Hitch trays
Submitted: Tuesday, Aug 08, 2006 at 23:59
_gmd_pps
Are hitch trays illegal in Australia ?
Why is nobody using them ..
Bike Racks are use with up to 4 bikes or so
why no hitch racks ?
any ideas ?
thanks
gmd
Reply By: ro-dah-o (WA) - Wednesday, Aug 09, 2006 at 00:01
Quote "Please explain?" unquote
188020
Follow Up By: _gmd_pps - Wednesday, Aug 09, 2006 at 00:07
explain what ? hitch trays ?
here is a link
accessory-center.com/default.plx/30/5346
hope this helps ..
gmd
445249
Follow Up By: ro-dah-o (WA) - Wednesday, Aug 09, 2006 at 00:11
Thank you.
I own a ute...
but a good idea non the less. Might solve jerry can issues if they are legal.
445250
Follow Up By: _gmd_pps - Wednesday, Aug 09, 2006 at 00:18
Yep , I have a truck but a slide on camper .. so need extra space
when I do not take the trailer..
I would not see any reason why they should be illegal.
I have a similar concept on my motorbike since years
got pulled over many times and never ever did a copper
even look at it ..
I have a truck camper and need space for a generator
etc when I do not have th trailer with me ... so thats an idea
have a look at this
gmd
445251
Follow Up By: _gmd_pps - Wednesday, Aug 09, 2006 at 01:57
sorry meant to post this link
Site Link
regards
gmd
445254
Follow Up By: Member - BBB - Wednesday, Aug 09, 2006 at 05:45
They are available here I think they are only a new concept here their was a stand at the last
Brisbane Camping show,The are also in Trail Bike magazines and when we go to our rides their are a few of them popping up their.
I made one my self when my son was younger and it carried a RM80 may not have been legal but did the job for to years much easier than a trailer.
Contact www.rtcb.net they may be able to help you find the manurfaturer.
BBB
445255
Reply By: Member - Stephen M (NSW) - Wednesday, Aug 09, 2006 at 07:28
Hi there GMD, I presume there legal as I saw one on pennant hills road the other day on the back of a mitsubishi van loaded up to the hilt with bikes and every thing else, my wife and I were wondering what the hell it was as I have never seen one before.Thought it was a home made jobby (may be it was) It didnt look real secure as evertime he took off it flexed back and
forth, maybe incorrectly fitted or had it over loaded, there you go you learn some thing new every day now I know what they are. Regards Steve M
188029
Reply By: Member - Oldplodder (QLD) - Wednesday, Aug 09, 2006 at 07:52
Maybe the first issue is the obscuring of any lights and the number plate?
Workaround on that one, since there should be a plug for trailer lights if you have a hitch point, so have a board with lights like a lot of people do with a tinnie on a trailer.
Maybe 2nd issue is the way the load is carried and whether it overloads the rear
suspension (obviously depends on weight of load) and also possibly lifting the front
wheels off the ground for poor braking and steering control.
Otherwise looks like a good idea for a light load and if you don't have a trailer.
I have a hitch, so I have a trailer,
well two actually, box and CT.
In the past I put the roof rack or board racks on so I can carry long objects over the car, if not through the trailer.
So I don't think I will be buying one.
188034
Reply By: oldmagpie2 - Wednesday, Aug 09, 2006 at 09:10
i think your allowed 1 metre max. overhang, no obstruction on tailights, but every time you need access to the rear wouldnt you have to unhitch & remove?
188055
Follow Up By: robak (QLD) - Wednesday, Aug 09, 2006 at 09:48
Actually I think that max is closer to 600mm (and must have a flag)
445290
Follow Up By: oldmagpie2 - Wednesday, Aug 09, 2006 at 10:04
robak your probably more on the money, but i think it might be different in each state. cheers
445296
Follow Up By: Member - andrew B (Kununurra) - Wednesday, Aug 09, 2006 at 22:24
I recall 300mm, ay be yet another state?
445500
Reply By: Member - Andrew W (SA) - Wednesday, Aug 09, 2006 at 09:36
Having carried three bikes on a carrier on the rear I can attest to the greatly reduced exit angles and the big loads it puts on the
suspension - all that weight sort of cantilevered way out there.
I have seen things like this from time to time - there is one for those electric wheelchairs, for instance, so I don't think they are illegal.
They do take a pounding however and would need to be quite strong for the potential weight that folks put on them - especially jerry cans if that was envisaged.
188064
Reply By: The Fox - Wednesday, Aug 09, 2006 at 10:53
i made a simple one a few years ago out of 3 pieces of weld mesh. Folds up flat against the back of the truck when not ine use. Drops down to form a simple wood carrier for out in the bush. Not wide enough to interefere with lights. Had to move numberplate from center to one side. Very handy. I have a tray top, and the tray gets filled with my Carry-Me-Camper, so no where else for wood. Only used in bush, never been tackled about it and i can't see any problem with it.
Re departue angles: The hinge arrangment allows it to lift up if travelling froward and it its the ground, but is a problem in reverse, especially with the long whell base f250. Not a problem on normal gravel roads, just extreme off road.
188095
Reply By: _gmd_pps - Wednesday, Aug 09, 2006 at 12:04
thanks guys for all the arguments..
this is my solution on my bike ..
http://www.ozshops.com/wing/images/packed.jpg
it was just packed up for the run arouind the corner to the
post office ...
usually I have the eski and tent etc on it when I go cruising
since I have this a long time and it serves me
well I was looking
at the same solution for the truck when I do not have the trailer(boat)
attached. I have a truck camper (slide on) and a boat trailer but obviously
I will not take the boat trailer everywhere and may just go for a few days
or couple of weeks without the boat (mainly inland of course).. so I need
additional space for the Generator and a couple of things ... I also can see
no reason why it should be illegal .. weight on
suspension etc is no issue
here as some pointed out ... I do not necessarily intend to buy one because
they are easily made (like my bike one)
thanks again for all the contributions
regards
gmd
188110
Reply By: lbudgie - Wednesday, Aug 09, 2006 at 17:20
_gmd_pps
i think this is what your looking for.
www.ezimotow.com.au
i got a price last year and they were about $600 - $700 ish from memory.
there are 2 american mobs making them aswell. all 3 look virtuly identical.
am very seriously considering making one myself and think i will save about $500
188173
Follow Up By: _gmd_pps - Wednesday, Aug 09, 2006 at 17:38
thanks
was not really after a specific one .. just in general was wondering why people dont use them that much
here is another example of motorbike ones
Site Link
and yes I think you can make them cheaper yourself..
did that with my motorbike version ..
thanks
gmd
445417
Reply By: Ianw - Wednesday, Aug 09, 2006 at 19:30
I saw one in Geelong a couple of months back. had a ramp and was used to carry a disability scooter. Great idea. Was fitted to a Falcon.
188201
