GU rear door
Submitted: Monday, Jun 19, 2006 at 16:42
ThreadID: 35075 Views:1763 Replies:5 FollowUps:4
hello all,
i have an 03 Gu patrol and there is a rattle / vibrate noise in the rear door, it is killing me. i have checked everything and it is still there.
I have taken it to my nissan dealer a number of times and all they do is grease the seals, they are useless.
i have a 35 inch spare on the rear door,
When i take the spare off it goes away, i have been told that a 35 is to much weight for the rear doors. is this true?
has anyone else had problems with there rear doors?
I have been told to put a rear wheel carrier on for the spare, i am not a fan of the look of them.
Reply By: Truckster (Vic) - Monday, Jun 19, 2006 at 17:06
Think you have answered it by removing it and the noise goes away.
Once its on the back you dont see it but they are HEAVY.. so new springs too
AnswerID: 179270
Follow Up By: Peter McG (Member, Melbourne) - Monday, Jun 19, 2006 at 21:20
Bruce,
Did you get any rattle problems using the spacer on the 285s?
FollowupID: 435562
Follow Up By: Truckster (Vic) - Monday, Jun 19, 2006 at 22:56
Nope none.. Great little thing..
FollowupID: 435586
Reply By: Gu_Patrol - Monday, Jun 19, 2006 at 17:06
Yep mine does it with the 33" , I hate havin the kaymar wheel carrier on i'm in town,
AnswerID: 179271
Reply By: BBB - Monday, Jun 19, 2006 at 17:19
Brent
I had the same problem with my GU I have 285 175 R16 Brigestone A/T.
I fixed it by using 25mm x 25mm steel tube painted it with 3 coats of Kill Rust paint to pack out the bracket that holds the spare wheel on.
The bolts that hold that bracket on are 65mm long and are long enough to do the job.
I did mine 3 years ago and no problems way cheeper than swing arm types.
Try this first
BBB
AnswerID: 179278
Follow Up By: Brent.n - Monday, Jun 19, 2006 at 17:59
i already have an arb spacer between the spare holder
FollowupID: 435529
Reply By: Dave ....Adelaide - Monday, Jun 19, 2006 at 22:08
Hi Brent
Im sur you posted this same question a couple of weeks ago .....Cheers ....Dave
AnswerID: 179349
Follow Up By: Dave ....Adelaide - Monday, Jun 19, 2006 at 22:35
Yep you posted on 12th this month ...post 34841.....cheers ....Dave
FollowupID: 435580
Reply By: mick - Tuesday, Jun 20, 2006 at 12:01
I had similar prob, na not the tyre but the number plate cover, bit of foam wedged between the back of the cover and the number plate, GONE!!!
could be it
Mick
AnswerID: 179439
