GQ longrange
Submitted: Monday, Aug 28, 2006 at 22:15
ThreadID: 37211 Views:2001 Replies:2 FollowUps:2
GQ long range fuel tank
Hi Folks, I have a 95 GQ fitted with a long range fuel tank, this is all good except for the concept of the transfer pump and the mucking around with it. The question I have is it possible to switch from the original pump and sender unit to the auxiliary pump and sender unit. By putting a Y section in the delivery line and installing check values (to stop any possible siphoning)?
Any replies or ideas gratefully accepted.
Reply By: Member - Roachie (SA) - Tuesday, Aug 29, 2006 at 08:23
G'day mate,
Okay I'll bite.......
I looked at your post last night and decided I was too confused to respond.
You say: "I have a 95 GQ fitted with a long range fuel tank, this is all good except for the concept of the transfer pump"..............
Please help me out here (I'm on the wrong side of 50 and am slow to grasp concepts). You make no mention of having a 2nd tank, so I'm left wondering as to why you need a "transfer pump". Where are you transferring the fuel to/from? AFAIK the GQ never came out with 2 tanks, but it is possible that you've fitted an AUX tank, but haven't mentioned it.
As Pauline once said....."Please explain"......;-))
AnswerID: 191599
Follow Up By: Old Beasty - Tuesday, Aug 29, 2006 at 09:14
Sorry, your right after rereading not enough info (I know what I mean :) )
The auxiliary tank is a after market model that has been added, the set up as it is now:- two filler necks one to the original and one to the aux, a breather line from aux to filler neck and an outlet to a transfer pump that goes in the original. From there, when I am running low on the original I have to switch the transfer pump on to pump from the aux to the original. I also have another switch on the dash that switches from the level sender unit in the aux to the level sender unit in the original so I can see how much is each tank.
As you can see this is very clustered, I hope someone can give me some advice on how to simplify things
Craig
FollowupID: 449406
Follow Up By: Member - Roachie (SA) - Tuesday, Aug 29, 2006 at 09:59
G'day Craig,
The set-up you describe is virtually identical to that used as standard in the GU....and as far as I'm concerned it works really well. The only difference is that you have only one gauge ; switchable between the 2 tanks.....which sounds quite okay to me.
However, I understand that Toyota Landcruisers (for example) use a system whereby there is a dashboard switch which physically isolates one tank or the other. That system also works quite well apparently.
I'm not sure I'd bother changing the current system if it's actually working okay. It is nice and simple with no solenoids (I think that is what Toyotas use to switch over) to go kaput. The worst thing that can go wrong with your set-up is that the pump could stuff up.
By the way, on the GU, the transfer pump pumps the fuel back up to the top of the neck of the filler for the main tank.....open the filler cap when you've got the transfer pump switched on and you can see the diesel coming out of the pipe. Not sure where your's pumps into......if it's the tank itself there could be an issue with air lock or something (but I wouldn't have thought so).
Hope this helps......my advise; if it ain't broke, don't fix it......
Cheers mate
Roachie
FollowupID: 449416
Reply By: Gerry - Tuesday, Aug 29, 2006 at 17:44
Hi old beasty,
I had a similar setup when I had a GQ and bought a motorised two way valve designed especially for this purpose. It has 6 ports, 3 for the flow and 3 for the return. A 2 way switch in the dash drives the valve so it will pick up and return to either of the 2 tanks. The valve was around $200, but that was a few years ago now. Bought it from my local 4wd service guy, but I'm sure ARB or similar would know of them.
Gerry
AnswerID: 191675
