Roof Tents
Submitted: Tuesday, Jul 25, 2006 at 20:15
ThreadID: 36155 Views:8096 Replies:8 FollowUps:8
I am thinking of buying a roof top tent. It must have a Queen size bed.
Any suggestions and comments?
Reply By: Des Lexic - Tuesday, Jul 25, 2006 at 21:51
Shippshape overall size is 2100 x 1500 I'm 185cms and have plenty of room for a couple. Check out their website and they are based in Sydney. Very happy with ours. Had it about 3 years and have spent about 7months in total use in that time.
AnswerID: 185311
Reply By: Truckster (Vic) - Tuesday, Jul 25, 2006 at 22:03
Why must it have a queen size bed?
AnswerID: 185317
Reply By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 22:53
I am sure I have seen that you can hire these - good way to try before you buy. We have a home made one (not by us) and we're very happy with it. It can be a slight hasstle if we want to go for a bit of a day trip, but itsonly a 4 min job, so no big deal. Its very comfortable to be in a full size bed up away from the ground, just a bugger I end up in the tent with the kids most of the time.
Cheers Andrew
AnswerID: 185329
Follow Up By: Steve - Wednesday, Jul 26, 2006 at 08:21
Aussie Traveller is the answer ..best roof top tent in the market ..had one for eight years and it was the best unit I could get and I looked at everything available...it also seemed at the time to be the least expensive..
FollowupID: 442144
Reply By: Member - Coyote (SA) - Wednesday, Jul 26, 2006 at 08:26
Are you commited to one? I don't want to put a dampeneer on the idea and a lot of people like them and all but they have down sides..
I spent three weeks travelling through Africa with one and although convenient for quick sdet up and all, they are no good once it rains.. the first time it rains the canvas gets wet. no owrries, but as soon as you pack it up.. all your bedding and everything inside is against wet canvas and next night everything is wet of course. Furthermore, unless you have rock hard suspension, they can get a bt of a sway up when you are getting in /out. No big deal on your own, or in the morning etc, but if one of you wants to stay asleep?? And finally. Can you always park your car perfectly flat at every camping spot??
At least with a quick set up tent/CT you can put it where you want it and it doesn't move. Just something to think about.. Oh, and you can stand up in them..
AnswerID: 185362
Follow Up By: PGK - Wednesday, Jul 26, 2006 at 10:28
Hi all,
Great site - first post from me...
I've also been considering a roof-top tent and currently, I'm leaning towards something with a hard roof that you pop-up when it's time to sleep.
Packing up for a day-trip would be a similarly quick pop-down process and hopefully the hard top would minimise the wet canvas wetting the bed (so to speak!)
Interested in peoples thoughts on such a set-up. I'm not referring to any particular brand or model, just the principle of the thing at this stage.
One silly issue that swag users may have already solved - when it's wet & muddy, where to people typically put their coat & boots so that they're not in the rain and also not wetting/muddying the bed?
Thanks & Regards
PGK
FollowupID: 442164
Follow Up By: draff - Wednesday, Jul 26, 2006 at 10:39
PGK,
see my response below regarding hard top roof top tents. Fantastic in my opinion.
boots just went on top of the back wheel to keep dry.
FollowupID: 442165
Reply By: Member - Omaroo (NSW) - Wednesday, Jul 26, 2006 at 08:26
If you're tall - then an EeziAwn is longer than the ShippeShape. They are 2,440 vs, 2,100, and are still 1,440 wide. That's 8cm longer than a queen size bed, but 4 cm narrower. At least you can peel off your clothing and have room to throw it at the base of the bed and not hit it.
AnswerID: 185363
Reply By: draff - Wednesday, Jul 26, 2006 at 10:37
We just got back from 6 weeks travelling the cape and gulf with the in laws who used a roof top tent (we used a swag). Unfortuntely i can't remember the brand (made in south africa i think) but it was a hard top tent (looks similar to those plastic roof top storage pods) and to assemble all they did is push up one end. It took them less time than it did for us to set up the swag! We watched quite a few people setting up the traditional style of roof top tent and they seemed to take an awfully long time to set up and pack up.
We were rained on every day for 2 weeks on cape york and they never had any problems with water getting in or the canvas getting their bedding wet (probably because the only canvas is the sides and one end). However, they did have one camp area where they had to drive up on a rock to get level.
I'm not sure on the size of the bed but it might be worth investigating this style of roof top tent for sheer ease of setting & packing up.
AnswerID: 185381
Follow Up By: Member - Omaroo (NSW) - Wednesday, Jul 26, 2006 at 11:28
The Hannibal "Impi" and Autohome "Columbus" are probably the two you are referring to. They are a great unit, but they also cost around the $3,500 mark - which certainly 'aint cheap....
FollowupID: 442173
Follow Up By: Waynepd (NSW) - Wednesday, Jul 26, 2006 at 12:38
Howling Moon is another Sethh Effrican roof topper i believe
FollowupID: 442183
Follow Up By: Member - Omaroo (NSW) - Wednesday, Jul 26, 2006 at 12:43
That's right Wayne
Difference between the Howling Moon and the EeziAwn is that the EeziAwn has a marine ply base whereas the Howling Moon is sandwich aluminium/foam. I think I'd rather the wood as it may not separate as easily, but I might be wrong there. The other difference is in the packing bag. The Howling Moon zips up front to back, which means that if you leave a little too much bedding up there it can be very difficult to close the zips. The EeziAwn has a belt tensioner which just takes up whatever slack there is - whether you leave stuff up top or not.
FollowupID: 442184
Follow Up By: Waynepd (NSW) - Wednesday, Jul 26, 2006 at 13:16
Thank you Omaroo,
I saw the howling moon when i went to open sky in Camperdown to look at the Jurgens Xpedition and Oryx campertrailers, also from SA.
I wasn't impressed with them much compared to my Shipp Shape.
Looked a bit small and claustrophobic for my taste, but each to his own i guess.
I haven't seen the EeziAwns first hand but I will look out for them next show i go to....
FollowupID: 442188
Follow Up By: Kiwi Kia - Wednesday, Jul 26, 2006 at 15:03
Have you seen the type of roof top tent on the Zelt Cruiser (100 series toymotors) as used by 4wd Hire Service (www.4wdhire.co,.au). I have used these for over a month and found them great. I have heard that 4wd Hire Service will dispose of all these vehicles by March next year, don't know if the tents will sell seperately but the company has very large number of these vehicles spread around Australia.
FollowupID: 442213
Reply By: Muzzgit (WA) - Wednesday, Jul 26, 2006 at 21:10
One consideration to keep in mind is that you both need to be physically capable of climbing a ladder to get into/out of bed. This one aspect of the rooftop put me off, as Jaqcui has bad eyes without her glasses and she finds ladders/rocks/steps very difficult.
We've removed all the rear seats in the patrol and have a mattress and curtains in the back for sleeping, and everything goes in on top for travelling.
AnswerID: 185473
Reply By: Muddy doe (SA) - Wednesday, Jul 26, 2006 at 21:21
Hiya PajMan,
If you are in South Australia then Opposite Lock at Mile end have an Eezi-Awn rooftopper that they hire out. They have various bars and adapters to get it to fit most roof rack setups. I looked at this option on the Prado but went with a swag in the end.
Now we have a Carry-me Camper that we tow on a box trailer. Excellent!
Muddy
AnswerID: 185475
