Towing on Fraser island
Submitted: Thursday, Jul 27, 2006 at 12:24
gearo
Hi I am thinking about a trip to Fraser island september 2007 I have a Jaco Flamingo Outback Campervan, I am a bit nervous about towing it on
the beach
Tow Vehicle is a 2005 Toyota SR5. Thought about arriving at Kingfisher bay resort and traveling over land to a
camping spot some were about the middle of the Island. Advice would be appreciated. thanks gearo
Reply By: Member - MrBitchi (QLD) - Thursday, Jul 27, 2006 at 12:42
Much easier to get on the island at
Hook Point, from
Rainbow beach. Go at low tide and the run up
the beach is like driving up the freeway (with just about as much traffic in peak periods...). Much easier than coming across from Kingfisher, although even that is not too difficult these days.
Also, barge is much cheaper than the Kingfisher one.
185584
Reply By: gearo - Thursday, Jul 27, 2006 at 13:07
Thanks John, What about leaving
the beach to get up to the
camp grounds will i have soft dunes to get over ?
185591
Follow Up By: Member - MrBitchi (QLD) - Thursday, Jul 27, 2006 at 14:26
You will encounter some soft sand in patches. When you get to
Rainbow, let your tyres down to about 20PSI BEFORE you attempt to get on the barge. Recently towed my camper trailer up to
Orchid Beach behind my Pajero with absolutely no problems. Most beach
camping spots are just at the top of the tide so you don't have to climb over any big dunes to get to them.
The softest sand I encountered was the blow behind
Indian Head. That spot tends to trap the unwary but correct tyre pressures and gear selection should see you through no worries. There's plenty of beach
camping on the main beach, south of
Indian head if you don't want to try it.
442452
Reply By: Troop-a-dour - Thursday, Jul 27, 2006 at 13:27
G'day
Towed a Cub Drifter (behind a 4WD Express Van) on Fraser a few years back. No great probs- just travel where the sand is firm- and watch for the creeks crossing
the beach.
The barge from River Heads?? is (was) a back on_ drive off to the western side of the island.
The one at
Rainbow Beach (
Inskip Point) is drive on- drive off, a bit easier with towing.
185598
Reply By: dublediff - Thursday, Jul 27, 2006 at 13:28
Gearo, I did this trip towing a golf camper van some years ago. My vehicle was V6 pathy at that time and it did the trick easily. I stayed at Lak Mac Kenzie in the cntre of the island, just do the normal things and keep tyre pressures low, even on the camper, and watch out for the dastardly and dangerous backperous toyotorus renta, they have no idea what they are doing. Cheers Eric.
185599
Reply By: Redeye - Thursday, Jul 27, 2006 at 16:56
Let the tyres down on the vehicle and the van and you will have no problems.
Been ther emany times without issue.
Redeye
185636
Reply By: Mikee5 (QLD) - Thursday, Jul 27, 2006 at 17:35
Gearo,
During the Fraser Island fishing comp people tow 20+ft
trailer boats up
the beach to
Orchid Beach then beach launch behind the headland. As others have said, lower your tyres then lower your speed to match. If you get stuck getting off
the beach to
camp, lower them some more. If that doesn't work hook a snatch strap up to your car and wave it around.
The beach is usually busy and there is always someone willing to help.
185642
Reply By: Member - Monkey (QLD) - Thursday, Jul 27, 2006 at 19:35
Hi Gearo,
WE took our Jayco Outback Eagle to Fraser for the first time 3 weeks ago suffering the same reservations you have. We travelled at the right time for the tides and let our tyres down to 18lb psi for the soft sand at
Inskip Point and inflated then up to 25lb for the run up
the beach. Your van is only 120kg heavier than the Eagle so I doubt that you'll have any problems.
I don't think I'd entertain the idea of crossing the Island from Kingfisher Resort with a Jayco. The idea of having to reverse a Jayco van on a sand track to give way to a tour bus, is more of a potential challenge than I would like to entertain (IMHO).
We based ourselves at Dundubara
Camping Ground and did day trips from there to the Islands many attractions. We hadn't been to the eastern side of the Island for 21 years and it was just as wonderful as we remembered.
Next time we go we will
camp on
the beach, but the hot showers etc, available at the
camping ground are very inviting.
Cheers, Monkey.
185668
Follow Up By: Member - Julie P (VIC) - Saturday, Jul 29, 2006 at 09:27
Agree with this Monkey - we took or
Dingo on to Fraser - and though we had no problems - backing up for tour operators with a trailer on is not easy - also the barge we went over to Kingfisher on was back on drive off on the way over and drive on back on coming back - whereas I think the
Rainbow Beach ones are all drive throuogh from recollection - I also don't think you can
camp with a trailer at McKenzie any more - I believe that
Central Station is now the designated
camping spot for trailers etc - I think McKenzie is now a walk in
camp.
jules
442898
Reply By: Pajeroman - Friday, Jul 28, 2006 at 06:00
I visit Fraser 4-5 times a year. Up
the beach from
Rainbow is by dar the best. Dead low tide at
Inskip point is the best way. The only problem you are likely to have is getting on an off the barge that is why you need low tide so you can get speed on the had sand as you leave the barge.
18-20 psi when you exit and low rang and give it plenty and you will have no problem.
185747
Reply By: bigcol - Friday, Jul 28, 2006 at 09:15
All the advice given is exactly right.
I have towed a Jayco Swan behind the STR on Fraser Island.
It wasn't even an off road jobby and it had very skinny tyres on it.
Just get the tyre pressure right on both and
Hook Point is the way to go
185770
Follow Up By: gearo - Friday, Jul 28, 2006 at 10:19
Thanks, Everybody seems to be saying the same thing, I feel a little more comfortable about towing a van on Fraser island Know. I have not Driven on sand for a long time so i will go to my local beach get use to it again.
Thanks Doug
442693
