Help with new vehicle for Mrs
Submitted: Tuesday, Jul 25, 2006 at 14:38
Ron173
My wife has a SWB petrol Pajero, and loves it to bits.
Its getting bit old now though and she needs to update it. If they still made em she'd buy a new one. They dont. (
well not in Oz, can get one imported from South Africa for a fortune!)
Were searching for a suitable replacement but have a few prerequisites which eliminate most of the market.
Firstly, she cant drive larger vehicles comfortably nor
park them, so SWB size perfect.
Needs to be able to tow 1000kg comfortably (boat or caravan both weigh similair)
Needs to have low ratio to recover other vehicle if bogged launching/retrieving boat. (this eliminates vitara / rav4 / xtrail type of soft off roaders)
Any good serious suggestions?
Ron
Reply By: Member - MrBitchi (QLD) - Tuesday, Jul 25, 2006 at 14:42
Challenger? Not much bigger......
185232
Follow Up By: disco driver - Tuesday, Jul 25, 2006 at 14:47
Old as in decrepit & rusty or Old as in high mileage.
Might be worth considering a full rebuild rather than a replacement if it's old as in high mileage
441980
Reply By: Member - Craig D (SA) - Tuesday, Jul 25, 2006 at 14:42
Pathfinder?
185233
Reply By: Robin - Tuesday, Jul 25, 2006 at 15:02
Hi Ron
Doesn't eliminate Vitara (grand) , has low range , not bad either.
We recently went thru that senario at Xmas and brought A RAV4 runout model, the last RAV with true 4wd.
Took the new Suzi into bush and it wasn't bad but on balance we found that the RAV4 was better, and got auto for towing and the odd recovery. (bit hard on transmission -but it does do it.)
Robin Miller
185236
Reply By: Truckster (Vic) - Tuesday, Jul 25, 2006 at 15:04
My GQ Diesel Auto would be her best bet.. going cheap too :)
185238
Reply By: strzelecki - Tuesday, Jul 25, 2006 at 15:29
The racv has a comparo test on 6 smallish 4wd vehicles.
Subaru forester came up
well,tows 1400kg and comes with low range in the manual.
185242
Reply By: PBob - Tuesday, Jul 25, 2006 at 16:28
A Forester might be too small, but the manual ones have low range boxes.
185250
Follow Up By: disco driver - Tuesday, Jul 25, 2006 at 17:42
The Forester is a great little wagon, I had one prior to buying the TD5 Disco.
True, the manual has low range but it's not a very big reduction from High range, somewhere around 1.3-1.2:1 if I remember right.
Still it's a fabulous vehicle for gravel roads and good dirt tracks with a reasonable towing capacity as
Disco
Another thought but expect a heap of adverse feedback for suggesting it is a
late model Landrover Defender 90 Extreme.
442038
Reply By: TAS PAJ - Tuesday, Jul 25, 2006 at 17:19
Not sure how much you want to spend but the Forester is a great car. Maybe even the turbo model if you want some go. I think they both have low range gearing
185260
Reply By: PBob - Tuesday, Jul 25, 2006 at 17:51
Disco driver, great to see you have now one of the best. My wife owns the manual Forester, I am on my 5th disco, having had a series 1 V8, then 4 TD5s (the last an HSE manual) and now have the latest HSE TDV6 auto which is just brilliant. At 2500 revs it is doing 150km. 6 speed box and is just the best design you can imagine. This will be the forerunner of all new model 4 wheel drives built from now on. Pretty expensive, although you can really work on a good deal. (As with most new cars, do not take the list price as anything more than a start point.
185266
Reply By: silverback - Tuesday, Jul 25, 2006 at 19:20
My wife drives Jeep Cher limited
loves it to death great to
park
great towing cap heaps of grunt?
185282
Reply By: Ron173 - Tuesday, Jul 25, 2006 at 19:29
Thanks for all the replies,
Its old as in high km,
well for petrol anyway, got bout 220,000 on it now, bit of play in diffs etc, clunk if not very careful with clutch.
I explained the rebuild, would need transmission worked over, and prob recon donk, that would cost prob 2-3k for trans and bout 4k donk, shes bit scared to spend 7k on it, tried to tell her itd be like new..... women know otherwise.
Body quite good, no rust, but it previously lived on Fraser Island and had heaps of sand in when we got it. I think it'd prob be easier to trade it.
Challenger... Pathfinder, wheelbase too big, same as Trucksters, she likes the Paj SWB as time after time she sees fourbies trying to get into spaces in town, and giving up and driving off, she then nips in with paj no trouble. Its just small nippy agile, and with full diff locks, a very serious off road vehicle, not to mention all the gadgets on it, its GXL? I think.. adjustable shocks from cab etc
Might need to try get her to see sense in spending dollars on it
Might look at that racv comparison though.
Thanks for input
Ron
185284
Follow Up By: Member - Bruce and Anne - Tuesday, Jul 25, 2006 at 19:35
What about the import Paj with the turbo diesel (only come in soft top thpught)
442063
Follow Up By: Member - Pesty (SA) - Tuesday, Jul 25, 2006 at 23:29
Hi Ron,
You dont say how old it is, but my father in law had a 2.6 petrol one, LWB, but same, in the old square model, 86, and he had g/box brgs done and it did 430,000 with very little other repairs, nothing to engine other than servicing, and he towed camper and caravan all over this country to all the roughest
places you could imagine.
If you like it have any repairs done that need doing and just drive it into the ground, as its worth nothing, and repair as needed, rather than preventative repairs.
Or keep your eyes out for a real good one with lower k's and buy it when it comes along.
Cheers Pesty
442115
Reply By: angelflake - Tuesday, Jul 25, 2006 at 20:12
How about the baby Pajero the "IO", I have one for sale in the trader section !
185295
Reply By: Trevor R (QLD) - Tuesday, Jul 25, 2006 at 20:34
Does Kia still do the Sportage with a low range?? if not a 2 or 3 yr old Sportage would have the low range. Would fit the requirements of towing and size just not sure of asthetics as that is something only you can answer.
Cheers, Trevor.
185299
Reply By: Member - Stephen M (NSW) - Wednesday, Jul 26, 2006 at 09:16
Hi there Ron, you say this eliminates viitara, whys that ?? They have a low range that is probably better then some of the others, I know my 2litre vitara had a tow range of I think 1100kg ( I think ) for memory, I know I towed my inboard ski boat behind it and it was 1230kg. Maybe I was over the tow limit (possible) ??. I cant remember the exact tow weight but wouldnt be hard to find out. They are a top 4wd, just on 100kw of power my wifes was a 5 speed manual great on fuel 9L per 100 on the open road, great air con, didnt struggle towing the boat with air on, yes you knew it was there but no drama's ever. Just a thought. Regards Steve M
185370
Follow Up By: strzelecki - Wednesday, Jul 26, 2006 at 17:38
According to the racv test,vitara 2 ltr has a tow capacity 1850 kg braked and 750 without brakes.May be higher with the 2.7 ltr v6 donk ?
442249
Reply By: kerriek - Wednesday, Jul 26, 2006 at 18:41
Hi guys,
This is my car we are talking about here. I do SOOOO love it!!!
It is a 1993 NJ top of the range job. Power tinted windows, sun roof, HUGE tyres, electric arial, every button you can think of and it has a big pipe on it and sounds really cool.
The paint work is good, there is no rust to be seen. The interior is in good shape too. When we bought it a year ago I found a
well used map of Fraser Island in the pockets on the back of the
seat. The screws that hold down the trim inside have surface rust on them and there was a little bit of sand around too.
It has 208,000 on it. I did the timing belt at 200,000 and it has 2 year old shocks. It does clunk if you aren't carefull with the clutch and it is burning oil. I (husband)changes the oil every 5,000 since timing belt.
I love this car because: I am 5 feet tall and it means I can see past the bonnet and reach the passenger door. I dont feel lost in it. I drove a Patrol wagon once and felt like I was at the helm of
HMAS Sydney!!!!
The seats are versatile and offer loads of space for pram and shopping (10yr and 18 month old sprogs).
I can
park it ANYWHERE!!!
It LOOKS mean with it's big wheels and it is unique to my town. There are only 4 in town, none of them as mean as
mine!
It sounds great!
It hauls arse.
It hauls the caravan no worries ( I haven't been allowed to tow the new Quinnie yet (:) .
The only other new car on the market that appeals to me is the Jeep Cherokee. A bit out of the price range (see new Quinnie:)
Ok so thats the situation.
Please let me know any more of your thoughts, I appreciate them.
185439
Follow Up By: Doggy Tease - Wednesday, Jul 26, 2006 at 22:44
From thesound of it, you will be hard pressed to find a replacment car that would live up to the NJ. Honestly, the best thing, IMHO, would be to spend the money on fixing what is wrong with it, and getting another 5-10- years good service from the ole girl. The red book value on something this old may not be very high, so using it as a trade on a new(er) car would probably end up not worth it either.
meow.
rick.
442319
Follow Up By: strzelecki - Thursday, Jul 27, 2006 at 12:24
The hyundai terracan may be a contender,size and power would fit the bill.
I notice in the jd power quality study in the US Hyundai are now 3 rd in the quality ranking ahead of toyota and honda.
442417
Reply By: Member - Phil G (SA) - Thursday, Jul 27, 2006 at 10:28
Hi Ron,
We went thru exactly the same as you a few months back. My wife ended up with the Xtrail because it has 2000kg tow capacity (500kgs more than any of the equivalents) and the manual had a reasonably low 1st gear (3.416), and I wanted the 132 Kw that the 2005 models had. Would have loved it to have a low range, but many of the low range transfers in these vehicles are not as low as your old Pajero.
My only other thought is the 90series Prado (up to 2002) which are a very easy vehicle to
park because they are skinny. They have depreciated quite a bit lately, so are better priced 2nd hand now. The old 2.7 can be bought for a song.
185551
