LED Tailights
Submitted: Tuesday, Aug 01, 2006 at 17:37
Bag Boy
Hi fellow 4x4er's, Just wondering.. I'm in the process of replacing my tail lights on the GU ute. I want to use some LED lights, dose anyone know where I can get some and is there a selection I can choose from.
BB.
Reply By: Ray Bates - Tuesday, Aug 01, 2006 at 17:41
Try Dick Smiths but remember you may have to put in a resister for your indicators
186532
Follow Up By: Bag Boy - Tuesday, Aug 01, 2006 at 17:44
G'day Ray, What is the story with the resister???
BB.
443604
Follow Up By: Ray Bates - Tuesday, Aug 01, 2006 at 18:02
In some instances the LED will not use enough current to activate the flasher unit so an extra load has to be in the circuit even if it is the original globe
443607
Reply By: Member - John L G - Tuesday, Aug 01, 2006 at 17:50
You can buy these at most good auto accessory shops and have some fitted to the back of the Tojo 75.
Brilliant for brake and
park lights but only average as a reverse light.
Not cheap - about $150 for a three unit light park/turn/reverse depending where you get them. Lights are sealed, submersible and much better than the el-cheapo bulb jobs.
Ciao for now
186534
Reply By: mprice2233 - Tuesday, Aug 01, 2006 at 17:57
try here
and there are plenty of others on ebay
186537
Follow Up By: Ray Bates - Tuesday, Aug 01, 2006 at 18:04
I believe that our friend is just looking for LED globes not the full assembly
443609
Reply By: Peter 2 - Tuesday, Aug 01, 2006 at 18:36
A few things to remember is that alot of the LED globes are very directional, fine if you are directly behind or in front of the LED but woeful if even slightly off centre.
The lens and reflectors designed for normal globes don't work very
well at spreading the light from LED's, I for one want to be as visible as possible to other road users.
Most of the replacement LED globes are not certified for road use.
The LED light units made by manufacturers like Hella, Narva etc are usually ADR compliant and should say so on the packaging.
186552
Reply By: Max - Sydney - Tuesday, Aug 01, 2006 at 19:31
They must have a lot going for them - I am amazed at the number of trucks on the road recently that have obviously replaced their rear light units with LEDs, which are eminently visible, especially at night. The new
Sydney buses likewise have them.
I suspect its less bulb failure from vibration as part of the reason on trucks.
Max
186562
Follow Up By: rodeonut - Tuesday, Aug 01, 2006 at 21:21
Trucks also use them on their trailers because they are multi voltage, therefore either a 12 or 24 volt truck can pull the trailer without the hassle of changing your globes
443651
Reply By: Mark- Tuesday, Aug 01, 2006 at 20:11
If the lights you are buying are ADR approved, they should be reasonably visible from off center. Ebay is where I'd be looking first.
They have a lot going for them, - vibration proof,
water proof, dust proof, last indefinitely, quick brake light response, draw minimal current, crisp indicator flash etc. Fantastic on boat trailers. But unless using them on a trailer you will need a non load sensitive flasher as said above.
Also look for poly carbonate lenses - almost impossible to break.
186579
Reply By: Jugs - Tuesday, Aug 01, 2006 at 21:45
Check out post 34641
The Narva web site has lots on LED designed for the purpose with kits for flasher mix filament / led or all Led
Jugs
don't work for ect
186607
Reply By: Barnesy - Wednesday, Aug 02, 2006 at 18:16
From what i understand simply changing the standard globes to LED without changing the reflector will give a poor performance. I inserted a globe into the 'dummy', slightly tinted tail lights on my GQ. With a standard globe they were acceptable. The LED i tried was hardly visible through the lens. A waste of money.
I have seen LED taillights on some 100 series (probably after market) and they are brilliant.
Barnesy
186773
Reply By: Bob Y. - Qld - Wednesday, Aug 02, 2006 at 21:01
Fitted some "super"
bright LED globes to the tail lights of the 80 series, which are very good, with most of the benefits mentioned above.
One thing we didn't count on was affecting the cruise control. Apparently the whole globe lights up, whether on tail, or stop. As there's this residual current feeding back into the brake circuit, the cruise just cancels, even with only the parkers on. Bit of a bummer if it's raining, or visibility is poor.
Hella make good LED assemblies. Lot of road trains up here use them exclusively now, especially for trailer lighting. Not affected by voltage drop, or poor earthing.
Hooroo...
186811
