Oil pressure
Submitted: Friday, Jun 23, 2006 at 19:13
edbid
80 series cruiser with no oil pressure gauge reading - i suspect it is the sender unit.
anyone give me a tip where the oil sender unit is - petrol model - and how to test if it is the gauge or the unit?
Reply By: FZJ 80 - Friday, Jun 23, 2006 at 19:59
Edbid.
I think it will be under inlet manifold. Remove wire from sender and earth wire to engine block, turn ignition on and guage should go to full. This indicates the guage is ok and leaves you with a sender fault or of course an oil press fault.
180134
Reply By: edbid - Monday, Jun 26, 2006 at 10:51
Thanks Greg,
finally found it under the exhuast manifold, they do like to hide em and was simply a wire off.
phew !
Ed
180379
