gu patrol electric fuel pump..
Submitted: Monday, Jul 24, 2006 at 21:40
ThreadID: 36129 Views:2777 Replies:1 FollowUps:8
in regards to the post number 35664. i have a gu 2.8 and have fitted fuel flo electric pump. There is a good noticable increase throttle responce. Acceleration is a lot better too. On the high way it performs better and dosnt use as much boost, so the economy has improved also. over all it was a great mod. when i fitted the pump i put it after the fuel filter, this was done because the pump has a built in 50 micron filter but it is a sealed pump. not sure how u would go if it got clogged up..
Reply By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 12:59
What sort of $ are the pumps worth. After reading the post on the 3.0l pump going, I might plumb in a pump down near the fuel tank and put a CAV filter in somewhere. I think the 2.8 has it's fuel return hose going into the filter not into the tank, (I was once told this is not good, as the pump heats the fuel a bit, and if it keeps circulating it will get warmer and warmer, compared with being allowed to cool a bit in the main tank). Does anyone think this will be a problem if I fit an electric pump down near the tanks which in this case will not have any pressure release! (apart from the fuel the car is using)
Cheers Andrew
AnswerID: 185220
Follow Up By: Flash - Tuesday, Jul 25, 2006 at 14:23
I've been running an electric pump ("Facet" brand with output about 5psi) near the tank for years now.... and a Frantz (toilet roll) fuel filter for many years on my TD42.
Outstanding results, and the toilet roll filter has to be the perfect filter filtering down literally to a micron or two. (it's upstream of the factory filter, which never sees any dirt at all.)
FollowupID: 441975
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 14:28
Does the 4.2 return fuel to the tank or back to the filter? I might do google on the Facet
Cheers Andrew
FollowupID: 441978
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 14:56
Andrew,
Return is back to the tank. I too have a Facet pump fitted recently. They're about $80- to $100- and only push about 3 to 5 psi.
Roachie
FollowupID: 441983
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 15:15
Looking at a website & they have a pressure relief valve so the fuel return may not be a problem for me.......just how noisey are they & what model did you get
Cheers Andrew
FollowupID: 441987
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 16:24
The one I got is a 594 from memory. I've fitted it to the side of the chassis rail, right under where I sit. It is mounted on rubber buffers and I can just barely hear it before I crank the engine over (waiting for the glow plugs to do their trick). After start up, no can hear at all.
FollowupID: 442010
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 16:33
Sorry....it's a 574.
Check out Post number 34,343 for some more info. Also, type in "Facet" to the search at the top of the Forum page and you'll get a lot of info.
FollowupID: 442012
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 16:41
Thanks for the info, I'll do a bit of searching around
Cheers Andrew
FollowupID: 442016
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 17:50
Bit of searching around, $100.00 delivered to KNX. Will check the locals tomorrow to see if they have anything similar priced.
Thanks for the advice
FollowupID: 442042
