re installing co-piloto on pda
Submitted: Sunday, Jul 23, 2006 at 09:48
djrziggy
Can anybody help with instructions on re installing co pilot live back on to my pda (asus 632). I was having problems with the programme opening so I deleted the program but now I cant re install it. Tried the travroute web site but that didnt help. tried to ring the help line no answer.Can somebody please help I am pulling my hair out.
Darren
Reply By: The Explorer - Sunday, Jul 23, 2006 at 10:05
I found this on their website - it is for the installation of a upgrade "patch" - but may be same method or inititial installation. The only other way would be to make sure PDA is connected to PC (via Acitivesync) and run the installation program from PC (thats how a lot of other PDA programs install) - but try method below first.
Make sure that your Pocket PC is connected to your Desktop/Laptop and make sure Activesync says "Connected".
On your desktop find the file you saved, Right click on it and select Copy.
Open the Activesync window and click on Explore.
Next double click on My Pocket PC.
Next double click on My Documents.
Next Right click anywhere in the My Documents window then click Paste. This will copy the patch file and save it to the "My Documents" folder on your Pocket PC.
Once the file has been copied down to your Pocket PC, disconnect your Pocket PC from your laptop/desktop.
On your Pocket PC, go to Start >Programs > File Explorer > My Documents.
In the "My Documents" folder, you will see the file that you just copied over from your laptop/desktop. Tap on this file to start the installation. When the installation starts, you may be warned with this message "CoPilot is already installed! Would you like to reinstall?" Click Yes to reinstall CoPilot. You may also be asked, "Do you want to replace these files?", Click "Yes to All" to install all the update files.
NOTE: Once the software has been installed, the .CAB file should automatically remove itself from your Pocket PC.
184873
Follow Up By: djrziggy - Sunday, Jul 23, 2006 at 10:51
Greg thanks for the info, just tried this, it installed but now it is telling me that it is unable to open co pilot. please make sure the storage card is inserted or that the data has been downloaded properly
441594
Follow Up By: The Explorer - Sunday, Jul 23, 2006 at 11:01
Sorry - no idea - have a look at these - one may be relevant.
Site Link
441596
Follow Up By: Richard Kovac - Wednesday, Jul 26, 2006 at 23:19
Off topic, but just got your latest DVD's Very good thank you.
any time frame for a Goldfields version?
Richard
442326
Follow Up By: The Explorer - Friday, Jul 28, 2006 at 17:59
Hello Richard
Goldfields....after
Pilbara 50K which is next on the list (ready for Christmas). There is no 50K mapping of Goldfields - so it will be 100K - may do it as 3 or 4 separate DVDs..but maybe not... should have something happening this time next year.
442802
Reply By: Frank_Troopy - Sunday, Jul 23, 2006 at 10:43
If you connect via activesync to the computer that you originally used to install the software you can click tools -> add/remove programs in the Activesync program. You should see the list of programs you have installed. If you click the box next to copilot then you can reinstall it, presuming it hasn't been deleted from your PC.
Good luck.
Cheers Frank.
184879
Reply By: Member - AVA 191 (QLD) - Monday, Jul 24, 2006 at 21:36
Hi Ziggy,
If u r still stuck, this may help -
I tried these guys when I got stuck with
mine once:
www.ja-gps.com.au/index.htm
There was a small charge cos' I didn't buy it from them, but the guys I spoke to knew their stuff.
185114
Reply By: Trevor R (QLD) - Monday, Jul 24, 2006 at 22:02
gpsaustralia.net is a website with
forum like this that you can ask Q's in, if they can't help no one can.
I run co-pilot but have never had to reboot it.....yet ;-))).
Trevor.
185122
Reply By: djrziggy - Tuesday, Jul 25, 2006 at 08:41
Thanks guys for the info, I finalyy got onto travroute helpline and the guy there guided me through it and eventually after aquite a few hours mucking around I now have it working again. If anyone needs help in the future the number to ring is
Travroute support (03) 5871 7973.
Darren
185162
