun 19, 2006 at 14:16
All 42 psi with BFG AT
FollowupID: 435475
Follow Up By: Footloose - Monday, Jun 19, 2006 at 14:22
Does it pull to the left all the time or only on certain roads ? Done some heavy 4wding lately ?
FollowupID: 435476
Follow Up By: djpatrol - Monday, Jun 19, 2006 at 14:27
No Offroad footloose its a tow only truck 20ft van its been getting worse over time thats why I suspect the Damper, all roads some worse than others depends on road camber,
FollowupID: 435478
Reply By: Member - Roachie (SA) - Monday, Jun 19, 2006 at 14:27
AFAIK all/most Patrols tend to pull to the left....they were not designed for our left-road driving, camber etc. Try driving on the wrong side of the road (eg: when overtaking) on a quiet country road (Please be careful; I won't accept any responsibility for you having a head-on bingle!!!! hahaha).
I have fitted a 4Ways Return To Centre steering damper and this has helped my GU a lot.
Roachie
AnswerID: 179234
Follow Up By: Member - Craig D (SA) - Monday, Jun 19, 2006 at 14:51
My last GU (3litre) was a bugger pulling to the left. Fitted a 4Ways RTC and the problem became only slight. Changed tyres from Cooper A/T's to BFG A/T's and it ran pretty true. I'd suggest an RTC as Roachie said.
FollowupID: 435487
Reply By: Dave Thomson - Monday, Jun 19, 2006 at 14:33
Hi ,
I dont know anybody thats got a Patrol and doesn't pull to the left , allbeit even slightly, it's a common fault with them,there is one solution and thats to have a castor correction plate fitted , dont know how much that would cost but I ended up just living with it as it didn't do it all the time, also heard mags would help,
anyway finally solved it.................by selling the Patrol...............
sorry couldn't resist that,
regards,
AnswerID: 179235
Reply By: Member - Troll 81 (QLD) - Monday, Jun 19, 2006 at 14:49
Mine does the same thing and I have learned to live with it as well, I don't think there is anything you can do about that
AnswerID: 179239
Reply By: Phil100 - Monday, Jun 19, 2006 at 15:15
Mine did the same, I fitted castor bushes to the left hand side. You need about 1/2 to 1 degree extra caster on the left side to allow for the road camber when driving on the left side of the road, patrols and many other vehicles are set up for other countries and the castor was about equal on both sides. I did the bushes on mine rather than the plates mainly for the cost, about $130. I fitted a return to center steering damper before doing the bushes and it almost took the pull away, but the left hand front tyre started to scrub on the outside edge.
AnswerID: 179246
Reply By: Brid from Cost Effective Maintenance - Monday, Jun 19, 2006 at 16:05
Geez DJPatrol!
My 2001 GU did NOT pull to either side, so I wonder about others' comments that they all do. These other guys probably have more experience with Patrols specifically, but if yours is becoming worse, then clearly there is a problem, and it is not normal ex-factory stuff.
I would check things like brakes. Calipers can seize at times, pistons become a bit sticky. Wheel bearings (LHS?). Jack the wheels up and check lateral play and resistance to rotating. Easier to compare if both wheels are in the air at once. Also check for worn steering knuckle bearings (king pins equivalent). Grab the wheel top and bottom and try to rock it hard. Or both hands on top and rock hard, to feel for play. Steering joint play. Have somebody rock the steering wheel back & forth continuously while you check for play at all steering joints.
Also, even though tyre pressures are even, there could be problems if tyre wear is uneven.
You could swap tyres front to rear &/or side to side to see if there is any influence. May be other things I haven't thought of at the moment, but hopefully it's not too hard to find.
Hope you have some luck.
Brid
AnswerID: 179255
Follow Up By: warthog - Monday, Jun 19, 2006 at 21:39
I agree, our '00 patrol is fine.
FollowupID: 435567
Reply By: Michael ( Moss Vale NSW) - Monday, Jun 19, 2006 at 19:56
It pulls left because its eager to leave the Black Top......... WOW!! What a vehicle!!! Michael
AnswerID: 179305
Reply By: Rick (S.A.) - Monday, Jun 19, 2006 at 19:59
Anyone had this problem.....................
You bet.
Please use the search facility on this site. on top of the "home" Forum Page is The Forum search function. it is self explanatory.
for example: threads 14168; 16181; 16196 are examples of this specific query that has been responded to.
AnswerID: 179306
Reply By: Peter McG (Member, Melbourne) - Monday, Jun 19, 2006 at 21:24
Try dropping the tyre pressure - I run 34 front 36 rear. 42 way to high imho
AnswerID: 179337
Reply By: Member - Pezza (QLD) - Monday, Jun 19, 2006 at 21:50
Hi djpatrol,
Agree with Roachie and Craig, put a 4ways RTC damper on and put slightly more pressure on the spring when setting it up, worked well with mine.
Also as Peter said try lowering your pressures, I run 36 front and 34 rear when empty, smooths out the ride a bit and less work for your shockies.
Avagoodn
Pezza
AnswerID: 179344
Reply By: Ron George - Monday, Jun 19, 2006 at 22:33
If you want a quality lasting solution to your problem take your rig to a Big Wheels Truck Alighnment centre they have branches in every major East coast city.
I had the same problem with a Dana 44 on a 4x4 F truck, had about four alighments in the space of 18 mths from so called alighnment specialists all amounting to zip, Big Wheels took most of the day to do the job but they got it right, they actually tune the suspension to the vehicle, sometimes setting the suspension to manafactures specs just won`t cure the problem (gotta think outside the square) cost me a bit over $400.....spittin that I didn`t find em first up.
Cheers Pushy-cat
AnswerID: 179357
Reply By: AJB - Monday, Jun 19, 2006 at 22:43
My GU pulled to the left and got worse over time. Went to 3 or 4 so called specialists and they all said it's within specs and there is nothing more that can be done. Then I went to a bloke who does aglinments on trucks and he said he could fix it. He did almost. It still pulls slightly to the left but only when there is a fair camber on the road. On freeways etc it is near perfect. Not as good as a ford but the nissan is a japanese light truck and will always ride rough.
AnswerID: 179361
Follow Up By: AJB - Monday, Jun 19, 2006 at 22:50
Forgot to say he reckoned the LHS wheel base length was shorter than the RHS, or the oher way around. Anyhow that was about 120,000kms ago and I have done nothing to that part of the vehicle since (the rest has been rebuilt!). He reckons he'd done heaps and not just nissans and he could have fitted a castor correction kit but then I'd be pulling to the right.
FollowupID: 435583
Reply By: Darren C - Tuesday, Jun 20, 2006 at 11:05
Apparently Nissan do have a 'fix' for this - have seen it mentioned on other forums but apparently the guy who had it done says that his Patrol now pulls to the right!! Just cant win!!
AnswerID: 179424
