Simple question on Coax - fitting connectors
Submitted: Monday, Jul 31, 2006 at 11:08
Scoey (QLD)
Hi all, easy one I'm sure. By the way I tried Googling and found mainly info on TV fittings or articles full of Technical jargon which I don't understand. :-S
I have a new UHF and antenna 'cept the antenna cable has no connector (2nd hand). I have the appropriate conenctor (thanks Dick Smith) but since I've never played with UHF's or coax I have no idea how to put said connector onto said coax. Anyone know of a fairly easy to follow article that would step me thru it? My worry is that if I don't do it right, I'll have really dodgy (or no) signal.
Help?
Scoey!
Reply By: Scoey (QLD) - Monday, Jul 31, 2006 at 11:10
Aw cr@p!! Sorry all, I just had a 'better' look on this site and found exactly what I was after! I swear it wasn't there before! ;-)
*sigh* It's Monday and I'm living in Trouble Town!
Scoey!
186238
Reply By: ExplorOz Team - David - Monday, Jul 31, 2006 at 11:24
Scoey,
I was going to post the answer you must have found. For the others the info is on the
UHF Radio Accessory page at Site Link. The image shown is
186244
Reply By: Troop-a-dour - Monday, Jul 31, 2006 at 11:48
Hi Scoey
David's reply shows the non- solder (for the earth braid) method. I would strongly suggest you do solder the braid to the 'outer' sleeve, and of course a good solder joint for the inner.
I have seen a few failures with the friction- non solder system, and with UHF you need as much efficiency as possible to eliminate signal loss.
186246
Follow Up By: Kiwi Kia - Monday, Jul 31, 2006 at 12:04
You pays your money and makes your choice.
I would not use a solder joint if I have the choice. Non solder will not crack and can be remade in the field if required
443281
Follow Up By: Troop-a-dour - Monday, Jul 31, 2006 at 12:39
Kiwi Kia
IF the job is done properly, using a purpose made PL259- there would be no need to make repairs in the field. I have seen the friction braided type fail and disintergrate, and that was on (so called) professional installations.
Oh..and by the way- I understand the price of lamb has risen in New Zealand...
It's now $40.00 per hour.
443289
