Long range fuel tank - Mazda E2000
Submitted: Wednesday, Aug 02, 2006 at 16:35
wmoore
I've got a Mazda E2000 motorhome (started life as a LWB flat-bed) and I'm looking to get an auxilliary fuel
tank installed before heading off on a big trip around Oz :-) The thing is, I'm struggling to find anybody locally (
Brisbane) who can / will fit one.
The nearest I got was ARB and Opposite Lock who said there was a
tank for this vehicle but not to fit a pre-1992 model. Does anybody know of a
tank for this model or a generic one that can be fitted?
My last resort is to build a bracket underneath the van to carry a couple of jerry cans but I'd rather not do this if possible.
Cheers.
Reply By: kev.h - Wednesday, Aug 02, 2006 at 17:30
Hi do you have room to fit a second standard
tank or does the motor home come down lower than the chassie if you have room i have a
tank that should fit i had if under a ford econovan e2200 flat bed
Kev
186760
Follow Up By: wmoore - Wednesday, Aug 02, 2006 at 19:18
There is lots of room under the chassis - the motorhome skin hangs down over the chassis but apart from the spare wheel there is plenty of room underneath. We have a waste
water tank behind the main fuel
tank and the house electrics are on the other side. But I think we should be able to mount another
tank back there.
Where abouts are you? The Ford Econovan and the Mazda are basically one and the same aren't they?
443839
Follow Up By: kev.h - Thursday, Aug 03, 2006 at 16:56
I'm in
Bundaberg the
tank is approx 330mmx330mmx870mm with a mounting flange each end on the centre line overall (outside flanges )is 930mm it has a gauge sender filler neck suction line and breather - it needs a small electric fuel transfer pump
if it looks like it will fit give me an email address and i can send you some photo's
Regards kev
444077
Follow Up By: wmoore - Thursday, Aug 03, 2006 at 20:35
The van's out getting some welding done just now so I can't measure but I'd appreciate the pics and I'll check it at the weekend.
waynemoore[at]aapt.net.au
444124
