time gentllemen please
Submitted: Friday, Aug 18, 2006 at 18:29
ThreadID: 36893 Views:2088 Replies:4 FollowUps:2
Not 4x4 but time is /can be a mater of importance in exploring Aus or anywhere else for that mater ,query is my computer time/clock reads wrong ,is set at brisbane =gmt+10hrs as per puter windows tells me to do , if 6pm on puter clock real time by phone / tv / radio all 6:6 or 6:10 ,get the picture ?how do i fix the computer clock to be inline / right time ,as I post this my clock says 6:19
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Friday, Aug 18, 2006 at 18:36
Alloy, i just clicked on the time at the bottom of my screen & up popped the clock,calender showing time zones. Maybe the same as you'res or different.
Bob.
AnswerID: 189687
Reply By: GaryInOz (Vic) - Friday, Aug 18, 2006 at 18:45
Assuming you want to "fine tune" the time (+/- a couple of minutes or so)
Right click over the time in the lower right hand corner of the screen.
Left click on the "Adjust Date/Time".
Position mouse over the minutes (under the clockface) and left click to highlight the two digits.
Use the up/down arrows to the right of the time to increment/decrement as required.
left click "Apply" and "OK"
This can also be done to any other parameter of the clock settings (hrs, date, month, AM/PM, etc)
AnswerID: 189691
Follow Up By: gbdid - Friday, Aug 18, 2006 at 19:57
There is a program called "about time" which when installed and used will automatically update your time to the second.I googled it and then downloaded and installed and use it occasionally to reset the computer time.I think the site is www.arachnoid.com
FollowupID: 447171
Reply By: dublediff - Friday, Aug 18, 2006 at 23:24
I think it is probably your computer clock out of sync with your software clock. You have to go into either the bios or cmos settings of your puter to set the clock as well.
AnswerID: 189737
Reply By: Notso - Saturday, Aug 19, 2006 at 18:36
Time synchronisation is available in Windows,
Go to Cotrol Panel Date/Time and then click on the tab Internet Time and tick the box marked automatically synchonise with an internet time server, you have a choice of two different time servers.
AnswerID: 189799
Follow Up By: MrMagoo - Sunday, Aug 20, 2006 at 02:04
IF you have XP operating System then what Notso says is true. If your time is wavering then this could indicate the CMOS battery is beginning to fail. Beware - If you remove the CMOS battery then the settings in CMOS will be lost. (the bit on the Mother board that tells the computer that it isnt an empty box). Either take it to a PC repairer to replace the battery - or if you are confident you can buy and install an external battery and connect it to the appropriate pins on the mother board -this allows you to then remove and replace the battery (the silver thing that looks like a 10c piece). OR put up with it (IF it IS the battery then one day it will die and the computer will just blink at you when you turn it on.
FollowupID: 447330
