Fixing damaged fuel tanks
Submitted: Monday, Jul 10, 2006 at 11:07
Buffer
Could someone give me advice on if there is a product that can be used to do an emergency repair on a damaged fuel
tank, hopefully I will never have to do it, but it pays to be prepared. Thanks Pete
Reply By: Moggs - Monday, Jul 10, 2006 at 11:17
Question is....will you ever really "Kneed-It"? ;-)
182670
Follow Up By: Buffer - Monday, Jul 10, 2006 at 12:04
Thanks Moggs will give it a go.
439107
Reply By: Robin - Monday, Jul 10, 2006 at 11:19
Don't know the name of it Buffer , but there certainly is and it does radiators as
Used it a lot on spot rusted tanks, widely available , think its a 2 part mix.
Mine from Supacheap
Robin Miller
182671
Follow Up By: Buffer - Monday, Jul 10, 2006 at 12:06
Hi Robin, Moggs suggested kneedit, that is what you may have heard about.
439108
Reply By: Pedirka - Monday, Jul 10, 2006 at 11:33
Think I've heard that for a tempory emergency fix, on something small that you can use soap, pussed into the leak?
Can anyone else verfy that?
I have used the product called 'Kneed it'. Works ok.
182673
Follow Up By: Buffer - Monday, Jul 10, 2006 at 12:07
Tried soap about 30 years ago on a petrol
tank not sure how it would go on a deisel
tank
439110
Follow Up By: Mazdan - Monday, Jul 10, 2006 at 15:38
Yep I have had to use soap in the past, hmmmm, about 25 years ago actually on a mini coming back from
Perth.
I just took a bar and rubbed it into the crack and it worked a treat.
From memory needed a new rub every few days.
439157
Reply By: Geoff (Newcastle, NSW) - Monday, Jul 10, 2006 at 11:39
Soap and Bulldust, mix with
water into a paste. Trowel it on.
Les Hiddins recommends Spinifex Resin. Melt it in a tin over a fire and trowel it on.
Geoff.
| Geoff,
182674
Follow Up By: Buffer - Monday, Jul 10, 2006 at 12:09
Gday Geoff, saw Les use the spinifix method to seal a
water container suppose it would work on fuel
tank, and your are dead right about the
grey hair.
439111
Reply By: STAN - Monday, Jul 10, 2006 at 15:22
Drove a petrol tanker for 25 years in a previous life.[now retired] . Part of my kit was a bar of velvet soap. Rub the bar into the break whilst the fuel is p.....g out. Bingo fuel leak stops . Couple of applications daily until a more effective repair can be made. Kept a tanker going for 10 days once , until my holidays came up,then I told the boss about it. No overtime when the tanker is in for repairs.
Stan
182718
Reply By: Member - Jeff M (WA) - Monday, Jul 10, 2006 at 15:39
I heard a neat trick the other day, you get some two part epoxy and mouldit into a round spear type shape, let it set and hammer it in, followed by some good gaffer tape for re-enforcement and it's supposed to be good.
182723
Reply By: Member - Oldplodder (QLD) - Monday, Jul 10, 2006 at 15:40
Always found Minties work the best, the white sweet. Give them a little bit of a chew first to soften them up, then push them in. OK if they have been sat on the dash in the sun for a couple of hours. Dry as hard as a tack and seem to stick
well to a fuel
tank, even with petrol present. Found they work better than the 2 pack putties, which don't seem to stick to fuel tanks that
well with petrol present.
Yes, there is a personal story of split fuel tanks behind this knowledge. :-(
Oh, and have a bit of steel wool or scourer handy, good to clean the
tank first for a good bond.
182724
Follow Up By: Member - Beatit (QLD) - Monday, Jul 10, 2006 at 15:51
G'day Oldplodder,
I suppose this would work for
water tanks as
well and it would be a food qaulity fix even if it gives the
water a slight mint flavour.
Kind regards
439159
Follow Up By: Member - Oldplodder (QLD) - Monday, Jul 10, 2006 at 20:27
Good one,
Hadn't thought of it before.
As long as you don't chew it first :-)
439235
Reply By: ferris - Monday, Jul 10, 2006 at 16:02
A welding rod??
182731
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 16:15
Great suggestion. Welder going of course? You can do it
well away from the vehicle.
Hope no one would try it.
439172
Follow Up By: ferris - Monday, Jul 10, 2006 at 16:23
I've seen a few diesel tanks welded with just the fuel emptied out, and fire extinguisher handy. Petrol.... we'll let somebody else weld that. lol.
439176
Follow Up By: extfilm - Monday, Jul 10, 2006 at 19:09
I watched one of my old bosses weld up my fuel tanks when I was an apprentice after a reckless driving episode I had once...... There was a massive split in the tank after I hit it on a storm
water pit...... I could not believe he did it, and it was a petrol tank.
439207
Follow Up By: Member - Barry C (NT) - Monday, Jul 10, 2006 at 23:46
yep some old timers used to weld full petrol tanks NOT 1/2 full and survived, I've seen it twice. Some didn't survive tho.
I used to work on fuel tankers Avgas and Avtur - saw safety films of a guy walking along the top of 45,000 litres of petrol with a torch - he lit all 6 sections of the tanker with top hatches open, threw the torch to the ground and walked back along the tanker and shut the hatches - no fire, BUT this was because it was full.
Baz
439325
Reply By: Ole Grizzly - Monday, Jul 10, 2006 at 19:20
Too easy...if your tank requires welding, then extend a flexible pipe from exhaust pipe into the empty fuel tank. Run engine at a fast idle for a few minutes to displace any oxygen from fuel tank, then leave it idling still in tank whilst welding...have done this several times with both petrol and diesel..Very Safe..
182767
Reply By: 3F62 - Monday, Jul 10, 2006 at 19:25
I've done the minties thing on a petrol that did the trick (If the kids leave any in the bloody glove box) also used a self tapper screw & peice of garden hose on the same job to get us
home.
182768
Reply By: bgreeni - Monday, Jul 10, 2006 at 23:37
Have used both soap, and powdered milk mixed to a thick paste.
182844
