Tyre wear, tyre life, 750/16, 215/85/16, 205/16
Submitted: Wednesday, Aug 23, 2006 at 03:04
ThreadID: 37024 Views:7545 Replies:7 FollowUps:12
Hi Guys, what kind of mileage are you getting out of your tyres?
Please share any information on your experience with different brands?
Any information about the above sizes appreciated?
Which ones you prefer and why?
What mileage did you get with them?
Note: Needless to say a lot depends on way of driving, but the average life on car tyres is about 60 000km, while on trucks it is 150 000km?
Reply By: Member - Andrew W (SA) - Wednesday, Aug 23, 2006 at 08:10
average rolling circumference of a car tyre is ... and a truck tyre is ...
typical compounds used in car tyres is ... and truck tyres is ...
you drive your truck like you drive your car, or do you want your car to handle like a truck?
This question is extremely dependent on what you do and where you take your vehicle - how fast your drive, what inflation you use and how well you monitor it, how frequently you rotate them, what sort of roads or tracks you travel on, what loaded weights you carry etc.
What do you wish to know about the sizes above?
I prefer Cooper STTs for my truck and what I do, but they probably won't suit you.
I don't know what mileage I will get, but my ATs were taken off at 72ks and still have 10ks or so left in them.
AnswerID: 190462
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 09:03
Oh, if I haven't made it clear, I apologise, I always get the correct pressure and rotation....
On off road ration is 50/50.
Average speed between 75k/h to 110k/h ... Does that sound average enough for you?
Average load 2 people plus 500kg of gear.
No trailer.
Have you had experience with the 750/16?
FollowupID: 448103
Follow Up By: Member - Andrew W (SA) - Wednesday, Aug 23, 2006 at 10:57
I have run for quite some time on LT285/75R15
500 kg of gear is not much - what vehicle?
FollowupID: 448130
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 11:07
Hi Andrew,
It's a Nissan Patrol MQ, SWB, L28 motor
FollowupID: 448131
Follow Up By: Rick P - Thursday, Aug 24, 2006 at 12:19
Hi Andrew, still waiting on your reply,
After all the questions, a preaching of no such thing as average, a very common word in the English language.... your feedback is missing?
How Typical !!!
FollowupID: 448362
Follow Up By: Member - Andrew W (SA) - Thursday, Aug 24, 2006 at 13:37
um - what more did you want to know?
I am good for LT285/75R16 (previous R15 was mistake) on my much heavier HZJ105R (usually travelling 3200-3500 kg) with paranoid approach to inflation with Cooper ATs (old ATs not ATRs) to 80,000km approx - I've not had the STTs for long enough to know.
I am a careful driver, but do a big mix with about 50% dirt/50% highway including significant hard work (High Country; Nullarbor etc.) - not very average compare to most folks.
Usually truck compounds are much harder, the tyres larger, the tread patterns deep and straight - mostly designed for long straight roads.
Car tyres on the other hand, esp. off-road tyres are generally softer, the tyres smaller, the tread patterns are more complex for grip on corners, rocks etc - general car handling requirements.
All in all, there are lots of reasons not to expect truck tire like life.
Ciao for now
Andrew preaching typically.
FollowupID: 448382
Follow Up By: Rick P - Friday, Aug 25, 2006 at 17:46
I know all about tread pattern designs on various tyres as well as tyre contraction.
What I didn’t know is that you got 80 000 out of yours, that is what I needed to know. Thanks,
Bar the Indian speeches.
FollowupID: 448692
Reply By: Member - MrBitchi (QLD) - Wednesday, Aug 23, 2006 at 08:12
Cooper AT's 265/75/16 58K so far. Got about 5mm tread left so should be legal for about another15/20K.
AnswerID: 190463
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 09:06
thanks mate, this is what I was guessing most people would be getting, around the 80 000km mark... give or take a few.
FollowupID: 448104
Reply By: Nick R - Wednesday, Aug 23, 2006 at 08:31
Our GU had Nexen 265/70/16s (apparently AT tyres, more like HT I think) on when we got it, done 19000 so far and they are about 1/2 worn, I think I will go for a name brand next time....
I suppose they were on so the dealer could get the car out the door for not too much cost.
NickR
Carpe Cerevisi
AnswerID: 190467
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 08:55
I've got the Kumhos At 235/85/16, which fit on the standard split-rims, my Patrol is done 80 000km with them and I think it will go safely to 100 000km, maybe more.
They're very good all-around tyre, good off-roaders too.
Of course I check the pressure on weekly basis and I rotated them more or less every 10 000km... or so.
FollowupID: 448101
Reply By: Member - Blue (VIC) - Wednesday, Aug 23, 2006 at 10:24
225/75-16 on Mitsu Triton, approx 65,000km and 7mm tread left, should comfortably see 100,000km... About 80/20 off road on these...
AnswerID: 190493
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 11:13
Thanks Blue, spot on mate!
FollowupID: 448133
Reply By: Member - Phil G (SA) - Wednesday, Aug 23, 2006 at 11:49
Rick,
750R16 are a tube type tyre - so are only used on split rims. Mostly good for 35-50k each. Because of the tubes, they build up heat and wear quicker.
The 215/85R16 is an uncommon size - only available in a couple of brands - Toyo are one of them. Usually fitted to 6 inch rims on lighter vehicles like the 90series Prado - mileage i'd guess to be 40-50k, because they tend to scrub out on these vehicles.
the 205R16 are commonly fitted to both split and tubeless rims. Diameter is smaller, and tend to go on vehicles like the Hilux, and old jackaroos etc Again, about teh same mileage.
The wider tubeless tyres, say 265/75R16 will give you greater mileage than the 3 sizes you've mentioned.
AnswerID: 190508
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 12:58
Thanks mate, I didn't know that about the 750/16's... I would've thought they would last as long as the more popular, fatter tyres, speaking of which, I've got Dunlop Super-Gripper in 750/16 on the rear, will see how it goes...
FollowupID: 448155
Reply By: friar - Wednesday, Aug 23, 2006 at 12:35
G/Day Rick P got 215/85 R16 cooper st on a hilux done 40000 thousand ,probably about 20000 left in them ,rotated about every 5000th,half this done off the black stuff.
Friar
AnswerID: 190513
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 12:59
Thanks mate!
FollowupID: 448156
Reply By: Michael ( Moss Vale NSW) - Wednesday, Aug 23, 2006 at 14:41
265x75 16, BFG's current tyres 120,000 k's. My Patrol has 180,000 on the clock and changed them at 60,000. They are good for another 10,000 yet at least. OH!! Only one puncture in that time.. Michael
AnswerID: 190527
Follow Up By: Rick P - Wednesday, Aug 23, 2006 at 23:25
Now that's impressive, well done, thanks for sharing your experience!
FollowupID: 448288
