Camper manual water pump
Submitted: Wednesday, Jun 21, 2006 at 09:06
tdv
Hi all
My aussie swag kitchen
hand pump has begun to leak and only pump small amounts of
water. Anyone know where to buy parts or replacement taps online?
Tez
Reply By: Rigor - Wednesday, Jun 21, 2006 at 09:18
Hi Tez , I have purchased parts for
mine at a caravan place in Virginia Brissy ,
I am sure any caravan and
camping place will have parts , not sure about online though , may have to let your fingers do the walking.
Cheers Dave L
179622
Reply By: Brian B (QLD) - Wednesday, Jun 21, 2006 at 09:28
Tez,
CLICK HERE and you will be taken to an online store that sells heaps of parts for caravans and campers. Hopefully this will help you out.
Have a good one.
179623
Follow Up By: tdv - Wednesday, Jun 21, 2006 at 10:19
Just what I was after...thanks
435839
Reply By: Shaker - Wednesday, Jun 21, 2006 at 09:30
A brand of pump & your location would be a big help!
179625
Follow Up By: tdv - Wednesday, Jun 21, 2006 at 10:20
Sorry. Trojan and in Far Nth Queensland. I tried a few local shops and everyone just looked at the pump with a blank face!
435841
Reply By: Member - Nutter (QLD) - Wednesday, Jun 21, 2006 at 09:46
Hi Tez,
Camec also sell this sort of gear, they are over the southside of
Brisbane, you can have a look at their website at camec.com.au
See ya
Guy
179626
Reply By: itsdave - Wednesday, Jun 21, 2006 at 15:00
Ive an Aussie swag also and had problems with the
hand pump so replaced it with another from Whitworths, didn't last long so have now replaced it with a 12volt inline Whale pump wired up to a toggle switch using the same bracket as the original
hand pump. Also had to put in a 1 way valve and have to prime the line when setting it up
Cheers Dave
179676
Follow Up By: Member - Jeff M (WA) - Wednesday, Jun 21, 2006 at 19:12
Yeah, you can buy a flo jet self priming pressure activated 12v pump for about $100. I fitted one in the back of the surf and it's probally the best mod I ever did to the car. I just fitted a garden hose type spray end and all you do is pull the lever on the sprayer and the pump fires up automatically giving you pressured
water, can even use it for a cold shower if you want! Great for doing dishes and hosing the 3 tonne of beach sand of the kids before they get in the car.
You could, of course, just fit any type of tap on the end (even a normal household
water tap) and it'd work fine. Be just like being at home!! ;-)
435921
Reply By: Shaker - Wednesday, Jun 21, 2006 at 16:08
You can order on online here:
Site Link
As there are only $29.50, it's not worth trying to kit yours.
179687
Follow Up By: Shaker - Wednesday, Jun 21, 2006 at 16:10
Sorry, fingers went faster than my brain .... (not hard to do!)
You can order one online here:
As they are only $29.50..... etc etc
435895
