NAVARA ZD30 TURBO NOISE
Submitted: Sunday, Jul 09, 2006 at 23:48
DMECH
Ihave a friend with a navara zd 3o engine ,just started making noise at turbo at slightest exceleration,back off and noise disappears only to reapear at a touch of the throttle. vehicle dosent seem to have lost power. HAS anyone had this problem and what is it??. i was thinking perhaps it might be a leaking ex manifold as i have had this problem on rodeo diesel before.Would appreciate any feed back. THANKS IN ADVANCE DEMECH
Reply By: snow - Monday, Jul 10, 2006 at 09:05
Yes have noticed the same from
mine ('03) like a light whirring or buzzing...dealer was adamant this was considered normal (like they do with any fault in... my experience at least).
Has not proven to be a problem as yet (65000km) time will tell I guess.
182647
Follow Up By: graeso - Thursday, Aug 03, 2006 at 19:25
Might be a bearing in the alternator ??? I thought my whering sound was the Turbo but tracked down, and found it was coming from the alternator, especially when turning the motor off. In a brand new R51 Pathfinder lo and behold, one of Nissans unsuspected surprises, have had them regularly, I could right a book..Graeso
444111
Reply By: Dirty Smitty - Monday, Jul 10, 2006 at 09:47
My Nav does make a noise around the 2200rpm mark, it does sound like an exhaust rattle. Metalic ring/rattle /vibration. I suspect that it may be a loose heat shield/turbo sheild, I will be having a closer look at it today. I also had a similar sound coming from the rear of the vehicle and traced it to the towbar nut wire. I bent the wire so it sat clear of the chasis channel, I could have also used silicon rubber to insulate the wire. I hope that this helps.
I will let you know what I have found and a probable diagnosis.
Regards Smitty.
182656
Reply By: donks1 - Monday, Jul 10, 2006 at 15:41
check egr pipes. fairly common problem. normaly just the gaskets but sometimes the pipe itself is warped
182725
Follow Up By: DMECH - Wednesday, Jul 12, 2006 at 01:30
Thanks donks went out today 20 k to look at navara problem was very obvious one bolt loose [ready to fall out] the other missing alltogether ally pipe in the egr circuit, vehicle only done 112k km,havnt fixed yet waiting for gaskets ex e/states .
THANKS FOR INPUT DEMECH
439585
Reply By: snow - Tuesday, Jul 11, 2006 at 08:21
cheers D1 shall do
182878
