Pajero NP roof rack
Submitted: Sunday, Jun 25, 2006 at 16:58
Member - David M (VIC)
On my pajero I have factory fitted roof rails with a max capacity of 60kg(not much good when roof rack weighs half that) Does anyone know whether by removing these rails and directly mounting the rack to the same mounting location whether this will increase the load capacity. Mitsubishi will not comment as the roof rack is not factory genuine.
Reply By: Member - Marquis - Sunday, Jun 25, 2006 at 17:58
You cannot use factory mounting at all if your travelling on bad roads, it will put holes in your roof.
If the roof rails can be removed, then you can have the rhino track mounted which is bolted and riveted (about $250-275 fitted).
180282
Reply By: Member - David M (VIC) - Sunday, Jun 25, 2006 at 18:23
thanks Marquis. not what I wanted to here but what I expected.
180286
Reply By: pojo - Tuesday, Jun 27, 2006 at 20:02
Rhino racks are the only way to go been there done that
180686
