80series landcruiser solid and sliding rear windows
Submitted: Thursday, Jun 22, 2006 at 00:56
ThreadID: 35164 Views:6988 Replies:2 FollowUps:0
Hi Everyone
I want to swap my 2 solid rear windowns on my 80series with the sliding windows.
I've sourced the sliding windows but has anyone out there changed them over?
Any details on how to do it?
Reply By: Emo - Thursday, Jun 22, 2006 at 11:45
Quarter Window Glass Removal
1. Remove floor mat support plate (remove 5 screws and the plate)
2. Remove Quarter Trim
a. insert a screw driver between the retainers and quarter trim to pry it loose
HINT : tape the screwdriver tip before use
b. remove the quarter trim
3. Remove rear pillar garnish
a. insert a screwdriver between the retainers and the 1/4 trim to pry it loose
4. Remove rear seat side garnishes and scuff plate
a. insert a screwdriver between the retainers and the body to pry it loose
HINT : tape the screw driver tip before use
b. pull out the side garnish
5. Remove the vent louver and 1/4 belt moulding
a. remove the nut from the vent louver
b. insert a screw driver between the retainers and body to prit it loose
c. pull out vent louver
d. pull out the clips from the edge of the panel, and remove the moulding
6 . Remove the 1/4 window glass
if reusing the weatherstrip:
a. using a screw driver loosen the weatherstrip from the body
NOTICE: be careful not to damage the body
b. pry the lip of the weatherstrip outward from the interior part of the body flange
c. pull the glass outwards and remove it with the weatherstrip.
if using new weatherstrip:
a. from outside of the vehicle, cut off the weathestrip w/ a knife
NOTICE: do not damage the body and the glass
b. push the glass outwards and remove the glass
c. remove the remaining weatherstrip.
Borrowed from ih8mud.
AnswerID: 179840
Reply By: TagsOZ - Thursday, Jun 22, 2006 at 13:50
Much appriciated.
AnswerID: 179883
