80 series wheel offset
Submitted: Sunday, Aug 06, 2006 at 18:24
ThreadID: 36509 Views:11215 Replies:2 FollowUps:0
Can anyone tell me ,what would be the max. neg. offset rim I could legally use on my '94 80 series L/C. Or what is the standard offset, say for the GXL rim. Is there a max rim width as well?
thanks
teddy
Reply By: Member - DOZER- Sunday, Aug 06, 2006 at 19:25
Ted
std offset is 0 thats 4 inches in, 4 out...you can run 60 series offset on them and get away with it, these are 4.5 out 3.5 in or positive 20mm roughly....you can also run nissan 16x8's which are about (not sure exactly) 3.5 out 4.5 in...or neg 20...
Legally, you are allowed to change track 1 inch overall, so 12mm is the most you can go in or out each wheel....
AnswerID: 187466
Reply By: teddy - Sunday, Aug 06, 2006 at 19:43
Thanks dozer.
by the way, do you know what offset, the 90 series prado rims are? I've been useing a set of them (16x7 ??). The track looks to be narrower , than normal
teddy
AnswerID: 187472
