Fridge on Camper Trailer A-frame
Submitted: Saturday, Sep 02, 2006 at 10:43
ThreadID: 37337 Views:11062 Replies:5 FollowUps:14
I'm in the process of re-configuring my vehicle and trailer setup.
One of the suggestions I've received is to consider mounting - accommodating the fridge on the drawbar.
The trailer is designed for light to medium off-road work and has a 100 x 50 RHS drawbar.
I can see that a lot of the commercially available trailers (mine is a box trailer - 7 x 4 - galvanised, with a name brand soft floor tent retro-fitted) have provision for the fridge in an enclosure - on the drawbar.
I'd be interested in anybody's experiences and or opinions.
Brian
Reply By: Member - Robyn J (QLD) - Saturday, Sep 02, 2006 at 13:20
We thought about that with ou trailer but in the end left in the car. To carry the frig you have to have a large box which when loaded with fridge puts a lot of weight on the drawbar and inturn weight on the tow ball. We put an aluminium box on ours but only carry light stuff in it like buckets, tarps ropes Cobb etc expecaily as we also on some trips have the boatmotor on the front. When the motor is on the front we well on our towball weight.
AnswerID: 192317
Follow Up By: Member - Roachie (SA) - Saturday, Sep 02, 2006 at 13:51
Agree with Robyn, it's all about ball weight (although with the fridge in the back of the wagon, you've still got that much weight on the back axle I guess).......as well as what's good for the fridge itself. It's gunna get a pretty rough ride on the drawbar and you'd need to make sure you had a sturdy and DUSTPROOF box for it to reside in.
FollowupID: 450169
Follow Up By: Brian - Saturday, Sep 02, 2006 at 14:22
Robyn J.
thanks for your feedback.
In my case weight shouldn't be an issue, as the fridge would be replacing - weight wise on the draw bar - 2 x 20 litres of water, which can be more easily accommodated in the rear of the 100 series, without giving up 2 seats - there is six of us, plus on occasions, one or two of the kids mates.
As Roachie has mentioned below, I think the real issues are with dust, probably water and maybe vibration.
Brian
FollowupID: 450172
Follow Up By: Brian - Saturday, Sep 02, 2006 at 14:27
Roachie,
I agree re the location of the weight - maybe 6 of 1, half dozen of another.
Do you reackon it would be a much rougher on the draw bar? Interested in your opinion.
The Penrith camping show - western Sydney - is on in a couple of weeks. Probably do more research then before deciding.
Brian
FollowupID: 450173
Follow Up By: Shaker - Saturday, Sep 02, 2006 at 15:05
Quite a few commercially available camper trailers have the fridge situated in a special enclosure on the draw bar, from memory I think they have filters on the air vents.
FollowupID: 450179
Follow Up By: Brian - Saturday, Sep 02, 2006 at 17:11
Thanks Shaker.
I wonder how they manage the air circulation for the heat generated from the compressor, with regards the air in and out. As you say, must be some serious filters.
Shall check it out at the Penrith show.
Brian
FollowupID: 450191
Follow Up By: Member - Roachie (SA) - Saturday, Sep 02, 2006 at 19:07
G'day Brian,
I would imagine there may not be too much difference (between being on the trailer or in the 4by), if the trailer is fitted with coil springs and shockers. If it's a 7x4 box trailer (as described originally), I tend to think it's probably got leaf springs and no shockers....so the ride on the draw bar or any other part of the trailer could be quite harsh. However, if a sprung base (like what Engel sell for their fridges), that would cover that problem.
Roachie
FollowupID: 450203
Follow Up By: Brian - Saturday, Sep 02, 2006 at 20:57
You've pretty well got it in one Roachie. Leaf springs and no shockies.
As I'm in the process of modifying the draw bar - as we speak, I'll make an allowance to fit the fridge, and decide at a later date, as to what will actually go in the space - fridge, jerry cans and gas bottle, or whatever.
I'll do some research on the "sprung bases", and go from there.
Thanks Roachie,
Brian
FollowupID: 450226
Reply By: outback epicurean - Saturday, Sep 02, 2006 at 21:25
Hi, my comment would be that we prefer to have the fridge in the car, as its a long way back to the trailer when you need a cool drink.
AnswerID: 192389
Reply By: spliney - Monday, Sep 04, 2006 at 17:34
Have mounted a 60L Trailblaza in an alumininium box on the draw-bar of my Trackabout CT.
Clearly it does impact on drawbar weight, but for us with mobs of kids, not much alternative.
I fitted inlet and outlet vents to the box, to keep it cool. Outlet vent has a 12V computer fan fitted as an exhaust fan. Inlet vent has a Briggs & Stratton lawn-mower airfilter to keep the dust out.
I also glued 15mm insulation foam under the lid of the box.
4X internal tie-down points keep the fridge in one place.
Spliney
AnswerID: 192734
Follow Up By: Brian - Monday, Sep 04, 2006 at 21:51
This is great Spliney. Sounds like we have a similar setup with head count.
The 12v fan is a great idea - have a few of those from old PC cases - new units aren't much anyway.
I'm not very familar with the B&S mower. Is the filter a flat unit that mounts flat up against the box? Where did you score the insulation foam from? What faces of the enclosure do you have the filter and fan mounted to - front, rear or side?
Lots of questions, but your feedback has been most welcome.
Brian
FollowupID: 450651
Follow Up By: spliney - Tuesday, Sep 05, 2006 at 06:28
Brian
The foam came from Clark Rubber: silver-foil backed. Comes in a range of thicknesses and can be purchased by the metre. I used "liquid nails" style of glue to fix it to the underside of the lid, foil-side glued to lid.
In terms of vents, the camper was delivered to me (new) with a vent cut into the upper rear face of the box with a louvre-style stainless cover rivetted to the outside. I bought a 125mm ball-bearing equipped computer fan (I think about $30), a switch and a fuse. I mounted the fan over half of the vent and blanked off the other half with an aluminium off-cut. Wired it back to the on-board battery.
I went to a mower specialist and asked for the slimmest air filter he had. He came up with one about 15-20mm thick, in two parts - a foam pre-filter and a paper cartridge.
I cut an inlet in the lower front side of the box - diagonally opposite the outlet. Mounted a louvre style cover on the outside. Trickiest bit was fabricating up a retainer on the inside to hold the filter in place. I started with light aluminium angle and bent one face at right angles to form a "zig-zag" that I rivetted in place on three sides of the vent. The filter slides into the resulting bracket from the top.
We just did a trip to the Diamantina including 600km of dust. This setup worked well.
My fridge is the one Tim refers to below. The manufacturer is quite happy for it to be mounted straight to the draw-bar! However I'm much happier having it in the box! The other thing I did was cut three pieces of timber (batten size running front-to-back of box) and with a strip of rubber glued to the top. The fridge sits on these. Two reasons - allows air to pass under and provides a little cushioning.
We carry an evakool icebox in the trailer as our "fridge" and use the Trailblaza as our "freezer". No broken eggs - in fact no evidence that anything had bounced around at all.
Overall, tho not ideal for weight distribution, I'm happy with it.
Hope this helps
Spliney
FollowupID: 450691
Follow Up By: Brian - Tuesday, Sep 05, 2006 at 21:14
Thanks heaps for all the detail Spliney, as I have a pretty clear image of how you've done it. This is extremely helpful.
As suspension has been mentioned a few times, what is your camper fitted with, coils or leaf, with or without shocks?
Thanks again
Brian
FollowupID: 450848
Follow Up By: spliney - Wednesday, Sep 06, 2006 at 08:49
Mine is 7 leaf shackle-shackle rebound springs, no shocks.
FollowupID: 450904
Follow Up By: Brian - Wednesday, Sep 06, 2006 at 20:33
Thanks for that.
Safe travels.
Brian
FollowupID: 451050
Reply By: Member - Tim - Monday, Sep 04, 2006 at 23:28
When I was at one of camping shows in Brisbane I was talking to one of the fridge manufacturers, I think it was trailblazer but may have been explorer. It was one of the ones that have a really solid alloy fridge that can actually be done in chequerplate alloy. Anyway they said that it could be carried on the drawbar without a box and it would not have any issues. I specifically asked about if the dust would damage it and they said not at all, just blow it out when it got home. I suppose as long as you kept the rocks away from it it would be fine. I actually have a three way Chescold fridge that I sit in the boot on 12 volt so I don't speak from experience, just what they told me.
Tim.
AnswerID: 192852
Follow Up By: Brian - Tuesday, Sep 05, 2006 at 21:26
Thanks for your comments Tim.
Sounds like a fairly robust fridge.
If I wasn't a bit short on space, the back of the cruiser would be the prepared option. Spliney's setup sounds like it works quite well.
Thanks again for your input.
Brian
FollowupID: 450853
Reply By: Member - Geordie C (WA) - Tuesday, Sep 05, 2006 at 01:13
Brian
I tried the fridge on the drawbar trick and got scrambled eggs mixed with burst beer cans. That was with an Engel sprung travel base in a front box on a leaf spring trailer(and a few km of Pilbarra corrugations).
If you want to travel rough roads and do not have a nice coil sprung trailer with shocks then my advise is keep the fridge in the car and put other stuff in the trailer.
AnswerID: 192859
Follow Up By: Brian - Tuesday, Sep 05, 2006 at 21:32
Thanks Geordie.
It appears that it may have a lot to do with the type of suspension setup.
Don't normally have my eggs with a beer. Prefer a few rashes of bacon and a mug of billy tea.
I asked the kids whether they'd travel in the trailer. Got a mixed response.
Brian
FollowupID: 450855
