100 series turbo
Submitted: Wednesday, Jun 28, 2006 at 21:15
ThreadID: 35373 Views:2030 Replies:5 FollowUps:5
well finaly done it,
finaly got to turbo and intercool my hzj105 with a system from safari fitted by me and tuned by out of town 4wd took it for a run this sarvy and what a difference it has made its unbeliveable. i would recomend it to anybody thinking of doing it to go for it. i also fitted a 3'' exhaust at the same time it was from beaudesert exhaust
fitted by me also so easy(thanks brian and staff).ok happy motoring to all
deano
Reply By: Member - Stephen M (NSW) - Wednesday, Jun 28, 2006 at 21:27
Hi there black bull, yeah ive just bookes myn in for a turbo fit in 3 weeks time, got sick of it been so sluggish up hills, especially now we have the camper' didnt want to do it as it has done 285 k now and couldnt see the value in it but asked the question and I can transfer it accross to a 3Litre 5L hilux in the future if I want to. I'm paying $3275 for myn supply and fit including new exhaust and that it putting on Dyno before and after recalibrating the pump, it it getting done by turboglide in wollongong only an 80 minute run for me here in Penrith Sydney. They run 8 pound boost saying it will give an extra 30% increase Note: These are factual rear wheel power figures, not estimated flywheel drafts.
KPH NM before NM after KW before KW after
60 224 288 33 40
80 220 286 43 54
100 196 244 48 60
120 156 188 47 55
Hope myn makes a differance as spending this much on a 10k 89 hilux I know wont get any of it back hence thats why I asked the question about transferring to a later model in I want to. Regards Steve M
AnswerID: 180918
Follow Up By: fisho64 - Wednesday, Jun 28, 2006 at 23:10
the cheapo way to do it is get a turbo off a 2 LT, should be able to get a whole setup from wreckers for a grand or less. There are 3 different bolt patterns of manifolds, any of them can be modded to fit but (from memory) post 92 surf is the one that fits straight on. Did it on mine 18 months back (225000k's) done 30000 since at about 6 psi only. guessing 20% extra puff at topend and around 100k's extra per tank.
Very suprised overall.
FollowupID: 437227
Follow Up By: 100TD - Thursday, Jun 29, 2006 at 17:08
i believe its only a manifold stud shuffle and your in business!!
FollowupID: 437384
Follow Up By: fisho64 - Thursday, Jun 29, 2006 at 22:58
There are 3 patterns, cant remember which they are from the they are early surf, late surf and Bundera. 1, like Hilux, has all flange studs sloping same way, 1 has 2 sloping one way, 2 going opposite, and the other is all sloping same way but slightly different angle. They can all be made to fit though.
FollowupID: 437473
Reply By: Member - Stephen M (NSW) - Wednesday, Jun 28, 2006 at 21:49
Sorry there black bull meant to ask you is yours watercooled or not ? The one Im gettin fitted is not as the bloke said its not required on diesel motors,as they cause steam to build up and can cause pressure back through the system causing head problems,maybe he's just referring to hilux's, I presume he knows what he's talking about considering I know jack sh@t about turbo's and he's been doing it for 30 years. regards Steve M
AnswerID: 180927
Follow Up By: black bull - Wednesday, Jun 28, 2006 at 22:07
hi steve,
no mines not water cooled as they told me the same thing. not needed
it s unreal you'll love it
deano
FollowupID: 437212
Reply By: paul.as - Thursday, Jun 29, 2006 at 09:03
So when you fit a turbo as well as more power you get better fuel economy? Who much better do people find it in terms of economy?
Paul
AnswerID: 180996
Reply By: Trevor R (QLD) - Thursday, Jun 29, 2006 at 09:19
worth keeping an eye on exhaust temps with this setup as if they are running rich they will melt pistons. Quote from Toyota dealer and shown an engine on their workbench to prove it.
Not saying yours is but just some advice, to throw out or keep in the brain box your choice.
Good luck with it.
Trevor.
AnswerID: 180999
Reply By: FZJ 80 - Thursday, Jun 29, 2006 at 20:17
Black Bull.
Slightly off topic but just a question on the exhaust system. I am thinking of having my system replaced, manifold to tailpipe and are thinking Beaudesert exhaust. Did they weld the connections or clamp them? was it a good job? mine is an 80 petrol and is mostly original except rear muffler. Looking for a good job with improved performance if possible.
AnswerID: 181096
Follow Up By: black bull - Friday, Jun 30, 2006 at 20:35
hi greg, my exhaust system is a 3" steel and the workmanship is faultless very nice job and bolted togeather with flanges i fitted it myself very easy to do hope this helps
deano
FollowupID: 437632
