GQ NISSAN TD42 INJECTOR PUMP 1990
Submitted: Monday, Jun 26, 2006 at 21:05
JOEPATROL
I have fuel leaking from rear of injector pump, can the seals be replaced without removing the pump from the vehicle? Has anyone attempted this before? This involves removing injection pipework and taking out the back of the injector pump. Appreciate any ideas and advice on this. Thanks Joe
Reply By: GUPatrol - Monday, Jun 26, 2006 at 21:16
Joe,
The reason why some older pumps leak us due to the newer fuels. The seals used on the pump are not compatible with the new low sulphur fuel and start to leak.
Some people just replace the seals on visible leaks but the pump may also be leaking at the front towards inside the engine and you wouldn't know it is diluting the oil.
You are better off getting the pump serviced to comply with the new fuels.
Will
180491
Reply By: Truckster (Vic) - Monday, Jun 26, 2006 at 22:15
Yes.
Yes
Yes...
What he said above this one. Take the opportunity to get pump and injectors done you will never look back, better economy and power usually afterwards
180506
