poor diesel?
Submitted: Monday, Aug 07, 2006 at 22:21
ThreadID: 36568 Views:9902 Replies:12 FollowUps:5
Hi all,
was visiting my mechanic the other day. He was telling me about the poor fuel economy he and several people he knew were getting. He was blaiming it on the diesel, reckons the quality has dropped off. I'm not too sure how my economy is going, but I have noticed the 4by is laking a bit of grunt. I have to put the foot down a lot more to get it up and running. Has anybody else out there noticed their diesel consumption/ performance getting worse recently for no apparent reason?
Just curious to see if he is on to something or just blowing hot air.
Regards.
PJ.
Reply By: Truckster (Vic) - Monday, Aug 07, 2006 at 22:32
probably from them no name servos where they cut the diesel with everythign they can get their hands on
AnswerID: 187752
Reply By: Grandpa joe - Monday, Aug 07, 2006 at 22:33
If you Look up the recomended cetane rating of the diesel that your vehicle manufacturer specifies and then check with e.g. shell website which shows the cetane rating of the diesel supplied in your area, you will probably find the that the cetane rating isn't as high as what your 4b should have. I checked myself and noticed this while I was looking at which areas supply a lower waxpoint temperature diesel fuel in the the middle of winter down south......
check it out
AnswerID: 187753
Reply By: Eddy - Monday, Aug 07, 2006 at 23:15
There is not much new in this world is there?
With acknowledgement to "Ron" ( as opposed to cetane rating!)
" Reply 2 of 2 posted 03 Apr 2006 at 13:55 - (AnswerID: 164551)
Ron173 replied to the question
There is a minimum cetane rating for diesel for Australian market, I looked into this a while ago.
I cant remember the exact figures. However I can tell you this much:-
All diesel has to meet it and most do just that, with the exception of shell, which exceeds it by a few points.
From this if you are basing it on cetane rating alone that would make Shell the top choice.
If you do some digging on the net under cetane ratings / shell you will be able to confirm this easily.
I find mine runs pretty sweet on Shell although dont always buy it.
Hope this helps
Ron "
Good on you Ron, you old fore runner!
AnswerID: 187758
Follow Up By: Ianw - Tuesday, Aug 08, 2006 at 00:49
Just been doing some research come up with these figures from fuel co data sheets on ultra low sulphur diesel
shell 49 cetane
caltex 46 cetane
bp 51 cetane
maybe we should be using bp
Nissan quote above 50 cetane for Europe but only above 45 for rest
Is this dictated by what the fuel companies supply? Is BPs 51 cetane better?
I guess cetane rating would be lowered by additives in winter diesel?
FollowupID: 445039
Follow Up By: Rokkitt - Tuesday, Aug 08, 2006 at 07:44
Been going to Shell and to be honest I am not sure if there is any difference - happy to stick with it though as it seems to be a popular belief that shell diesel is better.....so looking at Ian's figures should I now switch to BP?
FollowupID: 445050
Follow Up By: Steve63 - Tuesday, Aug 08, 2006 at 08:51
Interesting. I usually (4 out of five fills) go to a Shell where a lot of trucks fill up. My reason being that if the fuel was regularly rubbish the trucks would fill somewhere else. I have noticed I get about 50km more from a tank if I filled at a Shell rather than Caltex. I thought this was me just having a heavy foot while on that tank. Maybe not. We are off in a few days for a month so I'll keep some notes on where I filled up.
Steve
FollowupID: 445056
Follow Up By: Member - Pesty (SA) - Tuesday, Aug 08, 2006 at 11:03
I buy a lot of fuel, a tank every 1-2 days and i buy it wherever, and for a couple of years i have noticed, by just driving , that i get a better power out of BP, so it is interesting that the scale above says that BP has a higher rating. I try to get it when I can, but dont always get a choice in the bush.
I also regularly put chemtech additive in to keep moisture out and carbon buildup down, and if i am doing any heavy towing it also gives a noticable power increase.
Cheers Pesty
FollowupID: 445081
Reply By: ross - Monday, Aug 07, 2006 at 23:42
Ive never had what I would call a bad batch of diesel or petrol.
I dont know how you can accurately gauge the quality by feel.
Its a bit like the endorsemnts in those fuel saver gadgets where "Mr Simpson "of Cremorne say his car "seems" to have more power or Mr Jones believes his fuel economy has improved 13.735% in the last 22 klms just from looking at the gauge.
If you get what you think is a bad batch take a sample and see if it can be tested ,if thats possible.
You cant scoff at Bill S unscientific claims then do it yourself;)
AnswerID: 187763
Reply By: Jason M P - Tuesday, Aug 08, 2006 at 08:15
Hi Paul , Yes i have notice the difference in fuel quality... I try to fill up with BP diesel for my 100ser. crusier. As i get more out Km's out of may tank.Using other fuel product i lose up to 50km to 100km out of the tank.So I'm sticking to Bp all the way..
Cheers...
AnswerID: 187784
Reply By: traveller2 - Tuesday, Aug 08, 2006 at 08:15
The quality of diesel supplied by all servo's can and does vary, despite claims that you can't detect the difference by driving anyone who is driving a vehicle constantly will notice any difference virtually straight away after refuelling.
I drive a Coaster bus with a 1HZ diesel (same as a cruiser) for work, always refuel at the same servo 3 times a week (shell).
Every now and then I'll notice after filling up that it is down on power and it remains that way till the next fill.
I've also noticed when travelling that occasionally a tank of fuel will not give the same get up and go, conversely you can occasionally get a tankfull that makes the old bus purr along.
Last week I refuelled just after the tanker had been, picked up lots of crap and now after draining the tank, flushing the entire fuel system and two fuel filters it looks like a pump and injector service will be required.
It will be interesting to see whether Shell comes to the party, initial reception to complaints has been favourable.
The sample removed from the fuel tank is like dirty milk with a thick brown sludge at the bottom.
AnswerID: 187785
Reply By: Notso - Tuesday, Aug 08, 2006 at 09:09
I have been putting Wollys/Caltex in the patrol for nearly a year I suppose and recently filled up with Shell on a trip, I noticed a jump in my economy of 11.2%. I repeated the exercise with fills of Shell and Wollys and got the same results over the same trip and very similar weather conditions.
I do keep accurate records and my long term average is what I am looking at. I have been using shell for about two months now and the improvement is sitting on around 8.5%
AnswerID: 187801
Reply By: TerraFirma - Tuesday, Aug 08, 2006 at 09:34
I agree, 2 days ago I put some Chemtech Diesel Power in my Hilux (Had some left over from the boat) and so far I am blown away, I will get 720km's from this tank , city driving. To be fair I also got the diesel from a brand new Independent Servo on way to Hastings. Normally I get around 680km's per tank, city drivng combined. The vehicle has clocked 28,000km's so perhaps it has suddenly also loosened up.? I lean towards the Chemtech DP, but I will keep on playing with all of this and recording results.
AnswerID: 187809
Follow Up By: extfilm - Tuesday, Aug 08, 2006 at 18:12
My first tank in my hilux when I got it in oct 03 gave me 620kms. From then on I was lucky to get 550kms per tank. 70% of my fills would only get 450kms. I did a trip from Sydney to Kalgoolie via the Nullabor. Then up to Exmouth via menzies, Meek and Mt Augustus. On the return was via Gunbarrel and Simpson. Still aweful economy. By then the Hilux had almost 30000 kms. My first tank back in Sydney I got 600 for a tank and then 650. was not unusual to be getting 680 and on occasion got 750....... I was incredibly surprised at the sudden overnight change.
FollowupID: 445134
Reply By: extfilm - Tuesday, Aug 08, 2006 at 18:29
Oh yes, I also remember the only fuel that would get me the big k's was bp fuel
AnswerID: 187900
Reply By: sandmanvanman - Tuesday, Aug 08, 2006 at 20:56
THIS IS THE BEST YOU CAN DO . ADD LPG TO YOUR DIESEL , INCREASES OCTAINE AND BURNS CLEAN. I CHANGED THE OIL ONE ONE THAT HAD DRIVEN FROM MELBOURNE TO DARWIN AND IT WAS CLEAN LIKE A PETROL. I HAVE NOTHING TO DO WITH THIS COMPANY , JUST VERY EAGER TO SPREAD THE WORD ABOUT LPG.
www.dieselgasaustralia.com.au/Faq.aspx
AnswerID: 187958
Reply By: snailbait (Blue mntns) - Tuesday, Aug 08, 2006 at 20:56
pauljohnston
maybe BP is using some sort of additive
snailbait
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
AnswerID: 187959
Reply By: Paul Cotter - Wednesday, Aug 09, 2006 at 10:29
Since having this same debate within our industry I decided to do some checking on the web re diesel fuel in Australia. After reading several reports I decided to use BP in our vehicles, Truck, Bobcat and 2 only 4wd dual cab utes. Each vehicle showed 10% better fuel economy and an increase in available power. The increase in power was most evident in the Bobcat.
The reports that I studied indicated that BP diesel was cleaner than most and had a better cetane rating than any of them.
Prior to this I used the no-name type servos because of price.
Paul
AnswerID: 188087
