Frontera LPG
Submitted: Monday, Jul 31, 2006 at 19:53
Camoco
Hi all,
I have a 2002 Holden Frontera Manual 3.2l (last model) running on LPG/Petrol. I have been running gas since Jan 06. While the installer took 3 weeks to get it working right, there has been some lingering issues. He said he would get to the bottom of it but I think he has forgotten.
Firstly the "check engine" light stays on while on gas (I expect the exhaust sensor to be the issue here) and used to take 30-40k's on petrol to go off. It now seems to stay on whether on gas or petrol. I guess it needs replacing but that would get expensive doing that every service.
Secondly, the revs are slow to reduce when throttling off and above 3500rpm it just way over revs (not that I take it that far normally).
Has anyone experienced these issues in the Frontera or other dual fuel vehicles. I have heard Patrols may suffer as
well. The computer mapping was a big issue to sort out as
mine is a manual and uses different cpu's to the auto's.
On a
bright note, I am very glad to have made the conversion even though it was $3000. It gave me a longer range and cheaper running. at 60c/l for gas it's way cheaper than $1.35 for petrol. I get about 85% /litre from the gas (was told it would be as low as 70%) and during cooler months, it seems to have as much power.
Reply By: Vince NSW - Tuesday, Aug 01, 2006 at 14:22
Camoco,
Had the same prob wihi my 2000 mod (Don't have gas) petrol about 2years ago in the snowy. Called into the local Holden dealer and he founf a leaf had some how got into the air intake to the cleaner and it was showing bad air flow. Out with the leaf and off with the light. Charge from the Holden Dealer $0.
Don't know if this is of help or not.
Vince
186506
Follow Up By: Camoco - Wednesday, Aug 02, 2006 at 12:04
Hi Vince,
Mine is definately related to the LPG. If the light is not on while on petrol, it comes on the instant switched over to LPG. It used to go out after a short time on petrol, but now it seems to be constant on. Guess the sensor is now stuffed.
It still runs
well though.
443757
