I somewhat reluctantly enter the minefield of 4wd tyre pressure.
For 15 years I have operated an agricultural boom spraying business with a couple
of diesel hiluxs. For about 10 of those years I threw away about 100 tyres, staked,
or sidewall blowouts due to sticks & rocks etc. This happened to every type of tyre
I used on a fairly regular basis, expensive Coopers & el cheapos were all treated
with the same distain by the rough country travelled over. At that time I operated
at 35 to 40 psi (sorry for psi but I'm too old to figure that new stuff). Some said
that was too high but with 800 litres of
water & another 700 kg of sprayrig I thought I needed at least that much pressure.
One day about five years ago,
as I chucked another 2 hour old tyre away, I got mad & pumped them up to 60 psi.
& , you guessed it, Ive hardly thrown a tyre away since. I use Firestone Firehawks
on 15 by 8 rims. Now I know this flies in the face of all the "expert "advice but it
has saved me thousands of bucks because it works!! And yes the hilux has
uprated springs. One more thing as I duck for cover..I dispute the advice I've
seen in this
forum re letting your trailer tyre pressure down to that of the towing
vehicle in sand etc. You fill your wheelbarrow up with
water,push it around with
a tight tyre,then let the tyre down & push again & tell me I'm wrong.
