ARB compressor under bonnet of gu
Submitted: Friday, Aug 18, 2006 at 17:55
Member - Vincent A M (NSW)
Has any one fitted the ARB Small Air compressor (diff lock type) under bonnet of 2004 gu fitted with 4.2 td with intercooler & duel Battery's as its crowded in there & i don't want to fit it under the
seat as some times you get the oil blow back smell, 90 grade stinks
Reply By: Member - JohnR (Vic)&Moses - Friday, Aug 18, 2006 at 23:15
Vincent, not sure if yours is the same as
mine, but a coil cab chassis I have my ARB compressor where some have the anti lock brake setup is on some of the others. I mounted a little plate in there on original bolt holes. Not at home at the moment to send a picture but it is in the engine bay! Intercooled and dual batteries too. Twine shower and all.
189735
Reply By: Member - John - Saturday, Aug 19, 2006 at 11:29
Vincent,
Mine is fitted in the Right hand rear corner looking at it from the front, Ute, 4.2 I/C, dual batteries, if you like I will take a pic and email it too you. John
189758
Reply By: Member - Errol (York WA) - Saturday, Aug 19, 2006 at 18:47
Same place as John . Just need to make a plate to mount it on . Errol
189800
Reply By: Member - Andrew W (SA) - Sunday, Aug 20, 2006 at 18:13
saw one today in a GU-III - it is mounted in a very crowded spot on the guard close up to the firewall in front of the passenger - I have no idea, but would not be surprised to find something needed moving or re-routing.
Ciao for now
Andrew.
189905
Reply By: Peter McG (Member, Melbourne) - Sunday, Aug 20, 2006 at 21:41
Mine's fitted drivers side tucked in the corner near the window in front of the battery.
189967
