Troopy Gearbox Breather Extension
Submitted: Wednesday, Jul 05, 2006 at 11:53
TUFF LUX
Been extending the diff breather hoses on my 92 Troopy up into the engine bay today.
Thought it a good idea to extend the gearbox/transfer breather in the same way but hit a bit of a hurdle. The breather valve on the top of the transfer case doesn't look to be a screw in job like diffs rather it looks to be pressed in.
Does anybody know how to remove the valve in order to fit a hose?
Reply By: STEVE069 - Wednesday, Jul 05, 2006 at 14:00
Hi Tuff Lux, The easyest way i have found is to unbolt the gearbox X-member(with a jack under it) then lower it down. then you can see it , flick the tin cap off with a screwdriver, then grab the top of the breather with vicegrips and put 2 levers under the vicegrips and lever on the same angle as the breather is. Some come out easy some dont ,then you can tap the hole for a fitting or braze a piece of pipe into the breather and put that back in. hope this helps, good luck.
Steve
181939
Follow Up By: TUFF LUX - Wednesday, Jul 05, 2006 at 14:06
Did you use the tap or braze method?
I'm a bit worried about getting swarf from the tap in my box.
also- Is there only one breather for both the transfer and gearbox or have i missed the other one?
438269
Follow Up By: STEVE069 - Wednesday, Jul 05, 2006 at 14:16
Tufflux, if I have the t-case apart I tap out the hole for a fitting, go for the braze method. there is no breather for the gearbox they breath through the gearstick.
Steve
438271
Reply By: Kiwi Ray - Wednesday, Jul 05, 2006 at 14:24
Dip the tap in grease and regrease the tap after two turns. this is a bit slow but will work if care is taken
Ray
181943
Reply By: Member - Nick (Kununurra) - Wednesday, Jul 05, 2006 at 19:53
I usually machine a sleeve that fits tightly into the existing hole and bearing mount it in,never moves or leaks.
181998
