Ebay air compressor - thoughts please ???
Submitted: Monday, Jul 31, 2006 at 20:25
ThreadID: 36334 Views:3974 Replies:15 FollowUps:19
After downsizing from my Pajero to the X-trail, I have been looking for an air compressor that will do the job of pumping up the tyres after beach trips. I can't justify spending $400+ again on a Big Red or ARB, but saw a 'decent' looking one on Ebay for $70. It claims an maximum draw of 23Amp and max pressure of 150psi, with a maximum running time of 12 minutes continuously. Has anyone bought one off Ebay. I know a lot of this stuff is junk and the figures cannot be proven, but I will only be using in a few times a year.
Site Link
Any thoughts or previous experiences are appreciated.
Reply By: Member - Vince B (NSW) - Monday, Jul 31, 2006 at 20:52
Hi Pajboy.
Why dont you place a wanted add in the trader section.I bought a thomas compressor years ago & it is great for beach work. You should pick up a good second hand compressor under $200.
Vince
AnswerID: 186368
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 21:03
Thanks Vince. I actually forgot all about the Trader. Expect to see an add soon.
FollowupID: 443428
Follow Up By: Member - Vince B (NSW) - Monday, Jul 31, 2006 at 21:08
How do you find the xtrail after having a pajero. Do you tow a camper?
Vince
FollowupID: 443431
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 21:12
Downsized due to family illness ($$$), but fitting the same amount of stuff into the exy is a problem though. We love camping, so a roof pod could be the next buy.
FollowupID: 443435
Reply By: 100TD - Monday, Jul 31, 2006 at 20:52
junk junk and junk dont bother unless u only want to pump up one tyre then let it cool for an hour before pumping up the next!!
AnswerID: 186369
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 23:30
Good point, thanks.
FollowupID: 443475
Reply By: Emo - Monday, Jul 31, 2006 at 21:00
I've got a Projector Cyclone compressor that looks similar. I had a problem with the thermal cut out but once I fixed that it's been fine. I've had it a year and it does the job. It's not what you'd call fast though.
AnswerID: 186372
Reply By: chips59 - Monday, Jul 31, 2006 at 21:08
my son has got one of those compressors, or should i say had one. just a short story, he went down the beach in his forby, let the tyres down as you would. come time to go home pumped the first tyre no problem the second started to get slower, third slower still, forth and after 30 min. it broke the piston rod. next thing rings dad for help, dad said drive home very slowly and learn a lesson about buying something that you have to rely on to work perfectly.
AnswerID: 186374
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 21:17
Very wise words indeed...and the reason for my enquiry here. I was (am) hoping to get an actual idea of its effectiveness or lack-of. Thanks. I am starting to think a few extra dollars spent will save some heartache down the track.
FollowupID: 443436
Reply By: phillip owen - Monday, Jul 31, 2006 at 21:22
People rage about the $390 Bushranger pump from 4WD or auto shops. I couldn't justify this amount either so I bought the smaller $99 model. Haven't used it yet though. They also make a model in between.
As for buying off EBay. Have only had positive experiences. But I did know what I was looking for and what was around in retail stores before I bid on anything. I gues as long as you do your homework, ebay can be good for some bargins.
AnswerID: 186381
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 21:25
Which brand did you go with.
FollowupID: 443440
Follow Up By: Muddy doe (SA) - Monday, Jul 31, 2006 at 21:28
Excellent point.
If ypou use it every weekend buy a MX-AIR but if like me you use it only a few times a year get the smaller Pro-Air ($200 if you hunt around or wait for a sale).
The Pro-Air that I have still beats the pants off all the cheapies timewise and will last years.
Bushranger do a smaller one still for $99 which would be a bit slower again but it is a brand name and should be more reliable than the "Bunnings or Kmart special".
Muddy
FollowupID: 443441
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 21:32
Thanks, at least that gives me something to start looking at. Nice pic of the Prado too, hope the windows were up.
FollowupID: 443445
Reply By: Member - uncle - Monday, Jul 31, 2006 at 22:10
People buy $30,000+ caravans & boats and only get to use them once or maybe twice a year , a $390 compressor to get you out of the chit, and prevent swmbo nagging your ears off(see told you, you should have paid the extra!!) mate $390 is a bargain!!
AnswerID: 186393
Follow Up By: Member - andrew B (Kununurra) - Monday, Jul 31, 2006 at 22:30
Where do you get one of them - SWMBO who wants you to spend more on the toys....
Cheers Andrew
PS - I have a $99.00 supercrap 'dr air' which is quiet, fairly quick, has seated beads on 16" tubless tyres and has had a fair bit of use. So Far.......
FollowupID: 443460
Follow Up By: Member - uncle - Monday, Jul 31, 2006 at 22:39
It's like looking for gold to get one, had to pull some rocks aside first!
FollowupID: 443462
Reply By: Muzzgit (WA) - Monday, Jul 31, 2006 at 22:56
Maximum running time of 12 minutes says it all !!!
I bet this thing would need a minimum of 30 to pump up 4 tyres
Good thing no cheap
cheap thing no good
AnswerID: 186408
Reply By: ross - Monday, Jul 31, 2006 at 23:24
I go the Bushranger for $360 with some phone calls and arm twisting.(5 years warranty;) )
They also make one for occasional use for $130 and is highly recommended.
If you buy 4 of those cheapies you can inflate as fast as my Bushranger; )
AnswerID: 186412
Reply By: Member - Phil G (SA) - Monday, Jul 31, 2006 at 23:24
The Xtrail tyres are only 215/70R15 so will pump up reasonably quick with one of these "Cyclone" compressors.
AnswerID: 186413
Follow Up By: PAJBOY - Monday, Jul 31, 2006 at 23:33
I'm running 225/70r16 BFG all terrains, but I agree that their size shouldn't put too much pressure on the compressor. I think I'll look at the Bushranger model.
FollowupID: 443476
Follow Up By: Member - Phil G (SA) - Tuesday, Aug 01, 2006 at 11:17
Pajboy,
We also own an Xtrail and thinking of upsizing the tyres. Any issues with the 225/70R16 BFG touching the guards? I'm guessing you've got the Ti mags.
phil
FollowupID: 443525
Follow Up By: PAJBOY - Tuesday, Aug 01, 2006 at 11:30
Phil,
The BFG's were the best addition so far to the exy. Really transformed it, however I am having some trouble getting the correct sand pressures worked out. No rubbing on the inner guards and they don't stick out of the guards at all, but they cause the speedo to read about 4% out, due to the extra rolling diametre. Small price to pay for top tyres. It also about the largest you can go with the spare tyre also.
FollowupID: 443529
Reply By: Member - MrBitchi (QLD) - Tuesday, Aug 01, 2006 at 08:05
I got one of the Bushranger copies off eBay. Have had it for about 6 months. Works fine.
AnswerID: 186433
Follow Up By: Member - MrBitchi (QLD) - Tuesday, Aug 01, 2006 at 08:06
Edit, edit.....
Max Air copy that is..... ;-)
FollowupID: 443495
Reply By: Member - Andrew W (SA) - Tuesday, Aug 01, 2006 at 09:02
I have a Bushranger copy off eBay (and a foot pump in case it ever dies as well as a hose to pump from the spares) which I have had for 18 months.
From memory $100.
As a pump it has worked flawlessly even in aweful hot conditions.
The rubber feet that connect it to the base vibrated to the point of shearing off so that the base was separated from the pump ... the vibrations was from having it in my recovery box unsecured and it was bouncin' lots.
I have put a heavy duty rubber mat on the base (about 8mm rubber from Clark) and bolted the pump down with nuts and nylocks and it continues to work a treat.
I can inflate 6 tyres (actually 285/74 "Tires" ;-) with it in about 15-20 minutes, and whilst it is hot, it isn't making any strange noises either.
The important thing is not to be relying on it when you are a long way from home regardless of the brand or how much you pay for it - that way you will never be stranded.
Ciao for now
Andrew.
AnswerID: 186449
Follow Up By: Shaker - Tuesday, Aug 01, 2006 at 09:16
I have one as well, also can't fault it after over 2 years of use. Air compressors have to get hot, because when air is compressed heat is generated. Try it with a bike pump even.
FollowupID: 443506
Follow Up By: PAJBOY - Tuesday, Aug 01, 2006 at 11:32
Thanks Andrew, good point. I previously had a Big Red under the bonnet of the Pajero and I pumped the spare up at little extra to transfer air to the tyres in case the compressor died. Never did but.
FollowupID: 443531
Reply By: Gmouse - Tuesday, Aug 01, 2006 at 09:41
Looks the same as were being sold by “Super Crap”
mine was used about 4-5 times and seemed ok
That was until it packed it in on the canning in May
think I paid about $69.00 for it…what a waste of the folding stuff
AnswerID: 186458
Follow Up By: Rokkitt - Tuesday, Aug 01, 2006 at 10:29
I use a very similar compressor and have done for the past three years, although it does work well I can't say I can ever really trust it fully! and I always hold my tounge just right while it is running.
FollowupID: 443519
Reply By: Member - MrBitchi (QLD) - Tuesday, Aug 01, 2006 at 12:26
Try this one.
AnswerID: 186489
Follow Up By: Member - MrBitchi (QLD) - Tuesday, Aug 01, 2006 at 12:28
Or this one.
This is the one I have.
FollowupID: 443537
Follow Up By: Rokkitt - Tuesday, Aug 01, 2006 at 12:31
Deals direct have these for 50 bucks.....again not sure of the longevity of the item.
Rod
FollowupID: 443538
Reply By: PAJBOY - Tuesday, Aug 01, 2006 at 13:02
Thanks for the links guys. I have been watching a few online, but I think the Bushranger fits my requirements nicely, especially for $99 with a 5 year warranty.
AnswerID: 186492
Reply By: Big Trev - Friday, Aug 04, 2006 at 17:59
I bought one of the bigger ones, but it only lasted 12 months of not much use, very disappointing.
AnswerID: 187144
