lpg tuning
Submitted: Wednesday, Aug 09, 2006 at 07:33
ThreadID: 36612 Views:1985 Replies:2 FollowUps:0
im having a hassle with my 100 series on gas, when i start it if it turns straight to gas it stalls, ive had it back to the mechanic 3 times and its still the same, would anyone know what would be causing it and does anyone know a good lpg mechanic around nowra or woolongong nsw.
thanks
Reply By: norml - Wednesday, Aug 09, 2006 at 12:39
Baz
Is it V8 or the 6 cylinder? Gas injection or gas mixer system? Also what brand of gas system
Norm
AnswerID: 188118
Reply By: Member - Tour Boy- Wednesday, Aug 09, 2006 at 12:44
Hi, my 80 does the same thing. When you start it on gas (impco system) it starts on a mixture of pet/ gas. I've found that the petrol only is supplied long enough for it to start then reverts to gas only. However as the system isn't positive pressure, the gas hasn't had quite enough time to make it to the engine causing it to stall. I found that if you start it on pet and switch it overto gas within 3 secs it runs and doesn't hiccup. The last 3 gas vehicles I've had won't idle properly untill they've been driven a few hundred metres. I just use the hand throttle. Yhese were 3 different systems. No one could fix. Better to start it on pet as there is less chance of backfire blowing the airflow sensor.
Hope this helps.
Tour Boy
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 188120
