RP7 started my diesel - but why?
Submitted: Friday, Jul 21, 2006 at 18:46
ThreadID: 36045 Views:6304 Replies:6 FollowUps:6
This morning I had not started my diesel since a cold 0 degree morning. Anyway it cranked fine, plenty of battery and engine speed but it just would not start. After a very long time of continous craking and retrying it was clear something was wrong and it was never going to start. So I got the RP7 (WD40 or whatever brand) and sprayed the engine bay around the fuel system, I also sprayed into the snorkel. Anyway, she started like a petrol engine first crank!! WHAT?? Can anyone explain in a chemical/physics sense what happened?
Reply By: Notso - Friday, Jul 21, 2006 at 18:51
WD40 is a hydrocarbon compound, it also probably uses LP gas as a propellent. I'm too lazy to duck out to the garage to check.
AnswerID: 184701
Follow Up By: Notso - Friday, Jul 21, 2006 at 18:52
OOPs I mean RP7, same sort of stuff
FollowupID: 441421
Reply By: Exploder - Friday, Jul 21, 2006 at 19:04
WD40, RP7 all that stuff is the >
Same as “Start Ya basted” or Aerostart It’s a hydrocarbon
Another one I have heard was Primer “T” loctight being used> was told that one by a hydraulic fitter who used it a few times on cold mornings on mine sites.
AnswerID: 184702
Reply By: Bros 1 - Friday, Jul 21, 2006 at 19:28
F4Phantom,
Nothing wrong with a burning rag held near intake as a last resort. (diesel)
Bros.
Work is the curse of the down and out bludger.
AnswerID: 184709
Follow Up By: F4Phantom - Friday, Jul 21, 2006 at 19:52
I am guessing if your glow plugs are bad this will solve that problem. I changed my plugs a year ago, i suppose they could be up for another change.
FollowupID: 441431
Follow Up By: Truckster (Vic) - Friday, Jul 21, 2006 at 23:56
your glow plugs are 12 mths old, they wont need changing for another 5 years....
the GQ ones are original, and thats a 91 model
FollowupID: 441464
Follow Up By: F4Phantom - Saturday, Jul 22, 2006 at 00:13
When I put the plugs in new the engine started on a cold day first time like a petrol, now it cranks a bit which is why I was thinking they could be hammered. This post is different than just normal cranking, the thing was never ever going to start in a billion years of cranking.
FollowupID: 441468
Follow Up By: G.T. - Monday, Jul 24, 2006 at 17:26
A rag which has been wetted with petrol ( not soaked or sopping ) held to the air intake will achieve the same effect. I was waiting for new glow plugs to arrive for my `94 2.5 Triton and did this in the morning each day. It started during the day with no problems after it had warmed up. My lawnmower petrol supply suffered though! Regards G.T.
FollowupID: 441794
Reply By: Member - Bruce and Anne - Friday, Jul 21, 2006 at 20:33
If you have to use aero start a lot and it is not the glow plugs than you might need to talk to CEM ( Cost Effective Maintenance) there advertisers here. There product has worked for me in a marine deisel that was hard to start and would not rev out to what it should have.
AnswerID: 184716
Reply By: blown4by - Friday, Jul 21, 2006 at 22:16
Many of those type of sprays that are used to free up frozen bolts, etc contain a percentage of diesel fuel so that is why the engine would have started. Straight diesel fuel free's up frozen bolts just as well but paying a lot more for it in a pressure pack can makes us feel better. Aerostart has ether in it hence the need to use it with extreme care and only when the engine is cranking.
AnswerID: 184736
Follow Up By: pilbaradisco - Saturday, Jul 22, 2006 at 00:00
We use a whole can of Aerostart to start the Diesel electric locomotives (GE Dash 9's, V16 4400hp) at work when they have flat batteries or after a full injector change.
Glen.
FollowupID: 441466
Reply By: Aandy(WA) - Saturday, Jul 22, 2006 at 00:16
Mechanics used diesel to do the things that wd40 et all do long before someone thought of marketing it in a user friendly spray can. That's why it helped to start your engine. Make sure you wait for the glow plugs to warm up before cranking too.
AnswerID: 184752
