Chambers Pillar/Maryvale
Submitted: Tuesday, Jul 25, 2006 at 21:40
Member - James B (VIC)
Hi all,
Was looking at going to
Chambers Pillar and Maryvale in September - however NOT in a group. Just the 1 4WD.
I have read older posts on here, and get a few conflicting reports as to just how bad the track from Maryvale (
Rodinga) heading south is.
Has anyone does this recently and care to share their thoughts?
As I said, we would be solo...so don't want to get bogged! No winch either.
Have done the
Gibb River Road and Bungle Bungles solo....so if anyone cares to make a comparison if they have also done these that would give me a good idea as to whether this is do-able by ourselves or not.
Thanks.
Reply By: ferris - Tuesday, Jul 25, 2006 at 22:13
Hi James,
I was out there a month ago, and no problems. But things can change a lot in 3 months, so maybe re-ask the question a week or two before you go.
We travelled north from Mt. Dare, through Finke and
Chambers Pillar onto the Alice. From Finke to Maryvale is sandy, but no worries. From Maryvale into
Chambers Pillar is slow going in
places, but again not a problem. From Maryvale into Alice is heavily corrugated and also sandy in
places. We were travelling in a convoy, but I would have been quite happy alone. Make sure you run on soft tyres - pressures in our group ranged from 18 - 28 psi, and I think we all dropped to about 20 psi before we got into the chamber. Between Finke and Maryvale we didn't see another vehicle, but there was constant traffic between Maryvale and the Pillar and also into Alice. The locals all get around in old Falcons, so you shouldn't have any troubles in a forby. Corrugations. I never want to see another corrugation again. I hate them. They're as bad as up in the Cape. One of our group had a can of spagheti bolognese explode on the way into the Pillar which made a lovely mess and his shockers had failed by the time we got to Alice. Would I go back to
Chambers Pillar? Tomorrow if I had the opportunity.
Keep the shiny side up.
Cheers Ferris
185321
Reply By: Member - Ian S (NT) - Tuesday, Jul 25, 2006 at 23:22
Hi James,
I agree with Ferris that it is very do-able and folks either head out for CP each day from here or arrive having done the trek from Alice and CP.
The Old South Road or Ghan Track is rough, we use the term undulating rather than corrugated. Undulated is larger corrugations or whoopsies that create a phenomena of load dumping. It tends to give suspensions and shockies a work out as it extends and compresses. Load dumping occurs when you are travelling too fast and your speed needs to be reduced until the load at the back doesn't crash down over each bump.
Reduced tyre pressure id important to have the tyre working as the first stage of the
suspension. So slowly goes is the way. The last
jump up before CP is relatively steep on both sides and with the loose rock on the track, you tend to fire rocks as you grip. Disconcerting if you have never done it before, but otherwise OK. CP is
well worth the effort if you have not seen it before, and even if you have.
Another detour is to take the Hugh River Stock Route from the South Road across to the Stuart Highway to Stuarts
Well (Jims Place) then duck back inton
Rainbow Valley. Do from Mt Dare north or from
Alice Springs south.
Enjoy
Ian@Mt Dare
185333
Follow Up By: Laura B - Wednesday, Jul 26, 2006 at 14:41
we are doing this by our selves in early sept and we are confindent to do it by ourselves....
just sandy and corrigated from what ive heard.......
again i like low tp........
fuel is at stuarts
well??????so ive been told.........
we are using HRSR from ayres rock way to get to cp...saves going all the way up to alice then down again.....
looks good...
Gramps has a photo of it in his profile....looks like snowy country with the trees....
Laura
442209
Reply By: Member - Coyote (SA) - Wednesday, Jul 26, 2006 at 08:21
Hi James.. might see you out that way.. I'll be heading through Solo too.. will be coming through from Simspon should be around 5-7th Sept or so.. I'll watch this thread with interest..
185360
Reply By: Raymond from Wanderin 4 Wheelers - Wednesday, Jul 26, 2006 at 09:40
Hi James
We did the trip from Mount Dare to Finke up the Old Ghan along the fence line into Maryvale, (good store at the Maryvale Station) then the trip into Alice. We travelled Solo and had no trouble at all, just took our time, lowered the tyre pressures and had a great trip.
Ray
185373
Follow Up By: Member - Coyote (SA) - Wednesday, Jul 26, 2006 at 13:05
Hi Raymond, mind if I ask you how long you took to get from Mt Dare to Alice??
442185
Reply By: Hairy - Wednesday, Jul 26, 2006 at 12:04
Gday James,
Apart from the little rocky
jump up just South of
Rodinga there is no where that will give you any trouble. Take note of what Ian said about your speed and you will be fine, most dammage to vehicles on that track is
suspension caused by wrong speed. Plenty of blackfellas use the track so if you did get stuck for some reason you will be able to get help.
Have fun
185388
Reply By: Raymond from Wanderin 4 Wheelers - Wednesday, Jul 26, 2006 at 16:09
The trip plan was day 1 we travelled to
Dalhousie Springs and O/N with a soak in the hot springs evening and next morning. Traveled to Mt Dare and then to the
Lambert Centre, then camped at Rumbalara
ruins. Next day to
Chambers Pillar and stayed two night (free gas BBQ's) Then from
Chambers Pillar to Alice. In Hindsight should have gone from Chambers to
Rainbow Valley then to Alice however we wanted to travel the lenght of the Old Ghan track which is what we did. Had a great time.
Ray
185419
Reply By: mickjp - Thursday, Jul 27, 2006 at 03:22
I went there a week after the Finke desert races this year. From Alice to the Pillar. The track was a bit rough because of all the traffic but easy as. I travelled alone aswell. Its as easy as the
Gibb River Road and The Bungles Track. But there is no need to let your tyres down on the track from alice to the pillar. The sand hills near the pillar are fairly firm. 4wd is needed over the dunes but nothing to worry about at all. I was in a '96 hilux diesel.
185512
