gu is haunted
Submitted: Sunday, Aug 06, 2006 at 21:38
brian
Well not really but it has started switching its brake lights on and off when it feels like it,even when parked.i am guessing it has a defective switch somewhere anyone had to replace theirs and any idea where it is located ???????? thankyou for any advice.
Reply By: grandpa joe - Sunday, Aug 06, 2006 at 22:01
If you follow the brake pedal lever up under the dash you will find the button switch that makes a click sound when you press on the pedal, more than likely you will find that all you have to do is adjust it a little closer to where it makes contact with the lever. This switch vibrates out of position on it's threaded holder on most vehicles given ample time.
187514
Reply By: Muzzgit (WA) - Sunday, Aug 06, 2006 at 22:09
OR......do you have an electric trailer brake controler fitted?
The Tekonsha brand had a fault in some models which would do this. The first time I noticed it I crept up the side of my car with a baseball bat, thinking some stooge had broken into it and was rummaging through my stuff. te he
187516
Reply By: ACDC - Sunday, Aug 06, 2006 at 22:10
Brian,
I'm tipping you have a Teckonsha brake controller that is faulty,they had a batch about 2 years ago which had this fault.
187517
Reply By: awill4x4 - Sunday, Aug 06, 2006 at 22:13
Brian, does your GU have a brake controller fitted for towing either a caravan or trailer fitted with electric brakes? If it has, my bet is that it's a Tekonsha Voyager controller, these controllers have a known problem in doing exactly this and Tekonsha have in the past been changing them to their Prodigy models (a much better version by the way)
Regards Andrew.
187519
Follow Up By: awill4x4 - Sunday, Aug 06, 2006 at 22:14
Geez, in the space of 3 minutes "great minds think alike"
444798
Reply By: Truckster (Vic) - Sunday, Aug 06, 2006 at 22:20
Im tippin he will say he doesnt ahve one fitted ..
LMAO
187522
Follow Up By: Muzzgit (WA) - Sunday, Aug 06, 2006 at 22:21
Pretty good odds on that one!
444800
Reply By: brian - Monday, Aug 07, 2006 at 07:51
Thankyou for the replies YES it does have electric brake controllerwill go and check it.
187543
Follow Up By: Shaker - Monday, Aug 07, 2006 at 09:20
It will be replaced under warranty.
444858
Reply By: Voxson (Adelaide) - Monday, Aug 07, 2006 at 10:44
I have to ask this because i also knew of that problem,,,,, but what i dont know is what does a brake controller does?????
Always been meaning to ask this?...
187589
Follow Up By: The Fox - Monday, Aug 07, 2006 at 12:27
A brake contoller is used to operate the electric brakes on a caravan or trailer.
It usually has a pendulum or some sort of inertia detection system so that the harder you apply the brakes in the car, the more voltage is supplied to the electric barakes and the harder they react.
Most have some sort of manual lever to allow you to apply the brakes to the van without applying the car brakes, hence the need for a connection from the controller to the brake lights. The faulty brake controllers intermittently operated this connection, causing the brakes lights to activate when not needed.
444891
Reply By: Ianw - Monday, Aug 07, 2006 at 19:25
Had a falcon last year, did same thing. Middle of the night, brake lights would come on and go off at random. Eventually caught the little bugger!! Mouse eating the wiring loom!!!!
187696
