Cabling
Submitted: Saturday, Aug 05, 2006 at 15:54
eerfree
I want to instal an On/Off switch on the dash of my Prado to control the Reversing Sensor ( drives me Mad backing the caravan).
Spent most of this morning mucking around underneath and found that I can get a cable all the way from front to back INSIDE the chassis rail, has anyone struck problems running cable this way? Would vibration wear off the insulation? Are there any other problems that this run could cause?
Thank You.
eerfree
Reply By: Sarg - Saturday, Aug 05, 2006 at 17:25
Run the cable thru conduit to add extra protection.
187305
Follow Up By: ferris - Saturday, Aug 05, 2006 at 21:56
Use twin sheath cable. As the Irish would say "To be sure to be sure."
444616
Reply By: Member - Mike DID - Saturday, Aug 05, 2006 at 19:26
Do you mean you want to switch off the Reversing Sensors when you have the Caravan in tow ?
If so then why not put the switch in the back - no lengthy wiring needed. When you hitch up the Van just open the rear door and flick the switch.
187323
Reply By: eerfree - Saturday, Aug 05, 2006 at 22:42
Sarg and ferris
Thanks, good points, the more protection I use the better off I will be, ( I think my Dad said that once !!!! ).
Mike DiD
Spoilsport !!! Thanks for coming up with the easy option after I spent half a day rolling around in the dust, LOL I would have said ROFL but my back is too sore.
Appreciate your comments on other threads as
well.Thankyou.
eerfree
187357
Follow Up By: Member - Mike DID - Saturday, Aug 05, 2006 at 23:31
eerfree, I wish my wife would agree with you - she says I spend way too much time thinking about how to solve a problem, rather than getting in there and starting :-)
Thanks for the feedback
444640
