Site Search
Section Image
TWINE SHOWER SYSTEM IN A GU 4.2TD
Submitted: Tuesday, Mar 04, 2003 at 15:19
dave charlton
i have installed a Twine unit in my 4.2td gu nissan and have found that it does not heat up as well as the 80 series and as such I have to run the motor at higher revs to acheive reasonable shower. Has anyone else experienced this with the nissan? I am considering fitting another exchanger (with a bypass option) to help with this problem. I live around the Victorian High country and the water is a bit colder than up north where it was not a problem when we travelled to the cape.
Advertisement
ThreadID: 3654 Replies: 14
Views: 446 FollowUps: 6
AnswerID: 14433   Submitted: Tuesday, Mar 04, 2003 at 17:28
Member - Raymond replied:
Hi Dave
The solution is fairly easy. Unless you are drawing straight from the river then just circulate the water back into the bucket for a few minutes to add a bit extra heat to the water, I agree up North no problem, but then they don't get our high country, traqcks and snow to play in. I notice that my GU does not get as hot as the 80 series I used to own
Ray
Reply 1 of 14
AnswerID: 14467   Submitted: Wednesday, Mar 05, 2003 at 06:08
Tony replied:
For the High Country in winter I fit a small disc in the hose before the shower head, it is a disc with 6 holes in it and slowes the flow rate down ever so slightly and allows the water to heat up more.
You need to remove it for up north as it makes the water to hot, the disc was supplied with the "Glind" shower.
Reply 2 of 14
AnswerID: 14479   Submitted: Wednesday, Mar 05, 2003 at 09:17
Frank replied:
Dave,
Today's modern vehicles have a very efficient cooling system, hence the difference between temperatures in heat exchange.
Rather than going off to but a second heat exchange unit, go to a refrigeration mechanic or a good plumber and have them make you one up. Ask them to make it slightly longer or wider, depending on space available under bonnet.
When the size of the exchanger is increased they can accomodate a larger number of internal piping twists. This effectively increases the resident time of the water in the exchanger, hence hotter water throught the shower piping. This way, you don't have to slow the shower head rate to a dribble, which is almost as bad as a cold shower.
If you are interested I can email you the drawing.
Frank
Reply 3 of 14
AnswerID: 14482   Submitted: Wednesday, Mar 05, 2003 at 10:01
dave replied:
thanks to all that have replied and I have already tried all the answers that I have received. In regards to fitting a disc to restrict the flow of water it can be done by slightly closing the hand control to help retsrict flow. My exhanger is fitted to the firewall and I do have a provision of fitting another exchanger albeit a bit smaller. This is a great website. I have spoken to John about the lack of heating in the GU and suggested the exchanger be a bit longer to cover all models and I personally woould not mind having to pay that little bit extra.
Reply 4 of 14
FollowupID: 8711   Submitted: Wednesday, Mar 05, 2003 at 10:24
Michael posted:
Dave , i had the same problem with my 4.2 Gu , it got me thinking about how to overcome this common problem with the GU. I have made a prototype heat exchanger, quite unique i think, that is mounted in the engine bay, it takes up NO extra room in the bay, no extra piping or awkward hoses, just loop the fresh water together in series with the Twine and it raises the temp another 10 deg c. I'm just finalising my 3rd prototype, just making a few more improvements, and i think it will get to around 45 deg at idle or just above. The last thing you need is 2000 RPM in your ears in the bush, just the reason you are there in the first place, to get away from the noises of daily life. I'll let you know how it goes when i'm finished. Regards Michael
FollowUp 1 of 2
FollowupID: 8728   Submitted: Wednesday, Mar 05, 2003 at 12:59
Michael posted:
Dave , one other thing, I dont think the by-pass idea is any better, if the heater tap is on full and the fan is off, once the whole car heater is up to temp, i think the losses from that area would be very small. My thoughts only. Michael.
FollowUp 2 of 2
Activities Index
Tandem Skydiving - Brisbane Tandem Skydiving - Brisbane
Brisbane - QLD
Experience the thrill Tandem skydiving and get ready for a gravity powered adventure and as you thro
V8 Race Car Driving Experience - 8 Laps, SA V8 Race Car Driving Experience - 8 Laps, SA
Adelaide - SA
Conquer South Australia's Mallala Motor Sport Park!
Sydney Fashion Secrets Sydney Fashion Secrets
Sydney - NSW
This is an inspiring walk for enthusiasts of fashion and design.
Sovereign Hill and Historic Ballarat Sovereign Hill and Historic Ballarat
Goldfields - VIC
Travel to Ballarat and visit Sovereign Hill, a perfectly re-created 1850s goldmining settlement.
Book Now - Things To Do
AnswerID: 14504   Submitted: Wednesday, Mar 05, 2003 at 15:18
John Eggenhuizen replied:
Hi Dave,
I own both Getabout 4WD Adventures and Twine showers.
In comparison to an 80 series cruiser, the GU normally runs a good deal cooler.
I have run my Twine unit down in the high country and yes I agree I do have to have a few more revs, I find in my vehicle (same as yours) that I have the revs around 1400rpm. I often shower up to 10 of 15 people and at those revs the shower is fine.
If you are still not happy with the system, give me a yell and we can exchange your unit with one that is 65mm longer. This would go a long way to solving your problem.
kind regards
John.
Reply 5 of 14
FollowupID: 8743   Submitted: Wednesday, Mar 05, 2003 at 15:32
Member - dolfn posted:
Hey there john, really great to see you on here supporting your product.
My wife and I are about to buy one for our series II disco.
What do you suggest for that are we going to have trouble free warm showers all over australia?
FollowUp 1 of 3
FollowupID: 8745   Submitted: Wednesday, Mar 05, 2003 at 16:06
John Eggenhuizen posted:
Hi Dolfn,
Thanks for the great wrap, we like to think that we can be fairly supportive to those who use our product.
So with your Disco, is it a TD5 or a V8, we have fitted them to the TD5 and they sit very nicely next to the rocker cover on the passenger side, if you trace your inlet heater hose you will find that it runs through that area. We don't have specific bracketry for the TD5 yet, but we're working on it.
cheers,
john
FollowUp 2 of 3
FollowupID: 8746   Submitted: Wednesday, Mar 05, 2003 at 16:30
Yes John it is a Td5 and if you can have a bracket organised in the next month, then sir you have yourself another sale.
Im in the Sydney area, so I might pop around to prospect one day and see how I should go about fitting one.
Thanks again for your support ;)
FollowUp 3 of 3
AnswerID: 14509   Submitted: Wednesday, Mar 05, 2003 at 16:27
Member - dolfn replied:
Reply 6 of 14
AnswerID: 14821   Submitted: Tuesday, Mar 11, 2003 at 09:29
dave charlton replied:
Gidday John, I would like to try the longer exchanger you are offering. Are you going to the Albury Wodonga Caravan and Camping and 4Wd show this year? If so we could chat then. Our unit has converted quite a few people from the traditional way of the canvas bucket and has kept the financial manager (wife) very happy when we have been away. There is nothing like a never ending shower when you want one. I have fitted a swivel joint onto the hand peice and we also use the spring loaded shower tent.
Reply 7 of 14
AnswerID: 14822   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 8 of 14
AnswerID: 14823   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 9 of 14
AnswerID: 14824   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 10 of 14
AnswerID: 14825   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 11 of 14
AnswerID: 14826   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 12 of 14
Activities Index
Goldfields - VIC
Great Barrier Reef Cruise &Seawalker Helmet Diving Great Barrier Reef Cruise &Seawalker Helmet D
Cairns and Tropical North QLD - QLD
Experience the marine life of the Great Barrier Reef by joining our Seawalker Helmet Diving adventur
Yarra Valley Wineries and Puffing Billy Yarra Valley Wineries and Puffing Billy
Melbourne - VIC
Sample renowned Yarra Valley wines and ride through lush forests of Victoria's premier wine region.
60min Reef and Rainforest Helicopter Scenic Flight 60min Reef and Rainforest Helicopter Scenic F
Take up the awesome opportunity to glide high above the lush tropical canopy of pristine Rainforest,
AnswerID: 14827   Submitted: Tuesday, Mar 11, 2003 at 09:29
Reply 13 of 14
AnswerID: 14828   Submitted: Tuesday, Mar 11, 2003 at 09:30
Reply 14 of 14
FollowupID: 8964   Submitted: Tuesday, Mar 11, 2003 at 09:33
dave charlton posted:
Apologies! I do not know how I managed to stuff that up with the reply.
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
