GU Patrol Starter Motors
Submitted: Tuesday, Jul 18, 2006 at 12:10
ThreadID: 35933 Views:6764 Replies:4 FollowUps:0
Has anyone had any experience of starter motor failure on petrol GU Patrols, and if so, are they repairable? I believe its the solenoid on mine, which my local Nissan dealer tells me is not available, which is believable as this is also common with Toyota starter motors.
Any advice would be appreciated, thanks in advance
Chris
Reply By: 1arm - Tuesday, Jul 18, 2006 at 13:06
Hi Chris
I have a 2000 GU petrol (On gas)
I recently had to replace mine after 135000 kms.
The auto electrician was going to repair it but it was beyond repair.
I had just completed a 10000km trip from Perth to Canberra and back and everywhere in between without any dramas.
2 weeks after I got home it wouldnt start. I hadnt had any trouble starting on the trip but the sparky said it was quite badly burnt out.
So I still have no idea why it happened.
Evan
AnswerID: 184071
Reply By: donks1 - Tuesday, Jul 18, 2006 at 14:55
y61 starter motors are serviceable however the problem may be local availability
even if ex japan wait should only be 4-5 days. nissan have the best v.o.r system i've seen. they will air freight anything at no extra cost to you
AnswerID: 184078
Reply By: Chris L (Qld) - Tuesday, Jul 18, 2006 at 16:44
Chris Uren
The internals let go on mine at about 120000km. Auto electrician unable to source replacement parts, genunine or otherwise to repair. Was not prepared to pay the Nissan price for a new replacement or wait for it to be delivered from way down south so obtained from a local auto electrical wholesaler a Chinese copy that has now done 50000km with no problems. Similar story with alternator. In this case have now had fitted a Bosch alternator (looks similar to original) as used on recent Falcon after modifying lower mounting bracket. Also has a slightly higher output than original. Should be able to obtain replacement parts for this alternator pretty well anywhere if it becomes necessary.
Chris L
AnswerID: 184091
Reply By: 120scruiser (NSW) - Tuesday, Jul 18, 2006 at 20:42
Chris
I have only had one come through my workshop.
It was polling and totally burnt out, unrepairable so I sourced a new one from my local auto electrician. Haven't heard back from the customer so must be OK. They soon let you know if there is a problem.
Hope this helps.
120scruiser
AnswerID: 184145
