406 mhz EPIRB
Submitted: Saturday, Sep 02, 2006 at 18:00
ThreadID: 37349 Views:5795 Replies:11 FollowUps:33
In 2008-2009 EPIRBs are supposed to be changing over to 406mhz.
The only 406 ones I can find now are marine ones. Shops still sell the old ones which will be useless in a couple of years. I was going to get one for outback travel.
For those that do travel with an EPIRB do you have the old or the new?
Is there any such thing as a personal EPIRB on 406 mhz other than the marine variety that of course are made to float upright etc and over kill for the job.
The marine ones seem to be $500+ while the personal ones are about $250
All I want is an EPRIB to carry in vehicle out west but not superseded in a couple of years.
Reply By: Member - andrew B (Kununurra) - Saturday, Sep 02, 2006 at 18:20
Gday Alan
As far as I am aware, the old style will still work and still get picked up for quite a while, the newies will become law for Marine use. The 406 gives info on the registered owner and an exact location of the unit, wheras with the old info is there is someone out there within about 50 odd km of 'x'.
I will gladly stand corrected on this info, its all from the memory bank!
Cheers Andrew
AnswerID: 192353
Follow Up By: Member - Mike DID - Saturday, Sep 02, 2006 at 23:37
406MH epirbs will only transmit their exact position if you buy the GPS option and have it connected to a gps.
without GPS they will still be more accurate than 121.5.
FollowupID: 450249
Reply By: lewjack1 - Saturday, Sep 02, 2006 at 18:53
alan
you should find that even that they call them marine epirbs, they will cover all of aust, land or sea, with the footprint covering all of aust(area of aust covered by satelite)being the factor
one big thing i must say is, do not activate these epirbs unless in grave danger, and if so do, not turn them off untill rescued
have a great day
lewjack1
AnswerID: 192361
Reply By: Member - Andrew (QLD) - Saturday, Sep 02, 2006 at 18:59
Alan,
If you really believe that you need a Epirb for emergency backup, then it should go without saying that you shouldn't compromise on the type you purchase. Go for the 406Mhz variety and be done with it. :-)
AnswerID: 192363
Follow Up By: Member - Andrew (QLD) - Saturday, Sep 02, 2006 at 19:10
BTW, ACR Electronics make a Personal Locator Beacon (PLB) which is probably what you would be wanting. Check out www.acrelectronics.com/terrafix/ for details of their "land" version or search their site for the aquafix version. They (aquafix) retail about $700 at whitworths etc (non GPS version).
FollowupID: 450205
Reply By: kimprado - Saturday, Sep 02, 2006 at 20:00
Hi Allen,
Your probably missing the point a bit (please don't take this as a criticism).
I was recently involved in an endeavour which saw both myself, a stockman and a long term local "bushed" in an isolated area of WA.
Between the three of us we've had over a 100 years of experience in the bush.
That experience eventually overcame the problem. However, it could have easily gone the other way.
Don't worry about the cost of an EBIRB. Until you're gone through the experience, you will never understand the value of these units. Once your in that position money means nothing!
Hope this helps
Kim
Kim McFarland
Phone/fax (03) 97821702
Mobile 0409213403
e-mail kimmc@satlink.com.au
Bus Phone 97055467
Bus e-mail kmcfarland@casey.vic.gov.au
AnswerID: 192375
Follow Up By: Member - Mike DID - Saturday, Sep 02, 2006 at 23:40
Yes Kim, it's unfortunate that many people have no idea how to prepare for the unlikely event of an emergency.
It's like saying "the chances of my house burning down are a million to one - why should I waste money on insurance against such an unlikely event"
FollowupID: 450250
Reply By: Footloose - Sunday, Sep 03, 2006 at 00:30
Hi Alan. I carry all the comms I can, but my older style epirb is always close at hand in the bush. It's my last line of defence. Even with the new ones coming in, the older ones will still be useful for a while.
If you're on a budget you can usually pick one up s/h, or even rent one for the big trip.
A new one will be the bees knees, but even the older one is better than nothing.
The older one will even travel in a shirt pocket, or on the belt, and is very light.
As they say, "don't leave home without it".
AnswerID: 192408
Reply By: Kiwi Kia - Sunday, Sep 03, 2006 at 09:30
The only difference between land and marine use could be the means of activation or its resistance to water ingress.
Some epirbs that are designed for marine use switch on automatically when imersed in water and some switch on automatically when removed from their mounting bracket. I would suggest that an emergency beacon that is activated if it comes out of its cradle or gets wet is prob not a good idea in a 4wd.
Some of the sattelites that recieve the signal from 121.5 MHz epirbs ("old" type) are being decommissioned in February 2009 - thats only about 120 weeks from now! The use of 121.5 MHz epirbs may even become illegal not long after that date as they cause to much trouble and expense for rescue services (especially in the USA).
An alert signal from an 406 MHz (new type epirb) recieved by a geostationary satellite will immediatly be passed to a rescue co-ordination centre. However, the exact location of the epirb may (in a worst case) take several hours to pinpoint. In the meantime the rescue centre will have the epirb ownership and contact details and will be trying to contact someone to find out details such as what sort of vehicle, vessel, aircraft, group etc. has the beacon and where it should be. Depending on the information that the rescue centre gets from the contacts made, rescue services will be placed on standby or may even tasked before the exact position of the beacon is fixed as it takes two passes from an orbiting satellite to fix the position of a non-gps type beacon.
AnswerID: 192439
Follow Up By: Member - Mike DID - Sunday, Sep 03, 2006 at 10:06
EVERY aircraft has the ability to detect and home in on a 121.5 EPIRB - that won't change.
FollowupID: 450289
Follow Up By: Mike Harding - Sunday, Sep 03, 2006 at 13:35
They can't prosecute me until after they have rescued me :)
As Mike point out; 121.5 and 243MHz will always remain emergency frequencies and aircraft will alert S&R of an EPIRB - personally I'll stick with my VHF unit until UHF prices come down to a sensible level.
I have my doubts the the VHF sats will all be switched off in 2008 anyway.
Mike Harding
FollowupID: 450327
Follow Up By: robak (QLD) - Sunday, Sep 03, 2006 at 15:59
Can someone explain to me how a geostationary satellite makes "passes" in order to locate your beacon. Aren't geostationary satellites suppose to be continuously over the same spot on earth? Or have I got that wrong?
R.
FollowupID: 450349
Follow Up By: Member - Mike DID - Sunday, Sep 03, 2006 at 16:20
TV and communications satellites are geostationary and 36,000km out in space.
Others are not geostationary.
GPS satellites orbit every 12 hours at 18,000km.
Globalstar Satphone sats are at 1400km
Iridium Satphone sats are at 700km
FollowupID: 450353
Follow Up By: Member - Andrew (QLD) - Sunday, Sep 03, 2006 at 18:49
Robak,
Unless i'm mistaken, there was no mention of geostationary sats "passing" over any areas.
Quite simply, there is currently 2 systems at the moment, with the older LEOSAR being replaced by the geostationary GEOSAR system. Australia is covered by 2, and in some areas, the possibility of 3 GEOSAR sats.
Check out Site Link for all the info...
I would guess 121.5 and 243Mhz would still be used as a homing frequency for some emergency services for some period of time afterwards if the signal is available via the epirb.
FollowupID: 450375
Follow Up By: Member - Mike DID - Sunday, Sep 03, 2006 at 19:09
LEOSAR will ALWAYS be needed, as GEOSAR cannot determine the position of an EPIRB that does not have a GPS input.
FollowupID: 450379
Follow Up By: Member - Andrew (QLD) - Sunday, Sep 03, 2006 at 19:29
yep, sorry....my mistake :-(
::pushes edit button on EO site::
::changes the words "replaced by" with "supplements"::
FollowupID: 450383
Follow Up By: robak (QLD) - Monday, Sep 04, 2006 at 09:18
Andrew,
I just got a little confused as Kiwi Kia said:
"An alert signal from an 406 MHz recieved by a geostationary satellite will immediatly be passed to a rescue co-ordination centre."
and
"the exact position of the beacon is fixed as it takes two passes from an orbiting satellite to fix the position of a non-gps type beacon."
But I guess he was referring to the new and the old system. Is that right?
So with the new system do you need to have a GPS attached since it is a geostationary satellite?
Oh it's all to confusing....
R.
FollowupID: 450455
Follow Up By: Member - Mike DID - Monday, Sep 04, 2006 at 09:32
LEOSARs can locate 121.5 to 20kms and 406 EPIRBs to 5kms after a few passes.
GEOSARs can immediately locate a GPS equipped 406 EPIRB to hundreds of metres. They can immediately identify a non-GPS 406. They do not receive 121.5 EPIRBs which put out 1/25th the power of a 406.
FollowupID: 450456
Follow Up By: Member - Mike DID - Monday, Sep 04, 2006 at 09:39
All aircraft and helicopters are able to receive 121.5 EPIRB signals and SHOULD have their second COM radio set to this frequency, but it's not too likely on smaller aircraft.
To locate a signal will require multple passes by the aircraft at lower altitude
All 406 EPIRBs have a 121.5 transmitter to allow aircraft to home in on it.
FollowupID: 450457
Follow Up By: Member - Andrew (QLD) - Monday, Sep 04, 2006 at 10:20
hey robak,
Check out the table at the bottom of the page with the link i provided earlier:
Site Link
Helps greatly with your questions.
FollowupID: 450464
Follow Up By: robak (QLD) - Monday, Sep 04, 2006 at 10:22
Thanks andrew.
I also read kiwi's response below. It's all starting to make sense.
R.
FollowupID: 450465
Follow Up By: Member - Andrew (QLD) - Monday, Sep 04, 2006 at 10:26
and who would have thought a kiwi could make sense ;-)
FollowupID: 450466
Follow Up By: Member - John R (NSW) - Monday, Sep 04, 2006 at 10:47
Mike wrote:
___________________________________________
"EVERY aircraft has the ability to detect and home in on a 121.5 EPIRB - that won't change" and:
"All aircraft and helicopters are able to receive 121.5 EPIRB signals and SHOULD have their second COM radio set to this frequency, but it's not too likely on smaller aircraft.
All 406 EPIRBs have a 121.5 transmitter to allow aircraft to home in on it."
____________________________________________
Sort of correct, Mike. While all aircraft with a VHF transciever can receive (and report) the triggering of a beacon, the ability to home on the beacon is limited to aircraft fitted with direction-finding equipment (ie. search meter). At the moment, that is limited to specially equipped SAR aircraft, and certain military aircraft.
All airline aircraft routinely monitor 121.5 on COM2, whenever not using it for other operational matters. Some pilots (to the chagrin of the rest of us) even use 121.5 for chat....Grrrr.
FollowupID: 450469
Follow Up By: Member - Mike DID - Monday, Sep 04, 2006 at 11:04
EVERY aircraft which can receive 121.5 can localise the transmitter - DF equipment just makes it very easy.
Standard procedures are published based on using acquisition and loss of signal and then tuning slightly off frequency to reduce receiver sensitivity when close in to the transmitter.
FollowupID: 450470
Follow Up By: Member - John R (NSW) - Monday, Sep 04, 2006 at 11:24
Yes Mike, I'm aware of homing procedures. However it is neither taught during pilot training nor requested of aircraft (by SAR authorities) in flight (well never in my 25+ years as a pilot). The last time homing procedures (no azimuth guidance ala DME homing) were taught as a syllabus item, was back in the early 80's, and even then it was an add-on for an instument rating that very few people ever took up.
The point I'm trying to make is I would not want to depend on having a non-searchmeter equipped aircraft being asked to participate in a homing-based search. The overwhelming majority of pilots would not know (and don't need to know) how to conduct one.
A typical response to a triggering nowadays is for ATC to seek info, such as when did it start/squelch enabled/disabled/loudest signal/signal fade. Once this info is gathered I imagine AUSSAR uses the data to plot the various data on a map to get a search area.
FollowupID: 450475
Follow Up By: Kiwi Kia - Monday, Sep 04, 2006 at 12:03
Mike DID - The old methods of "boxing" a signal went out with whistle-stop tuning! :-)) Man that's a looong time ago.
This system is also rather useless in mountain or deeply incised topography.
I am not sure that modern PLL radios are easily tuned 'slightly off frequency'.
Someone mentioned 243 MHz - this is military stuff ONLY
FACT:
New COSPAS satellites DO NOT have a 121.5 MHz reciever.
FACT:
The old COSPA satellites have reached the end of their use by date.
121.5 MHz WILL be phased out sooner rather then later, it will not be kept operating with bandaids.
As John R said; "The last time homing procedures (no azimuth guidance ala DME homing) were taught as a syllabus item, was back in the early 80's"
FollowupID: 450480
Follow Up By: Member - Mike DID - Monday, Sep 04, 2006 at 13:36
When RPT crews detect a signal on 121.5 they report the acquisition and loss location which will be used by the RCC to localise the source.
Any type of receiver will have reduced sensitivity on an adjacent channel that can be used for close-in localising.
FollowupID: 450510
Reply By: Member - Meggs - Sunday, Sep 03, 2006 at 09:55
From 2009 all the satellites recieving 121.5 mhz will be shut down. The 406 mhz will be the only EPIPB's that can activate satellites. The 406 mhz will activate a satellite immediately and not wait until a satellite passes overhead. They can also get a lot closer to the position than the old 121.5 mhz. All the 406 mhz EPIRB's will also transmit on 121.5 mhz as this will be the frequency that will be used by aircraft to finally located the EPIRB.
The 406 mhz EPIRB's have to be registered with the name and contact info of the user and from what I gather if a 406 mhz EPIRB is activated the first step is contact will be made with the owner to see if the EPIRB activation is genuine so if you don't register it don't expect to have anyone come look for you.
The 121.5 mhz will signal aircraft but due to the number of false alarms I would doubt if anything will be done without a corresponding 406 mhz activation.
AnswerID: 192445
Follow Up By: Member - Rotord - Sunday, Sep 03, 2006 at 12:24
Every transmission on 121.5 will be rigorously tracked down even when it is suspected to be not a critical situation . One reason for this is that a beacon triggered in the marina could mask or confuse a beacon triggered in anger up to 12 miles away . The other reason is that a beacon in an unlikely position could still indicate a real emergency . After JAN09 sattelites wont listen for 121.5 , and the number of aircraft routinely listening on 121.5 wont be large , but you could still use the old beacons by nominating them on your remote area travel information . When you dont arrive an aircraft would search on 121.5 .
FollowupID: 450318
Follow Up By: Mike Harding - Sunday, Sep 03, 2006 at 15:36
Given that radio transmission at these frequencies is "line of sight" only I would be interested to know how a UHF EPIRB can communicate with a sat. until it "sees" it?
Mike Harding
FollowupID: 450344
Follow Up By: Member - Meggs - Sunday, Sep 03, 2006 at 16:43
The satellites are in geosynchronous orbit that means they are essentilly stationary and rotate with the earth.
A read of this site will answer all the question that have been asked.
There is a section on bushwalkers using EPIRB's and the al the answers should be found here.
Site Link
FollowupID: 450357
Follow Up By: Mike Harding - Sunday, Sep 03, 2006 at 16:48
So you don't know then?
Mike Harding
FollowupID: 450358
Follow Up By: Member - Mike DID - Sunday, Sep 03, 2006 at 16:59
A geosynchronous satellite with a very high gain antenna might be able to pick up a low-powered EPIRB, but how would it locate the position of the EPIRB ???
The COSPAS SARSAT satellites are in low earth orbit at an altitude of 528 miles - have a look at www.sarsat.noaa.gov/satellites1.html.
As they move over the surface of the earth they transmit the shift in frequency of the received signal to the groundstation so it can determine where the EPIRB is.
FollowupID: 450362
Follow Up By: Kiwi Kia - Sunday, Sep 03, 2006 at 17:17
There are TWO satellite systems involved in the picking up and tracking of EPIRB's.
The COSPAS - SARSAT system consists of a mixture of LEOSTAR (Low Earth Orbit) and geostationary satellites. There are at present six American and two Soviet satellites.
The geostationary satellites are positioned so that their footprints monitor most of the earths surface except at high lattitudes as you approach the poles. The low earth orbit satellites are in polar orbits and unless your epirb is fitted with a gps then it is these that are used to fix the beacon position.
The 'new' 406 MHz epirbs also put out a signal on the 'old' frequency of 121.5 MHz and this is used by aircraft to home in on when at close range to the beacon.
The position of an epirb is located by TWO successive passes of a low earth orbiting satellite and it could be from 2 1/2 hours up to nearly 7 hours till your psoition is fixed. The satellites use the doppler effect to locate the position of an epirb by listening to the signal get stronger as the satellite gets closer. However, the satellite can not determine if the beacon is 'left' or 'right' of its track across the surface of the earth so two possible positions are recorded. On a second pass two more possible locations are noted, one of these will be the same as the first pass and this will be the location of the beacon.
The geostationary stellites IMMEDIATELY pass an epirb signal to a rescue centre. The low orbit satellites can ONLY pass on a signal if they can "see" an earth recieving station at the same time as they "see" an epirb.
With 406 MHz system, in some cases, it will be rather obvious where a signal is comming from if one of the two possible positions is on land and the other position is at sea. As soon as contact has been made with an owner nominated person and the rescue centre has been told that the beacon is on a 4wd on land then a sea contact could be discounted.
The important thing about the basic 406 MHz system is that a distress signal is recieved and rescue processes are started immediately. Exact location of the beacon will still take a couple of hours.
FollowupID: 450363
Follow Up By: Member - Andrew (QLD) - Sunday, Sep 03, 2006 at 19:00
I would also assume that because in most cases 2 GEOSAR satellites will be picking up the signal and sending it on to the LUT for processing (great, either NZ or India in most cases ;-)), they should be able to eliminate the incorrect location due to triangulation. I can just see it now.......those kiwis answering the call from a Indian call centre :-)
FollowupID: 450376
Follow Up By: Kiwi Kia - Sunday, Sep 03, 2006 at 20:01
That sounds logical Andrew but it does not happen that way unfortunately.
The only sure way of getting your location immediately transmitted to a rescue centre is to use a registered, gps equipped epirb. I am of course assuming that the epirb has been placed in a position where it can 'see' a large portion of sky eg. not down in a narrow canyon or in a steep sided mountain valley.
FollowupID: 450390
Follow Up By: Crackles - Monday, Sep 04, 2006 at 21:07
"The important thing about the basic 406 MHz system is that a distress signal is recieved and rescue processes are started immediately"..... Kiwi Kia I hate to burst your idealistic bubble about EPIRBs but that's not quite telling the whole story. After spending 2 weeks out in the desert with a Seargent in the search & rescue sqaud I can add that although the duty officer may start making enquires as soon as the unit is activated, depending on the time of day, the area the signal is coming from & the availability of aircraft etc etc, he suggested to me that if they don't have a 2nd sourse to corroborate, often it's nearly 24 hours before a search may actually begin & as much as a further 24 hours before ground crews are sent in.
There appears to be a false expectation by many that if one was to set off a 406 that rescue will normally be at hand within 2 hours when after my discussions with a member who coordinates these search's that is rarely the case.
Cheers Craig............
FollowupID: 450628
Follow Up By: Kiwi Kia - Tuesday, Sep 05, 2006 at 06:40
Hi Crackles,
"...and rescue processes are started immediately.." I can assure you that they are 'Started' immediately. The situation is assesed, contact with nominated parties is attempted, information about the possible location, numbers in party, pre-existing medical conditions, age of party members, current and forecast weather conditions, checks on availability of assets (aircraft, ground, sea, manpower) in the area, etc. etc. In some cases assets may be put on standby and are ready to 'go' as soon as hard data on a specific location comes to hand.
In my previous posts I have indicated that it can be up to seven hours (worst case) before low orbit satellites can confirm an exact position of the activated beacon.
A 121.5 MHz beacon needs to have a satellite not just 'in range' of the beacon but the satellite must also be able to 'see' a ground recieveing station at the same time. This set of circumstances may not occur on each pass of the satellite and so a ground station may not even be alerted for several hours. It could then take many more hours to get an exact ground location of the beacon.
FollowupID: 450692
Follow Up By: Member - Mike DID - Tuesday, Sep 05, 2006 at 08:47
Unfortunately for 121.5 "exact position" from the satellite, means within 20km and for 406 within 5km.
If you're under good tree cover, it will be hard even for an aircraft to find the actual incident, unless they can home in on the beacon.
I spent many days on ground searches looking for VH-MDX at Barrington Tops (there was no beacon signal in this case) and it still hasn't been found !
FollowupID: 450719
Reply By: PatrolBen - Sunday, Sep 03, 2006 at 17:29
I used to actually sell these things for a chandlery joint. The time the 300Mhz network will be turned off is August 2009, the reason for the change is that the new digital 406Mhz epirb have a digital signal. The 121.5Mhz frequency is primarily for aircraft and as far as I'm aware will remain in operation. This digital signal is unique to each unit and will correspond to a file (you fill out a registration form when you buy the unit) kept at SAR co-ordination (Canberra) so when you let it off, the authorities have a description of your vessel (or vechile ect.), home address, phone numbers and from these deduce where you might have gone and also can quickly find out if it is a false alarm or not. Also the new digital signal greatly increases the accurace and triangulation time for a position to be worked out.
The new 406Mhz are completely different in packaging so that they can easily be distinguished from the old 300's so any half competant transport dude can see instantly if you comply or not. So those thinking of doing a cheapy, don't, just like everything the price will fall as the introduction date gets closer.
In the short term the 300Mhz are selling pretty cheap, we had the GME 300Mhz base model (one about 25cm long, bout a kilo in weight and includes a mounting bracket) for normal retial of $159.95 and on special for about $150. Look around (try your local Bargain boat bits) and I am positive you can do better. This way you get almost three years of EPIRB (although the battery will last five but no signal pickup) for about $150 instead of going the whole hog and paying $500+ for five years with a 406.
AnswerID: 192508
Follow Up By: Member - Andrew (QLD) - Sunday, Sep 03, 2006 at 19:15
I wouldn't buy a 300Mhz version........no-one would pick up the signal ;-) I take it you mean an epirb using the VHF range (121.5 Mhz). The last thing we need is another frequency thrown into the equation ;-)
FollowupID: 450382
Reply By: Member - Beatit (QLD) - Monday, Sep 04, 2006 at 11:35
G'day Alan,
Bought one of those small personal, soon (8/2009) to be obsolete, models for our trip last year and at $300 I was happy in knowing it would serve my purpose untill 2009. Should be able to get a couple of trips out of it and I genuinely hope it never needs to be used. Put it in the tinnie when boating in remote locations and slip it in the backpack if walking away from the car. I think they still remain good value even if they become obsolete in 3 years.
Kind regards
Theo
AnswerID: 192628
Reply By: Robin - Monday, Sep 04, 2006 at 16:09
Hi Alan
To get to the point of your question , from what I hear your assumption is correct.
Yes the current ones are an overkill for that use, apparently lower cost non marine units are on the way and it would be worthwhile to hold off buying one if you have no immediate need.
Robin Miller
AnswerID: 192714
Reply By: PatrolBen - Tuesday, Sep 12, 2006 at 19:43
Apologies for the extremely late reply,
I checked with my old work mates and they confirmed what I had posted. The old marine units do broadcast on 300Mhz and 121.5 Mhz. 121.5 Mhz for interception by aircraft and 300Mhz for the normal satelite transmission. I hope this clears up some confusion.
AnswerID: 194201
