Rebuilding a GQ TD42 ???
Submitted: Saturday, Jun 24, 2006 at 12:35
Flash
Has anybody been through this exercise. My son's TD42 is nearing 600,000klms (yes, that much!) and not surprisingly is getting a bit tired, though still running OK. The rest of the vehicle is still good mechanically.
He's considering stripping it down and doing a recondition/rebuild sometime soon. I've done a few rebuilds on older petrol engines over the years, but have no idea about the costs involved in doing a Japanese diesel. Has anyone got any feedback on costs of parts etc in rebuilding a TD42? Obviously a lot depends on what parts need replacing, but any feedback at all would be appreciated. (My son and I are quite capable of doing the actual disassembly/reassembly ourselves, but will obviously need to send any bits off to have re-machining etc done.)
Thanks in advance for any feedback,
Reply By: fisho64 - Saturday, Jun 24, 2006 at 13:30
Hunt around on the internet (not sure where you are?) and you should be able to find a rebuild kit-pistons, rings, liners, bearings etc. Then you only need to get the crankshaft, camshaft, head etc ground if necessary.
180190
Reply By: strzelecki - Saturday, Jun 24, 2006 at 13:34
Site Link
180191
Reply By: Member - Axle - Saturday, Jun 24, 2006 at 21:18
Hi flash.
Your son has had a good run!!, But i would think now is the time to look at things very carefuly, to rebuild that motor from top to bottom witch will have to be done, ( TO DO A GOOD JOB) I think you should look at vechicle value against these costs, AS not a nissan owner I can't even give you any idea, on rebuild costs but as said be carefull.
Axle.
180226
Reply By: Flash - Saturday, Jun 24, 2006 at 21:22
Thanks for the info so far,
180227
Reply By: Truckster (Vic) - Sunday, Jun 25, 2006 at 10:37
Speak to Nick (woop) on either the Patrol
forum, or on outer limits.
Hes been through it and doing it properly doing most himself with Genuine parts was around $8000-9000
180251
Reply By: Pilbara Wayne - Sunday, Jun 25, 2006 at 23:19
GU 4.2TD on ebay for $3500.
Item number: 170001254497
Might be a useful link... who knows what you are after??
180332
