AGM Batteries
Submitted: Wednesday, Aug 09, 2006 at 20:07
phillowe
Hi There,
Has anyone had any dealings with "power sonic" AGM batteries???
If so what are your experiences????
Reply By: TerraFirma - Wednesday, Aug 09, 2006 at 20:12
No experience with Powersonic, sounds like they are sold in 25 countries. Within these forums Fullriver are recommended as popular along with Remco but I see no reason why the Powersonic wouldn't be any good. The best way to get what you want is to establish your AH rating , application etc and
shop it around via the major brands.
188215
Reply By: TerraFirma - Wednesday, Aug 09, 2006 at 20:28
Just came across the Fullriver 12v 120AH AGM battery for only $208, now that is very
well priced.
Site Link
188220
Follow Up By: Member - Scott M (NSW) - Wednesday, Aug 09, 2006 at 21:17
I got my HGL120 from LMC in
Newcastle for about $280 - dang terra, that's a good price !!!
However, I can't recommend LMC www.lakecomm.com.au/ highly enough - great service, great advice - nice guys.
445481
Follow Up By: fruers - Thursday, Aug 10, 2006 at 11:17
Also remember that Gee-Tek prices don't include GST and have pretty hefty shipping charges. Still good prices but worth keeping in mind.
Jonathan
445576
Follow Up By: TerraFirma - Thursday, Aug 10, 2006 at 11:30
Yes good point Jonathan however in this instance total price was $235.08 Inc GST delivered free to Port
Melbourne or
Melbourne as agreed by Keerin Black. So very happy as my remco 100ah cost me $269 and I had to pick it up.
445579
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Aug 09, 2006 at 20:59
Powersonic are Ok.
I sell Vision and Supercharge.
Both are very good.
Check the warranty when buying but most AGM's are good.
Regards Derek.
188231
Follow Up By: phillowe - Thursday, Aug 10, 2006 at 10:30
Hi Derek,
Hope you can answer a question for me.......can AGM batteries be used for cranking? It seems everyone I talk to has a different view on this. I will only be using it to start a RAV4 so I would think the load would not be that great. Many people on the
forum here say they use them to crank without a problem. The main reason I want to go this way is so I don't have to go down the path of a dual battery system.
What is your opinion??
445567
Follow Up By: Member - Mike DID - Thursday, Aug 10, 2006 at 11:20
Have a look at the CCA (Cold Cranking Amps) rating for the AGM - make sure it is at least as big as your existing battery.
445577
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Aug 10, 2006 at 11:29
Most are around 900 cca. Rav 4 no problem.
445578
Follow Up By: phillowe - Thursday, Aug 10, 2006 at 11:36
Hi Derek,
I have been looking at the PS-12750 see data sheet www.power-sonic.com/ but it does not have a CCA rating, although it say it will deliver 750 amperes for 10 sec or 225 for 7 minutes which makes me think this would be fine....humour me if I am wrong in assuming this :-)
445581
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Aug 10, 2006 at 11:41
Yes that sounds right for a 75 a/h battery.
My 90 a/h ones are 900 cca
445582
Follow Up By: phillowe - Thursday, Aug 10, 2006 at 11:42
So let me see....the figures I stated (750 amperes for 10 sec) equates to 750 CCA??
445583
Follow Up By: Member - Mike DID - Thursday, Aug 10, 2006 at 11:55
CCA is defined as "the amount of current a battery can provide at −18 °C for 30 seconds and maintain at least 7.2 volts".
The capability of a battery drops to about half at this temperature, so a battery rated at 900CCA would be able to deliver closer to 1500 amp at 25 degrees.
445586
Follow Up By: phillowe - Thursday, Aug 10, 2006 at 11:59
So does this mean the battery described above will have no issue cranking the RAV???
445587
Follow Up By: Member - Mike DID - Thursday, Aug 10, 2006 at 12:05
I suppose the RAV4 would actually draw around 100 amps on starting, so the battery will certainly start it, without shortening its life drastically.
All this means is that when the battery gets old and it's -18 degrees, it won't work as
well as a Starting Battery :-)
445590
Reply By: TerraFirma - Thursday, Aug 10, 2006 at 10:46
You can buy the hybrid AGM batteries which are a cross between a cranking and deep cycle battery. The Optima Yellow and Bluetop are an example of this, otherwise you can get 800-900 CCA from various 120AH AGM's I have seen.
188315
Reply By: TerraFirma - Friday, Aug 11, 2006 at 16:58
The Fullriver HGL-120B 120AH battery is 750CCA according to Fullriver Taiwan who thankfully replied to an email. I think no one wouldbuy this battery as a starter however it's always handy to know how much cranking capacity you have.
188563
Follow Up By: Alloy c/t - Friday, Aug 11, 2006 at 17:25
No one would buy it as a starter ,, maybe maybe not , I use a Fullriver 80amp AGM HGL as the starter in our 80 series turbo diesel , been in there for the last 2yrs and never a problem. The written/factory specs are not always the be all and end all in "real" use.
445813
