Hayman Reece Weight Distribution Hitch for 80 series
Submitted: Thursday, Jun 29, 2006 at 21:15
Member - Peter R (QLD)
Interested to learn the model needed for an 80 series to tow a Jayco Freedom 17' .
Pedro
Reply By: cipher - Thursday, Jun 29, 2006 at 21:30
Hayman Reece are a crock,
my dad has an 80 series cruza with hayman reece tow bar hitch,
his car broke down the tow truck hooked onto the tow bar and it snapped straight off, the steel had crystalised... BEWARE!!!
181108
Follow Up By: Muzzgit (WA) - Friday, Jun 30, 2006 at 01:19
That isn't the fault of the towbar mate, it's the fault of the tow truck driver for not using the axle of the car which is what you are supposed to winch a car onto a tow truck with.
437484
Follow Up By: disco1942 - Friday, Jun 30, 2006 at 14:53
WDH is not the same thing as the tow bar.
437568
Reply By: Member - len W (NSW) - Friday, Jun 30, 2006 at 06:52
i have a hayman reese setup on my 80 series towing an 18 ft full van had it for over 5 years now on this van also used it to tow a 14 ft poptop for almost 4 years there is nouthing better in my books for saftey
.............len
181139
Follow Up By: Member - Peter R (QLD) - Friday, Jun 30, 2006 at 07:29
len , what model/weight? is the setup please.
Reason is i have the opportunity to buy one second hand (never used) and before I look at it I want to make sure it will suit my rig.
Unit i think he said was 500 lbs.
Pedro
437488
Follow Up By: disco1942 - Friday, Jun 30, 2006 at 14:54
It is probably the 550 model ie 350kg
437570
Reply By: Wizard1 - Friday, Jun 30, 2006 at 14:14
Give Hayman Reese a call, or send them an email. As the manufaturer they tend to be more of a subject matter expert. You'll need to know your van's GVM and/or towball weight.
www.haymanreese.com.au
181226
Follow Up By: Member - Peter R (QLD) - Friday, Jun 30, 2006 at 14:19
Thanks Wizard.
Great minds think alike I had phoned Hayman Reece and they advise i need the heavy duty model Part nO 74504 and it is 550lb
Pedro
437558
Reply By: dj Patrol - Friday, Jun 30, 2006 at 14:56
I am towing a 18 ft full van with Hayman Reese Bar and Hitch it is a 550KG but all depends on your Ball Weight.Sounds like you need the same.
dj
181233
Reply By: disco1942 - Friday, Jun 30, 2006 at 15:06
It is a good idea to fit WDH. You will have around 200kg pushing down on the ball. This will take off some where in the vicinity of 100kg from your front
wheels (in addition to what you remove by loading behind the rear
wheels.). This will take a lot away from your braking (80% of which comes from your front
wheels) and steering. The WDH restores that weight and so increases the stability of your rig.
If you would like to know more about caravan stability and what hooking a van onto the back can do read,
http://tinyurl.com/2zjhg
It was written by an engineer
181238
Follow Up By: Member - Peter R (QLD) - Friday, Jun 30, 2006 at 16:22
Thanks PeterD and others who replied.
It certainly looks like the WDH is the way to go.
Pedro
437577
Reply By: Ray Bates - Sunday, Jul 02, 2006 at 08:58
I have been towing a 18' caravan with an 80 series for the past eight years. I do not have a HR hitch just a Toyota tow bar fitted with a mini hitch. Works fine. 80 series are heavy enough not to have all that gismo stuff
181422
Follow Up By: Member - Peter R (QLD) - Sunday, Jul 02, 2006 at 09:18
Thanks Ray.
I have been using dual swaybars and have had no problems either.
My main concern is the legality of this on any insurance claim.
Pedro
437762
