green stuff to stop tyre going down
Submitted: Wednesday, Jun 28, 2006 at 21:57
greghud
saw it in my local and dunno what its like so seeking comments
cant rember what its is called so no luck with a search
i was actualy considering it for the quad as it would be easer than plug and re inflate whilst out bush, cause its only gonna happen when your
miles from the car and tool box (thanks murphy)
any comments?
thanks greg
Reply By: Member - JohnR (Vic)&Moses - Wednesday, Jun 28, 2006 at 22:02
It's SLIME Greg. If you have a small hole in the tread area it may help you. When I have had it before it hasn't helped me. Have had a few bottles in the shed that have been used though not very successfully :-( Yes, that is in four wheel bikes - quads. In a 4by ute/truck I would rather the string type plugs and some good pressure.
180931
Reply By: hoyks - Wednesday, Jun 28, 2006 at 22:23
I have some stuff called 'never flat' that I use in the pushie. I have never had a flat, but I don't ride much either;-).
I used to have tyre slime and it worked OK. I changed a tyre and the tube had hundreds of little thorns from catheads, but it didn't leak.
180937
Follow Up By: Motherhen - Wednesday, Jun 28, 2006 at 22:48
You ran over CATS? Ooooooo
437221
Follow Up By: Trekkie (Member - WA) - Wednesday, Jun 28, 2006 at 23:06
Motherhen you are a trouble maker and David is watching you
437226
Follow Up By: Motherhen - Wednesday, Jun 28, 2006 at 23:15
Meiow
437228
Follow Up By: hoyks - Thursday, Jun 29, 2006 at 18:22
It's OK, it was only their heads ;-)
437415
Reply By: cipher - Wednesday, Jun 28, 2006 at 23:00
I have used a similar type of thing its call Tyre Fix, you can pick it up from most servo's FanTASTIC stuff!
Its just a spray in foam sort of thing and actually has to set... you can see when you inflate the tyre where the puncture/s were and the foam begins to seep out and in no time it stops, really great stuff... i had a puncture out bush put that gear in it and havnt had a drama since....and come to think about it i only just remembered that i still have it in it, hahah.. thanks for the reminder i guess it just goes to show that its worked a treat and i put that in probably 2 months ago and i do 600km a week, so you do the math!
GREAT stuff!
180947
Follow Up By: Member - Stephen M (NSW) - Thursday, Jun 29, 2006 at 08:36
Hi there cipher, I remember reading on the instructions on the same stuff I use to have which was called Finnie Leak, white foam looking stuff, said on instructions was a temperary fix only and to actually replace the tyre when possible as it ate the rubber away from inside out, maybe the stuff you have does not have or need that type of warning, just thought I'd tell you incase, the last thing you want at 100klm big bang blowout.I also remeber reading that you had to fill tyre with foam then drive a few klms so foam would distribute around the inside of the tyre then stop and put in required air pressure, presume its the same sort of stuff you all talking about. Regards Steve M
437256
Follow Up By: cipher - Thursday, Jun 29, 2006 at 16:08
Yeah steven i would assume its the same sort of stuff, the can i had didnt say anything about being temporary (i even read the fine print) so hopefully she'll be right, haha
Now that i think about it tho i think ill go now and get it repaired..
437345
Reply By: Truckster (Vic) - Thursday, Jun 29, 2006 at 04:56
Air from Chernobyl?
180966
Reply By: Member - Stephen M (NSW) - Thursday, Jun 29, 2006 at 08:26
Yeah carried a can of the stuff around all the time when I had my road bike was called Finnie Leak back then, I remember seeing on the instructions was not a permanant repair and will eventually eat the tyre from inside out, it advised you to change/replace the tyre when available, never used it luckily so cant comment on the way it works good or bad. Regards Steve M
180984
Reply By: F4Phantom - Thursday, Jun 29, 2006 at 09:32
Slime is not temporary you can keep it in for the life of the tyre. They started out with push bikes. I had it in my bike it was good. Recently I had a sidewall leak from hitting a log in the bush at nearly 40km/h. The tyre guy said if he took the tyre off the rim it would ruin the tyre. I wacked slime in it and it sealed right away. I have since let the tyres down for off road and reinflated no probs, I also dive at 100km/h daily, all is fine.
181002
Follow Up By: Member - Andrew (QLD) - Thursday, Jun 29, 2006 at 10:20
and you don't get "the bends"???
437274
Follow Up By: Member - Beatit (QLD) - Thursday, Jun 29, 2006 at 10:26
Not really deep but certainly fast. Probably no bends or face mask!
Kind regards
437275
Follow Up By: Member - Jeff M (WA) - Thursday, Jun 29, 2006 at 12:44
Yeah I was put onto it while
camping with another formite form here, he swore by the stuff. I have not used it yet, but carry it in the tool box. I also have plugs, but I think the purpose of the slime is for bigger holes that the plugs could not fix. Especially sidewall strikes. Apparantly it'll plug a up to a 1/2 inch whole in a sidewall! Dunno how good it is from personal experience, but I figured I'd rather have a bottle in the car than not even if it is only a pipe dream, you never know...
437291
Follow Up By: F4Phantom - Thursday, Jun 29, 2006 at 17:37
it will plug up to 6mm but saying that you got to remember a 6mm steel rod is not going to leave a 6mm hole> slime will not seal a 6mm drilled hole. Good stuff tho.
437403
Reply By: Eric M - Thursday, Jun 29, 2006 at 12:06
I used the green slime in my tyres for about a year, initially put it in all 4 tyres when I did the CSR. Whether it worked on the CSR or not I don't know, when I changed my tyres a few months later there was a couple of spongy bits where a screw and a stud had actually penetrated the tyre. As I fluctuate my tyre pressures quite a bit I hadn't noticed if I had lost any tyre pressure at all. 2 downsides to the green slime. Can't balance front
wheels correctly, 2 tyre dealers I went to couldn't correctly balance the
wheels and when I told them I had green slime in them. You could feel it at about 90Ks, then it would disappear. They said that was the reason. the other downside is that when you take the tyres off the rims, one helluva mess. EricM WA
181019
Reply By: johannagoanna - Thursday, Jun 29, 2006 at 18:06
Revolting Stuff!!! If you have intentions of later taking the tyre off the rim and fixing the puncture later on, then you are in for a gassing indeed. The stuff stinks, and makes a huge mess when you take the tyre off the rim - steer clear!!!
Anyone who has done this will know exactly what I mean!!!
Jo
181075
Reply By: Member - Charlie M (SA) - Thursday, Jun 29, 2006 at 18:29
Slime by name and nature absolute s?it to clean out for repair. if it worked would not see tyres in
shop.
Charlie
181077
Reply By: Gerhardp1 - Thursday, Jun 29, 2006 at 19:15
I used it in 2 tyres, one with a tile chip and one with a screw, bot through the tread, both fairly small holes.
Results perfect, never a problem.
Didn't have to have a balance with it in, could see that may be a problem on some balancing apparatus.
The tyre guys were not happy when I had new tyres fitted, but I did tell them it was there so there were no surprises.
181083
Reply By: Member - Vincent A M (NSW) - Friday, Jun 30, 2006 at 10:58
for small leaks you can use latex number 1 it will seal & is a lot cheaper & being a type of natural rubber is easy to clean out when you get time to do it properly simply peel it out or hose it out
181181
