Electric Brake Controler & UHF
Submitted: Friday, Aug 11, 2006 at 09:49
ThreadID: 36681 Views:2689 Replies:7 FollowUps:3
Instructions that came with my electric brake controller says that the unit should not be placed within 12 inches of any UHF. Problem is that there is really only one place to mount the controller. Does anyone know of problems relating to mounting the controller about 4 inches away from the UHF?
Reply By: Member - Brian (WA) - Friday, Aug 11, 2006 at 11:17
Hi . Mine is not 12 inches away have not noticed any differance
AnswerID: 188499
Reply By: Member - Mike DID - Friday, Aug 11, 2006 at 12:24
The manuafacture is playing it safe. If the controller has problems near a 5 watt FM transmitter they should improve their Electromagnetic Compatibility design.
Make sure that the UHF Coax Connector is very reliable or you can count on problems.
Put a Ferrite Sleeve over the power leads to the UHF and to the Brake Controller for additional confidence.
AnswerID: 188521
Reply By: Dave Thomson - Friday, Aug 11, 2006 at 15:03
Hi all,
while we're on the subject is it normal for the red light on the controller not to come on sometimes when your foots on the brake {not connected to the van} its a tekonsha voyager {newish} ?
regards,
AnswerID: 188547
Follow Up By: Shaker - Friday, Aug 11, 2006 at 17:14
It shouldn't come on at all when it's not connected to the trailer.
FollowupID: 445808
Follow Up By: Patrol22 - Saturday, Aug 12, 2006 at 08:46
Interesting that ....my Redarc controller shows red at all times when braking - trailer hitched or not. When the trailer is connected I get a green light that stays on all the time and the red shines through when braking.
Been like this since being fitted by reputable auto sparky.....it is wrong??
FollowupID: 445903
Follow Up By: Jimbo - Saturday, Aug 12, 2006 at 15:00
I've got a Tekonsha Voyager and the light never comes on when the camper is disconnected. Something's wrong Dave.
FollowupID: 445942
Reply By: itsdave - Friday, Aug 11, 2006 at 20:25
If its the voyager with the grey label on the front as opposed to the purple one the unit is faulty. I had one and had a hell of a time getting someone to replace it. Ended up with Tekonsha USA finding someone that would help and ended up replacing it with a prodigy. Best move I made. Best do a search on here as there is plenty about the voyager
Cheers Dave
AnswerID: 188584
Reply By: nisso - Friday, Aug 11, 2006 at 21:08
Its ok mine does that as well ,always has.When you first put your brake on it comes on bright and then fades.
AnswerID: 188594
Reply By: D-Jack - Friday, Aug 11, 2006 at 21:21
Oh no! Just installed my Prodigy right below the UHF. Hoping when transmitting it doesn't lock the brakes up on a corner on gravel! Is separated only by a colsole shelf! What are the implications if there is interference. I wasn't thinking about brake interferenc, only that braking might interfere with RF!
D-JAck
AnswerID: 188598
Reply By: nisso - Saturday, Aug 12, 2006 at 22:09
Thats ok, just aviod saying STOP on the UHF.(joke joyce)
AnswerID: 188725
