Gu Series 4 Uhf instalation
Submitted: Tuesday, Jul 11, 2006 at 13:29
ThreadID: 35727 Views:1894 Replies:4 FollowUps:2
I want to instal a Gme Tx 3400 remote head uhf but with the new dash & console layout i dont know where to mount the remote head any ideas.
Vehicle is a 2006 Gu Wagon
Dave T
Reply By: joc45 - Tuesday, Jul 11, 2006 at 13:51
Not sure if this helps, but in my GU-I, I have mounted the head where the ashtray is. I removed the ashtray, made up a dummy panel to replace it, and mounted the 3400 head (along with the HF head) on that panel. I fed the wires thru underneath. Both displays are quite easy to read in that location.
This also means that when I sell it, there are no screw holes to contend with. I just replace the ashtray.
Gerry
AnswerID: 182926
Reply By: Truckster (Vic) - Tuesday, Jul 11, 2006 at 13:51
Dash pod
roof console.
side of the console near the gear shift
AnswerID: 182927
Reply By: joc45 - Tuesday, Jul 11, 2006 at 13:52
Gerry
AnswerID: 182928
Follow Up By: joc45 - Tuesday, Jul 11, 2006 at 13:54
bloody wifi connection!!!
FollowupID: 439398
Reply By: geocacher (djcache) - Tuesday, Jul 11, 2006 at 23:40
I just did a mates. Moved the sub tank switch down onto the switch console next to the shifter. (Just enough length on the wires if you try it.) Then I put the head infront of where it and the other blanking switch cover were.
The tx/rx wasn't hard but I can't exactly remember where i put it. Drivers side footwell from memory.
AnswerID: 183078
Follow Up By: Troop-a-dour - Thursday, Jul 13, 2006 at 13:26
G'day geocacher
If it's OK..would you contact me off forum at:
op(dot)support(at)tsn(dot)cc
Troop-a-dour
FollowupID: 439862
